Question about Dollhouse Miniature Regency Dentil Molding
I'm looking for 1/2" scale dentil moulding. Can you help me?
My camellia has floweredd for the first time I eleven years but it has both pale pink and dark pink flowers.
They prefer acid soil and other types of soil can cause issues like this. However, there are far worse things that can affect them, such as scale, mould and root diseases.
Apr 05, 2017 | Garden
How to get mould of my quinny buzz seat cover??
I like a product called whizz mould and mildew remover have used this on many things before even on a mothercare pushchair hood but it was a waterproof hood so not as absorbent. Maybe do a spot test first somewhere inconspicuous.
Mar 31, 2013 | Quinny Buzz Three Wheel Stroller
Flakes/Particles coming out of the steam nozzle.
hi there,
the small flakes are bits of lime scale from your boiler system, to fix/ reduce flakes/particles complete a de-scale cycle on your machine using de-scaler. water hardness- set on 1 will change the length of time before it will ask you to de-scale the machine. Note- hardness 1 is the max time length. hope this helps
Feb 23, 2012 | Saeco Royal Professional Espresso Machine
The water leaks into my boot and the left or passenger side inside the car leaving huge puddles of water inside. very unpleasant. also the 2007 MX5 convertable - no leaks in roof or rubbers. help please.
  • If water is getting in from the driver's or passenger's window near the soft top weather-strip, shut the door after closing the window. When putting up the hood, lower the windows while you secure the hood latches & then raise the windows. These actions force the window to contact the weather-strip a bit differently than when the window is closed while the door is closed.
  • There are two common places an MX5 will leak water into the interior - where the top meets the windshield frame- and around the windows where they contact the mouldings. Leaks at the windshield frame are usually caused by dirty or damaged mouldings or the latches not being tight enough. Usually you will notice the top will squeak and rattle if it isn't latched down tight.
  • Wetness in the trunk/boot can be caused by a range of factors. 1. Dried out weather-stripping around the trunk. 2. A cracked rain rail on the convertible top. 3. Dried out weather-stripping around the tail lights.
  • There are three mouldings that fit around the window, and water can leak either between them and the window, or between them and the top. Each of these mouldings is attached to a metal 'track' that is secured to the top frame with two screws. The window moulding that is closest to the windshield header is held on by two screws, the others have nothing holding them.
  • Water can collect in the weather-strips due to small crack or splits along the edge of the hood where it folds after a years of regular top-up top-down use. The only real solution is a new hood.
Sep 08, 2011 | 2007 Mazda MX-5 Miata Touring Convertible
I locked my keys in my Hybrid Highlander and tried to use my husband's keyless entry fob to open and it wouldn't open. Is this happening because of a security situation. I can't believe the...
Lady,
Take a screwdriver and a foot rule. With the screwdriver remove the driver side plastic moulding that holds the window pane straight. Jus put the screwdriver blade under the moulding and press downwards so tha the moulding moves upwards. When the moulding is out, insert the foot rule or any thing hard and flat and thin between the glass and the door frame inline with the lock. When you feel resistance, press harder and you will hear a click. The lock has opened. Remove the keys and replace the moulding. It is press fitted. Press it till you hear a number of clicks. I have seen cops do it in LA while towing away locked cars.
Aug 15, 2011 | 2005 Toyota Highlander
I have two Taylor Lithium scales and neither one of them will turn on. I have replaced the batteries, still they will not turn on. I have done a "reboot" as suggested on FixYa, but without...
The scale may need to be initialized. This process is necessary because the scale was moved during the shipping process. Initializing the scale "re-seats" the internal parts allowing the scale to find the correct "zero." Here is how to initialize your scale:
- Place the scale back on a hard surface floor.
- With one foot only, place just enough weight on the scale for the display shows zero's or dashes. Once you see zeros or dashes remove your foot.
- Wait for the scale to turn off again.
- Step up onto the scale for a weight.
Or, your scale may be on an uneven surface or on carpet. Be sure to place your scale on a hard, flat surface to get an accurate weighing. Are you sure that the place the new battery with the "+" sign up into the battery compartment?
Keep us updated.
Jul 15, 2011 | Taylor 5599 440 Pound Tempered Glass Body...
Dollhouse Miniature Regency Dentil Molding Logo
37 people viewed this question
Top Dollhouse Toys Experts
Colin Stickland
Colin Stickland
Chance Miller
Are you a Dollhouse Toy Expert? Answer questions, earn points and help others
