Question about Dryers
Therma Fuse keeps blowing on my Kenmore dryer (64291)
Replaced fuse yesterday and the dryer only worked for a few loads.
  • 6,784 Answers
Make sure the replacement fuse is a time delay fuse. the regular fuses will blow.
Posted on Mar 11, 2009
Why does dryer's thermal fuse keep blowing out
Take it back to where you bought it or call the number on the warranty and the costumer care person can help you! Good Luck!
Sep 24, 2012 | Whirlpool Dryers
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
Kenmore cloths dryer no heat --- drum and air but no heat ---think it is therma fuse clean vents
Well it runs so that is not the thermal fuse. I would check the limits on the heater or maybe the heater itselfthemobilian_2271.jpgthemobilian_2272.jpgthemobilian_2273.jpgthemobilian_2274.jpg
If these components check ok and yall still have no heat then the timer may be bad.
or the dedicated house dryer circuit breaker is gone on the heat load side.
The motor works on 120 volts or L-1 and neutral. The 5000 watt 240 heating element needs both sides of the breaker to operate correctly. Heat can be iffy or none at all if this is the case.
I have service manual and more HERE
May 02, 2011 | Kenmore Dryers
Hello, I have a Kenmore Elite Dryer Model 110.65062500 that just clicked when I press the start button. I replaced the Thermal Fuse and the dryer started working again but after two loads, it looks...
you have to clean out the dryer.if the vent line is long blow it out with a leaf blower,remove the duct that the lint filter slides into and clean that out and vac out the cabinet where the motor is.if you don't do this the fuse will keep popping,the dryer can't move the air because lint is blocking the air flow,if the dryer starts to run to hot the fuse pops as a safety so you don't have a fire from not cleaning out the dryer
Feb 17, 2011 | Dryers
Fuse blowing
Your exhaust vent is blocked.
Timed dry is High heat.
Permanent press is a medium heat and intermittent.
The dryer does not get as hot as often in Permanent press mode. Therefore the fuse does not reach critacal and blow.
Remove the vent at the rear of the dryer and run a timed load.
If it dries correctly, repair your vent blockage.
If not, repost and I will lead you to the next step.
Feb 19, 2009 | Kenmore Dryers
Kenmore Dryer
I am sorry to hear this, my name is Marc White, i am self employed and it seems as though you have a bad timer, bad timer will cause the timer not to go to the off position and blow your fuse......change your timer..
thanks
Apr 03, 2008 | Kenmore 73952 Gas Dryer
Kenmore dryer won't start
your blowing that many thermal fuses, id replace all the thermostats. (2) come in one kit both on heater box 1 top and one bottom. id also look into your venting, a clogged fo kinked vent is going to overheat the unit and blow all sorts of stuff(not to mantion the potential fire hazard of a bad vent
Mar 19, 2008 | Dryers
My Bosch Condensation dryer (W2L 5400) won't heat up -- can't find the reset button
you need to remove the centre metal plate,after powering off the dryer. The small red reset button is on one of the black plactic connects on my model (WTA4408)
Feb 24, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Dryers Logo
404 people viewed this question
Top Dryers Experts
