Question about Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor
No movement or spinning of motor when turned on
I tried two separate - fully charged batteries; a marine battery and a car battery and still I am unable to get any life out of the trolling motor. I do not hear any humming from the unit nor movement on the prop when I cycle it on (forward or reverse). I tried manually rotating the prop, it does not appear to be stuck or jammed. The motor is relatively new, does not even have any scratches or chips on the bumper fin on the lower unit nor any dings on the props. Only used a dozen or so times. I am not the original purchaser, so I do not believe I have any access to the warranty. Any ideas or help would be greatly appreciated.
  • mike750 Apr 10, 2009
    Not quite the same problem:
    I have a buddy who has an auto pilot minnekota (Sorry - don't know the model) and he says the motor will not move when the directional foot pedal is pressed. Motor runs fine, but is in a "manual" state right now. Sorry to be vague, but that's about all I can offer. Any ideas?
    Problem Solver:
  • 11 Answers
One way to help isolate the problem is to turn the motor to an "on" position. Using a voltmeter, using the leads that go to the battery, test for continuity. If none, your problem is with the motor itself or the wiring inside the unit. Hopefully, you just have a loose connection. If the motor becomes warm or hot when connected to a charged battery while in "on" position, the motor is the problem.
Posted on Mar 12, 2009
My lift tech marine motor is running very slow, and growls when it first starts. Battery is fully charged. What's wrong?
I suggest you check the voltage to the motor while it is under a moderate load (and the current if possible).
If there is less than about 9 - 10 volts at the motor under load it is either consuming too much current or the battery or leads are incapable of supplying sufficient current.
If all outside the motor is good the problem is inside the motor or the gearbox. It will need dismantling and servicing.
Nov 09, 2017 | Cars & Trucks
05 cobalt. replaced starter and battery. starter solenoid spins but does not engage starter. head lights dim also when trying to start.
If the lights dim when the engine is trying to start, then the battery is not fully charged.
If the battery is not fully charged there is not enough speed to make the bendix on the starter slide out under centrifugal pressure and engage the ring on the flywheel.
Put the battery on a proper battery charger overnight. Also make sure the battery terminals as clean and tight, plus the negative strap to the body and the positive lead wherever it goes to.
Incidentally, the starter solenoid is not what you think it is as it doesn't 'spin'. It is an electrical relay used to take the massive amps needed to turn the motor from the battery to the starter without burning out the wiring to the ignition switch and the ignition switch itself. You mean the 'starter spins'.
Have a read
starter solenoid Google Search
Nov 08, 2017 | Cars & Trucks
Worx 17'' Cordless Lawn Mower (Model WG787). I've got a barely three month old lawnmower and the battery is fully charged yet the blade only barely spins. Seems to be virtually no power despite the charged...
The batteries are defective in this unit. It should be returned to the dealer that you purchased it from and get exchanged, or your money back. Another way to test this mower is to charge the batteries fully, then test them. If they are truly fully charged, run the mower until it slows down, and test the batteries again. If they are still charged, (unlikely) then the problem is in the motor itself and still should be returned.
Sep 09, 2017 | Worx 17" Cordless Lawn Mower with...
I have an electric friction motor on trike, For more distance I am adding a second battery (12v 18ah) in parallel. Need to put switch in line so one battery runs at a time. Then I know it is time to go...
Hi Chrome
I'd use pre-made automotive battery cables as they'll easily handle the amperage output as well as already having the ends factory installed.
With your battery selector switch, you'll be able to charge one batt at a time.
You'll need a ground from one battery to the switch and a common ground cable connecting the ground of batt 1 to the ground of batt 2 to make this work. Each HOT lead from the batts goes to the switch.
Hope this helps.
Mar 18, 2011 | Guest 2111a Universal Mount Marine Battery...
Minn Kota riptide ST green ready light will not turn on. It started flickering and will not turn on now. Pressed the battery test button and it shows that the batteries are fully charged. HELP!!!
Does the unit work without the auto pilot? Sounds like the auto pilot or the reciever is not functioning correctly.
Check and make sure the unit is grounded properly, you may need to run a test ground wire from the battery to the motor istelf to check this.
This is simple to do and takes 15 minutes. Starting in the battery compartment feed cable into the split-loom and continue feeding until reaching the control panel. Pull an extra 5 foot of cable and open dry hatch in rear by motor feed cable around and out to motor connections., Good time to check any circuit breakers
Try cycling the auto pilot though the modes.
there are 3 modes
to cycle through each mode
hold down the + and - key for 2 seconds
this cycles you to the next mode. Last but not least, try turning the unit on and spinning the prop by hand to see if it takes off, the motor migt be bound up slightly or have a bad spot on the brushes.
Dec 25, 2010 | Minn Kota Riptide St Saltwater 101 Bow...
How long will a 100 amp battery run a 30 motor att 2 speed ?
The Endura 30 draws 30 amps at the highest setting (5), so it'll run 100/30 - 3.33 hours with a fully charged 100AH battery. At setting (4), it only draws 15 amps, so it'll run 100/15 = 6.6 hours. At the lowest setting, it draws 3 amps, and should run 33 hours.
Feb 12, 2010 | Minn Kota Endura 30 Freshwater Transom...
Is battery included?
The 12 volt battery required is sold separate. You will have to remove the battery for charging...charger not included, It is possible to have the battery wired in such a way that it can re-charge from the alternator of the main engine.
Jun 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor Logo
550 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
