Question about Coleman Powermate Powermate 5000W Generator
Voltage too high (140v) when operating with load
    Prodigy:
    An expert who has answered 500 questions.
  • Coleman Expert
  • 573 Answers
The speed is excessive or you have a voltage capacitor in the end of the alternator gone bad
Posted on Nov 18, 2013
How do I fix...?an lg ctv model no 29 fg2rg which prodces high output voltage 155v instead of 140v
Check and replace all the electrolytic capacitors, including the main filter. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 11, 2015 | LG Televison & Video
What can I do if I am only getting 110v instead of 140v?
If you are getting 140v, you have a problem. I assume you are talking about powering the computer. Standard voltage in the United States in 120v, but I could range from 114v to 126v.
Why do you think you should be getting 140v?
Dec 22, 2014 | Computers & Internet
795.71029.010 Kenmore refrigerator not working
Run it for 10 minutes BEFORE you take that voltage reading, the compressor is a smart compressor and it senses load and has to run a while to tell the controller what to feed it. See pages 19-21 of the service manual.
Jan 20, 2014 | Refrigerators
E 3 error what does this indicate?
Error Code: E3Reason: The voltage is higher (140V-160V)for 3 secondsSource: Induction Cooker Error Codes Explained
Aug 20, 2011 | AEG 23 in. 6410KF-N Electric Cooktop
How much is a Pentax esp10-140 worth?
I found the ESPIO-140M selling for as little as $30, and I found an ESPIO-140V in excellent used condition selling for $150. I also noted a 140V that failed to sell for $55 on eBay. I hope this information helps.
Here's a link to the high priced V model:
http://www.porterelectronics.com/servlet/the-342/Pentax-Espio-140V-35mm/Detail
Jan 26, 2011 | Pentax Cameras
If the voltage in h out is 200v is good or bad and the voltage regular is heat?
You mean the collector voltage on the Horz output transistor is 200 volts?
I would check this by removing the transistor and then measuring the voltage on the board (where the collector or center leg of the transistor is soldered to).
I don't know what kind of tv this is but you should see 130v or 135 volts.
RCA sets you should see 140v. If the voltage is too high replace the voltage regulator.
Mar 09, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
G'day: I am currently fixing an upright freezer, Westinghouse Model#FJ383K-R Serial#338 53113. The fault is low voltage 140V going to the inside fan. I checked the fan, it's Ok, I checked the defrost...
140 volts in not low voltage. Actually it is a bit high or your meter is not calibrated correctly. In any event , just what is wrong with the freezer? If not defrosting check out the heat element for continuity. If compressor not running, check the hard start relay/capacitor. If you want a schematic go to this site for it as well as parts. Search Over 2 1 Million Appliance Parts
Sep 09, 2017 | Westinghouse Refrigerators
Horz. Output Transformer for a GE Mod#46GW945
Check this guys: //http://www.electronica-usa.com/
This guys may carry that part: //http://www.globalsemi.com/search.aspx
Jan 24, 2008 | GE 46GW945 46" Rear Projection Television
TV won't come on
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. This is probably a startup problem. It may be as simple as an open resistor that provides initial drive to the horizontal deflection. Check for power to the horizontal output transistor. If there is, check for drive. Could also be a bad flyback transformer. Another problem might be that the set is in high voltage shutdown, possibly due to a faulty voltage regulator. Check the regulated voltage going to the flyback primary (it should be marked on the circuit board what that voltage should be... 120V-140V in most TV's). If it is too low, the flyback transformer or one of its secondaries is probably loading down the primary input. If the voltage is too low, try disconnecting the secondaries. If the voltage remains too low, try disconnecting the primaries too. If the voltage is then normal, the flyback is bad. A REALLY bad flyback will also blow a fuse. don't leave the TV on too long with a shorted flyback, the h. output transistor can get too hot and probably fry, if it isn't fried already. If the primary voltage is too high, then the set is probably in high voltage shutdown, possibly caused by the voltage regulator. Good luck, and stay away from it if you haven't done this before. Take it to a lab if it's worth the repair.
Jun 03, 2006 | Memorex MT1091 Television
Coleman Powermate Powermate 5000W Generator Logo
64 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
