Question about HP Pavilion a310n PC Desktop
How can I tell if my power supply is bad?
Had a brief power outage while at work. Now PC won't turn on. Green light on back glows steady. Fan does not turn on.
  • HP Master
  • 3,799 Answers
Switch the machine off and leave it unplugged from the mains for 5 minutes, while it is unplugged press the power on button a couple of times. (This will make sure all of the logic in the tower is reset, ) Then turn it on again. The only way to test a power supply is with a multimeter or a PSU tester, the second one is easier and cheaper. (about 5 to 10 GBP)
Posted on Apr 20, 2013
  • 624 Answers
SOURCE: System will not power up
Here is a Compaq document will walk you thorough a fairly lengthy procedure that should solve your problem. Here is the link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&dlc=en&product=431080&query=presario%20sr1220&dest_page=product#N561 Let us know how this turns out or if you need any additional assistance.
Posted on Jan 02, 2007
SOURCE: Computer will not turn on. Power supply shows flashing green.
depending on the make of computer, a power supply cost's around $20.
Posted on Mar 15, 2009
  • 367 Answers
SOURCE: Storm knocked power off late
The first thing to try is to cycle the power. To do this, unplug the power cord from the back of the PC and press and hold down the power button on the PC for 5 seconds. This will completely drain any "stuck" power in the components. Now plug the power back into the PC and try booting. If it still does not come back on after this, then you may be dealing with a blown power supply. You can buy replacement power supplies from your local PC shop for about $50 for a 400watt.
To protect your devices in the future, make sure you have a good surge protector and / or a UPS (uninterrupted power supply).
Regards, Chris
Posted on May 25, 2011
mikedenney
  • 150 Answers
SOURCE: PC won't turn on, small
Hate to say it, but it's likely your power supply. For years now, HP/Compaq, and Gateway/eMachines/Acer have all been putting 'Bestec'-brand power supplies in their brand-new desktops. I tired of replacing them because a) Brand-new computer owners strayed away from me if I warned them about it prior to 'the inevitable', and b) Often, power surges on these Bestec power supplies would also 'take out' the motherboard, and sometimes even hard drive (and data!). After years of seeing this, I reported this incredible catastrophic known-fail rate to a law firm in NY who is supposedly going after the manufacturers for this problem (or ignoring the problem). Power supplies can be bought for under $100, and any technician who is honest and affordable (and can also afford gas!) should be able to install one for under $50 (I do it for $30, for comparison). Those guys ARE out there--so search one out, and hopefully you'll be up and running in a few nanocycles (sorry, redundant error on my behalf--I'm a nerd, okay?).
Posted on Jul 05, 2011
Joe Onley
  • 363 Answers
SOURCE: Have a PC 099A-ABA that
Hi Joe,
a power supply is pretty basic, only 4 screws on the back hold it in, and while you are getting a new one, get one that is a little stronger than the one you have if you can afford it, just make sure you get one that has the proper cables. bring the old one with you so you can have the people at the PC shop give you the right one. Some of the connections are going to be a little tough to get to and out, but be patient and don't pull too hard, some have a retainer you must press to pull them off the board. It's pretty strait-forward as long as you don't lose your cool. You can look on Newegg.com to find a price that you can expect to pay at a local shop, or you can order from there and it would be there in a day or so.
Hope this is helpful
Joe :)
Posted on Aug 30, 2011
Steady green light in the back--have reset the memory cards and checked all connections. I took cover off plugged power in and the green light comes on steady once again but th e fan doestn run and the...
replace your power supply you have lost your 12 volt supply coming from your power supply
but you have your other power supply voltages still working
Sep 30, 2013 | HP Computers & Internet
Precision T7400 power supply sounding an alarm
Did you open the case on your computer? It may have an open case alarm which is a small switch typically located near the edge of the cover you removed. Make sure the case cover is completely installed, then see if the alarm goes off.
Feb 28, 2013 | Dell POWER SUPPLY Power Supply
I have aT3830 that wont power on
http://www.geeks.com/details.asp?InvtId=D845GVSR-BO-R I would like you to 'jumpstart' it, and then post back in a Comment. Jump the Soft Power On of the 20-pin ATX main power cable. Power supply plugged into power, 20-pin ATX main power cable plugged into motherboard. Straighten out a paperclip, then bend it into a U-shape. Put black plastic electrical tape around the top of the U. Turn the U upside down. You are going to use the 'legs'. The legs go down in the back of the main power cable's connector. (Where the wires go in) One leg goes down into a socket hole with the Green wire, RIGHT NEXT TO the wire, and MAKE SURE it touches the metal terminal at the bottom. The other leg of the U-shaped jumper wire goes down into ANY socket hole with a Black wire. Contact made is brief. Does the Power Supply turn on? As stated, post back in a Comment. http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Aug 28, 2012 | E-Machines T Computers & Internet
HP Pavillion a1514n Won't Turn On
Yes even with the green light on it could still be the power supply. Have you pulled the power, opened the case, and pulled the BOIS battery? Could be the BOIS needs to be reset. You might also pull all the memory chips, turn it on and see if you get a beep code. I have had that happen in the past. Then I would replace the power supply (if you have an old one laying around use it to test, with just the MOBO plugged in). If the power supply fails, that leaves only the mother board as the issue.
Good luck, I hope one of these suggestions works for you.
Jun 29, 2012 | HP Computers & Internet
Hook a monitor to the video output, if no change! the video graphics chip is bad located on the motherboard.
Jun 29, 2012 | HP Pavillion dv9740us Notebook
Dell dimension 4600c won't turn on since we had a power outage
hi
if you CPU has a green light it meance your Power supplay is working fine chack back side of your CPU fan is working or not if it's working then just open case
folow the 2 step
1 remove RAM
2 CIMOS beetery which is on mother board leave your CPU for Some thime re fix both i hope you CPU will give you the disply
Jul 19, 2010 | Dell Dimension 4600 PC Desktop
Dell Dimension 3000 will not power up after outage
hi,
If the green lihgt is coming on the board means smps is fine.
there is the issue with the mainboard need to repair.
Thank You.
May 30, 2009 | Dell Dimension 3000 PC Desktop
ATX Bestec 1956F Power Supply Failure
sounds like your power supplie has not been switched on by *********** board.the fan will not turn on until power supplie is turned on by mb.as far as what is wrong there are several things i can think of.i would try resetting bios. It sounds like your power supplie is working and your motherboard could have a short.but i have no way to be sure without testing. I can however tell you how to perform a test on your power supplie.unplug the 20 or 24 pin connector from your mb. look for a green wire,and then locate the grey one.short these two together(you can use a paper clip or something).if it dosnt power up. your power supplie is bad.also do not short any other wires,and only touch the grey and green for a few seconds as this is not how it was intended to be powered on.
Mar 03, 2009 | Bestec ATX-1956F (ATX1956F) 200-Watt Power...
Won't Start
BLOWN YOUR FUSE NEED NEW FUSE IN THE POWER SUPPLY
Jun 30, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
HP Pavilion a310n PC Desktop Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
