Question about Intec Wii Wireless Dance Mat with Foam Pad
Intec mat controller for dpr won't work
Controller with wire is working. how do you connect wireless mat?
  • 152 Answers
SOURCE: controller intec for x box
Maybe your controller needs a cleaning or the game doesn't work with wireless controllers. Check your game instruction manual.
Posted on Feb 17, 2008
leethedeuce
  • 4472 Answers
SOURCE: connecting
Is there a reset button on the controller itself on the original controllers its on the top of the controller that will usually do the trick.
Good luck,
Lee
Posted on Jun 13, 2008
SOURCE: Problems connecting a ps3 controller
Here's how to connect it tou your ps3. Mine works perfectly guys.
1. Turn your ps3 off without the USB key given with the controller
2. Make sure your controller is off.
3. Turn on the ps3
4. Turn on the controller
5. Press on the sync. button of your controller.
6. Plug the USB key into one of your ps3's port
7. When the light above your controller starting to flash slower, just pess the home button and your controller will be sync.
You can't turn on the ps3 with this controller. So turn it on manually than press the home button of the controller to turn the controller on.
If my post doesn't solve your problem, I really don't know how to solve it. I managed to connect mine so I hope it'll be the same for you!
Sorry for my bad English folks! You know... french people =S
Posted on Feb 08, 2009
SOURCE: We have an Intec G7789
I dun really know how I did it, I had the same problem as u guys. And I try all sorta method.
  1. the last method that I tried was to leave my USB receiver thing in and then restart my ps3. With my controller turned off.
  2. After the PS3 restarts, I turned on my controller.
  3. Then I pressed the home and link button together. And those 4 lights on ur controller will flash really fast.
  4. Then I replugged my USB receiver, and the controller light will flasher a lot slower.
  5. Then just press "home" and the controller should sync with your PS3.
  6. And after that NEVER remove ur USB. LOL. After that, everytime u turn on ur PS3 just press the home button and the controller should sync with ur PS3.
  7. And remember to always to turn on ur PS3 before u turn on your controller.
Well that's my solution, if it doesn't work for u then sorry. Get a refund. I was planning to get a refund but then everything luckily worked out. Good luck and keep trying.
Posted on Mar 11, 2009
  • 4 Answers
SOURCE: I have an intec wireless
Putting batteries in controller
Turn on the PS3
Turn on controller
Press the sync button, the LEDs will flash rapidly
Insert the usb that comes with the controller, the LEDs flash slowly
Press the home button on the controller
READY.
Posted on Sep 29, 2009
DPR-1040 does not connet wirelessly
Wireless router must not use WPA2. Change to WEP or WPA or buy a more modern printer server,
Jan 05, 2014 | D-Link DPR-1040 wireless print server,...
How do I connect theintec controller to the ps3
Jessica, assuming the intec controller you have is wireless, there are 3 ways to connect ANY controller to a game system. Wired, wireless(bluetooth) or wireless USB. If it is a bluetooth, then you will have to pair it with your system. to do this, you have to go into your settings, then manage bluetooth devices, and add new. If it is like the intec I have, it comes with a USB dongle that MUST be inserted for the controller to work. It is automatic. Just plug it into the system, then turn on the controller. Hope this helps, good luck.
Apr 05, 2013 | Video Game Consoles & Games
Intec ps3 infinite play not working pc
It's not meant for the pc, but instead for the ps3.
Jan 03, 2013 | Intec Sony PS3 Infinite Play Wireless...
Can't connect orb controller to ps3
Plug the dongle in to the USB port, turn on the PS3 and the LED will flash a lot (as if you've pressed the connect button), then press L3 and SELECT together for 3 seconds; it'll then connect. Then press the PS button.
As long as you keep the dongle plugged in, the controller will not disconnect and won't need pairing again.
Jul 27, 2011 | Intec PlayStation 3 Turbo Shock III...
Intec wireless controller won't sync to my ps3 it is the infinite play controller can you help me
Had a similar problem with an official Sony Dual Shock 3 recently. Turns out the solution was a very small pin hole sized reset button on the back of the controller. Have a look and see if yours has something similar, then try connect the charging cable again and sync. Worked on the official one for me anyway :/
Best of luck!
Mar 06, 2011 | Intec PlayStation 3 Infinite Play Wireless...
My INTEC Turbo Shock 3 Controller is not working i asked my friend i followed to instructions it did not help please help as soon as possible Thanks Peter
I have the same problem. I disconnected the key, plugged the controller with its original cable. Turned the PS3 on, turning controller on, pressing Sync, connecting the key in PS3. At that state, the 4 leds start to flash slower as it detects the key. Problem is I can never connect to console. I mean I press Home and it never connects. Its been working fine before I updated PS3 to 3.5 version.
Dec 27, 2010 | Intec PlayStation 3 Turbo Shock III...
The mat doesn't work Intec G5618-A
It may sound silly, but make sure that you put batteries into the pad and that the pad is turned on.
Jan 10, 2010 | Konami Dance Dance Revolution Hottest...
Intec xbox 360 remote does not work with my xbox
Many 3rd party company controllers don't work. I bought one before for my old gamecube and it didn't work. Intec sounds like a pretty reputable company, but I never heard of Intec. Your best bet for a cheap controller from a 3rd party is Madcats, they make good controllers for most consoles. What you should do is see if you can return it, if not, try these.
Wireless Controller:
1. Try taking out the micro chip and blowing over it,
2. Try to bring it closer to your console, so it can focus on to it better.
Wire Controller:
1. Try shifting around the cord until you get some kind of signal that it is working.
2. Take it to a software technician.
Please rate.
Good Luck, Noob815
Dec 30, 2009 | Intec Wireless Remote Control For Xbox 360
Dpr-1260 onkly works when connected by ethernet cable
dpr-1260 searching for ap and connected keeps changing back and forth when I refresh.On dpr-1260 if status of wireless keeps changing from searching and connected, change wireless to WPA, instead of WPA2. even if you have WPA2 setup (as I did), if you choose WPA it will stay connected.
Jan 23, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Controller intec for x box
Feb 10, 2008 | Intec XBOX CONTROLLER- PRO MINI CONTROLLER...
Intec Wii Wireless Dance Mat with Foam Pad Logo
Top Intec Video Game Consoles & Games Experts
Martin Murray
David
David
Colin Stickland
Colin Stickland
Are you an Intec Video Game Console and Game Expert? Answer questions, earn points and help others
