Question about JBL Duet Speakers, White Computer Speakers
Speakers not working
I have a pair of JBL white duet speakers that suddenly stopped playing in the middle of a song. Is it the AC adapter? That's the only thing I can think of. If so can I open it and fix it? If not where can I get a new one (JBL doesn't sell them)? Thanks for your time Pete
  • Indy Sarah Nov 01, 2007
    Mine are cutting in and out. I know it sounds like it's a short in one of my wires (it's strung with connecting wires about 40' from the computer), but I've tested all the connections and can't replicate the problem. It's just intermittent.
    Any ideas? Time is of the essence, as Murphy's Law would have it. I have another gallery opening tomorrow night. BTW, these speakers run all day every day, but they are only 10 months old!
    Thanks!
  • 4 Answers
If you have another computer or a friend, test them on his/her computer. Try this, as its fixed such a problem for me in the past. Start>All Programs>Accessories>Entertainment>Volume Control Then check the ticked/unticked boxes
Posted on Aug 03, 2007
SOURCE:
Volume stuck on mute for wireless speakers
After pairing it, have you tried to go to your sound settings in Control Panel and selecting the bluetooth device as your standard sound device?
Oct 25, 2012 | Computers & Internet
The speakers quit working/what do I do?
Make sure that it is the speakers that stopped working by unplugging them from your computer (or whatever you have them plugged into), and plugging headphones into the same jack that the speakers were plugged into.If the headphones work, you have confirmed that the problem is with the speakers. If the speakers use an AC adapter (black plastic cubical thing that plugs into the wall), then you might try getting a replacement AC adapter with the same output (AC or DC), voltage, polarity (which side is positive, and which is negative), and connector. If the speakers plugged into a USB port for power, your USB port may have turned itself off. In that case, reboot the computer to see if the USB port will turn back on.
If none of this works, you have to buy new speakers.
Apr 18, 2011 | HP JBL Platinum Computer Speakers
I am looking for a power cord for JBL on stage II speakers. Part no. 700-0042-001. Model no.TEAD-48-180800U
The following power cords will work with your speakers
You can purchase the power cord from the following site if you are in the UK:
http://www.power-adapters.co.uk/jbl-7000042001-acdc-18v-power-supply-adapter-p-7165.html
You can purchase the power cord from eBay if you are in the US:
http://cgi.ebay.com/AC-Power-Supply-Adapter-Charger-JBL-700-0042-001-/350422898000
Regards,
sjstore2
Dec 18, 2010 | JBL CREATURE II Computer Speakers
I was in the middle of playing a song and all speakers suddenly stopped working cannot figure out why.
If it will turn back on and it jus keeps doin that,,,blow sterio out ,,,dust will cause that,,also check ,,if you have to replace speaker wire,,one little place in wire will do that everytime,,new sterios do that to protect reciever,,auto shut off,,,
Nov 04, 2010 | Creative Labs Inspire P5800 Computer...
Hello, I have a pair of JBL Platinum Series speakers linked to my PC, which are just a few months old. They were working well, but they have stopped working. Although the green light comes on when I turn...
Hi Lauren This is the process of elimination which i would follow in a similar situation: -check cable going from computer to speakers, make sure both ends are plugged in correctly; -ensure sounds are not muted on your computer;
-try to play a song using another program such as windows media player. If this works, it's most likely the iplayer program which has been muted. -If none of this has helped, try plugging the speakers into a different device, such as a stereo headphones jack, ipod headphones jack, even a TV headphones jack. If the speakers still do not work, they are probably no good.
Hope this helps, Benji
Oct 02, 2010 | HP JBL Platinum Computer Speakers
I have a pair of JBL Duet speakers and 1 doesn't work unless the volume is maxed out on the other.
mcdevito75 here, Try to increase the volume from your keyboard, Then adjust the volume at the speakers, there should be only 1 volume control on 1 speaker to control them both, also check your connections at both speakers.
Jul 17, 2010 | JBL Duet Speakers, White Computer Speakers
Just wondering what the power supply output JBL Media 3 Speakers
I have a pair of Media 3 JBL computer speakers. I am using a generic 12V DC adapter rated at 1000mA with a positive tip polarity, and it works fine.
Aug 15, 2009 | JBL Audio Players & Recorders
Both speakers have sound, but some of it will not play.
You have connector problems- probably bad/bent/worn "jacks" in the speakers or they may be dirty (oxidation, etc) or fatigued. If you can get to the Jack on the inside of the speaker make sure it is making good contact with the plug. Clean the surfaces using alcohol on a Q tip or cloth. Many of these type speakers are not serviceable.
Mar 08, 2009 | JBL CREATURE II Computer Speakers
Video upload....
well, the connector that comes from the 2nd speaker goes into the speaker port in the back of the first speaker.
The wierd cord possibly fits into the 12v dc slot in the back.. and the other end would go to a power adapter..
Seems you are missing a power adapter,, like you said earlyer.
Basically you would need a standard power adapter which fits into the speaker.
You could get some universal power adapter for it like
http://cgi.ebay.com/UNIVERSAL-DIGITAL-AC-ADAPTER-ADJUSTABLE-VOLTAGE-NEW_W0QQitemZ150275118131QQcmdZViewItem?_trksid=p3286.m20.l1116
Or
something to this direction
http://cgi.ebay.com/UNIVERSAL-AC-TO-DC-POWER-SUPPLY-ADAPTOR-ADAPTER-CHARGER_W0QQitemZ230275174536QQcmdZViewItem?hash=item230275174536&_trksid=p3286.m14.l1318
If you want to make sure you get the right kind of power apdater
Try contacting jbl directly
http://www.jbl.com/home/product_support/JBL_contactus.aspx?ProdId=PLATINUM%20SERIES&ProdName=COMPAQ:%20Platinum%20Series
I was looking around ebay, found this
http://cgi.ebay.com/NEW-JBL-Platinum-Series-PC-Speakers_W0QQitemZ260266345340QQcmdZViewItem?hash=item260266345340&_trksid=p3286.m14.l1318
Theres the power adapter in the middle, I think the odd cord goes to the back of the first speaker and the other end would go to a power adapter.. try contacting jbl they should be able to get you what you need.
Seems you have everything else you need except for the power adapter.
Jul 26, 2008 | HP JBL Platinum Computer Speakers
370 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
