Question about Acer Aspire 5600 Series 5630-6951 Laptop
Monitor won't come on when power on
My Acer laptop powers up but the monitor is blank - how do I get the monitor to come on?
    New Friend:
  • 4 Answers
Try unplugging it and then plugging in again, and make sure the monitor is turned on.
Posted on Apr 20, 2013
  • 13433 Answers
SOURCE: Acer Aspire 3100 Laptop Monitor will not turn on
1. Mainboard failed
2. Vga adapter failed
I wouldnt be suprised if the vga failed, my acer broke down on me 2 times, on the 3rd time it was too much and I sold the laptop.
Posted on Mar 28, 2008
kibonghe
  • 25 Answers
SOURCE: external monitor says laptop is in power save mode and goes blank
hey jkep
this has nothing to do with power, here is what to do
right click your desktop->
properties->
click the settings tab->
click the advance button->
click the display tab->
depending on your graphic card there should be 2 or 3 different monitors being displayed switch them on and automatically your TV will turn on then you can change the settings to your likings
Posted on Feb 13, 2009
Geekman
  • 32281 Answers
SOURCE: acer aspire 5100 blank screen
Try reseating the RAM modules. If that doesn't work test the RAM in another laptop. If nothing works chances are you have a faulty motherboard.
Posted on May 03, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Toggle Between Laptop and Monitor
Fn + F5 toggles the display output, the trick here to wait each time you hit this combination because it goes through several options. Hit it once and it may want to go to just the external, then both the laptop screen and the external. etc. Now Fn + F6 turns the backlight bulb off on the internal monitor to save energy. Now I am giving up the link to your service manual, it is in PDF format so you can make a copy for yourself and keep on the laptop, print it or save it to a flash so you can reference it later. I believe if you take the keyboard off and disconnect the video lead on the left side where the display plugs into the motherboard, then when you power the laptop back up it will default to the external cord and you can use the laptop without any switching. That is what I am doing with an Aspire 5920 that I am rebuilding. Good luck, ParrotHead PC Repair
Just copy and paste the link below to you internet address bar and hit enter.
http://tim.id.au/laptops/acer/aspire%203680%205570%205580.pdf
Posted on Sep 05, 2009
ruwidperd372
  • 279 Answers
SOURCE: Acer Extensa 5210 blank screen
re seat the memory cards, clean them if necessary with pencil eraser (the metal connector on mem card), if it won't work, you might need to replace them with the new ones
Posted on May 04, 2010
Acer Aspire wont clone display on monitor
It is very possible, software not included, it happens like microsoft and their new progs, somehow they miss old friends of until we complain.
Try a download update.
Jan 28, 2013 | Acer Aspire TimelineX 5820T-5951 Notebook
My toshiba l675d-s7013 laptop screen won't come on?
hi
turn off your laptop take out the battery and hold the power button for 20-60 secs to discharge it and then put the battery back in and reboot or remove the battery and the ram clean the ram or try another stick of ram then press the power button and see if that restores your laptop.
if not plug another monitor into the external vga port, if the external monitor works then your laptop screen is faulty.
if the external monitor is also black or blank then the inverter inside the laptop needs to be checked or replaced.
cheers
Dec 02, 2012 | Toshiba Satellite Computers & Internet
E248WFP (external) Monitor Won't Power Off when Laptop Screen does!
this is not a pc problem... this is because the connection loss between pc and monitor... not all pc's have sleep mode in externa vga connection.... it just cuts power off... u can configure monitor of possible to do that..
Jul 09, 2012 | Dell UltraSharp E248WFP 24" LCD Monitor
Acer Model 2216W Monitor won't turn on
There are usually one or two capacitors that open in the power supply, and in some cases they bulge at the top making it easier to spot.
Apr 02, 2012 | Computers & Internet
( Dell xps m1530 laptop ) Monitor blank, powers up but screen won't come on.
It ISN'T the LCD screen. Since you diagnosed with an external VGA monitor, you now know the problem is the laptop.
(When you connect an external VGA monitor to a laptop, you are bypassing the Video Cable, and LCD screen. You are connected directly to the laptop )
The basic Windows files aren't being found. The boot files. This may mean a bad Harddrive.
Do you have the Restoration CD Disk? Laptop on insert it into the optical drive tray, close the tray.
When asked choose - Repair. (Non-Destructive Installation)
If a checkdisk is done, you have bad sectors on the harddrive.
There IS a special procedure in replacing a harddrive.
[ More information on Harddrives,
http://computer.howstuffworks.com/hard-disk.htm ]
Regards,
joecoolvette
Feb 26, 2012 | Dell XPS M1530 Laptop
My Acer V223W LCD Moniter, It all started a couple of weeks back, when it went into sleep mode the screen would turn off and the power will flash from stanby to on then off and repeats. I could fix this by...
It also doe the same if you use this monitor to your brother's PC? Just want to make sure since you will have to open up the monitor if the monitor is bad for sure.
It is more likely to have power supply problem due to unstable DC feeding the circuits because of bad DC filter caps as you can see to these ACER monitors here and also ALL other brands as well.
http://s807.photobucket.com/albums/yy352/budm/ACER/
You can learn about troubleshooting here:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jul 07, 2011 | Acer V223W Monitor
My LG Flatron W2453SQ monitor is connected to my laptop. Since two days ago, when I dont touch the keyboard/mouse for 30 secs the monitor goes blank and enteres power saving mode. I have chyecked the cable...
HI kissakiwi,
In the control panel's power option , you need to change the SYTEM STANDBY settings to never , and then the problem would be solved.
There are three options , turn of monitor, turn of hard disk and , system standby , if you select all of these three to 'never' then you won't have this problem.
Remember you can also change the settings via the screen saver tab when you right click and select properties on the desktop.
Let me know in case you have any queries. Hope this helps ...:)
Jul 01, 2011 | LG 22" FLATRON LCD Monitor
Both mains and battery power OK with green power light on but nothi8ng happening...blank screen. Can hear hard drive working.
There may be a pinched wire somewhere or a soldering joint that melted away, thereby cutting the power off to the monitor. If you can't take apart the laptop by yourself, bring it to a technician. If you choose to get rid of the laptop, remember that you can connect a standard monitor cable to it, and bypass the laptop monitor altogether.
Jul 12, 2010 | Acer Aspire One PC Notebook
Monitor flickering
Hi
Change the power cable if that does not work the power connector on the monitor may be faulty, Test the moniter on a different computer
Mar 28, 2009 | Acer Aspire 4315 Notebook
Acer Aspire 5600 Series 5630-6951 Laptop Logo
73 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
