Question about Husqvarna Garden
Changing a fuse on a YTH1542XP riding mower - Husqvarna Garden
2 Suggested Answers
alicantecoli
  • 22156 Answers
SOURCE: I have a cub cadet 2146 riding mower. I've changed the battery and replaced the fuses, still no power. What else could the problem be?
check the battery connections and also the earth cable if no luck their then check the fuses with a test light or similar and look for a feed to the fuses as the connections at the back of the fuses could be corroded
Posted on Nov 23, 2011
Where is the fuse on a Husqvarna model YTH1542XP riding mower
Did you ever find the fuse? I have looked at the diagram & tried to locate w/no success
Apr 20, 2013 | Garden
Yth1542xp take the deck off to clean
See page 19 and a very good diagram for this procedure in Figure 16 to do this. This is your owners manual. You will need Adobe Reader installed on your computer to view it. It is a free download if you don't already have it.
http://www.husqvarna.com/ddoc/HUSO/HUSO2003_USen/HUSO2003_USen_O0302029_.pdf
Jul 03, 2011 | Husqvarna Garden
Husky yth1542xp. I've changed the blades, leveled
When levelling the deck, rotate the blades so that the right blade has one of its cutting edges at or near the right side center of the deck. Do the opposite with the left. Measure to the blades from the level ground, not to the deck. Try leveling that way.
Gary
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have a yth1542xp when i run it for 30-40 min. it starts to move slower and when up an incline it will stop and start moaning. anybody with a fix out there.
It sounds like the hydro static drive in the rear of the mower is over heating. Remove the battery and carrier tray under the battery and check that the cooling fan and hydro static drive are free of grass etc. Regards Phil
Apr 14, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have a Husqvarna Lawn Mower YTH1542XP. when it is in gear to move, i have to use my foot to hold the pedal back for it to go. if i don't hold the pedal back, it barely moves. any suggestions are...
It sounds like the transmission drive belt is slipping. When you pull the pedal back you are increasing the tension on the belt. You may also want to make sure the spring that pulls tension on the idler pulley is in tact. Hope this gets you in the right direction.
Feb 23, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Blowing fuses
try unplugging the pto, starting the mower and then engaging the blades. If it still blows a fuse the problem lies in the mowers wiring. If not the problem is the pto. Hope this helps
Jul 13, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
15 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
