Question about kawasaki Garden
Exmark lazer z kawasaki motor surges and drags
The mower constantly surges and drags while trying to mow
  • 413 Answers
SOURCE: engine on riding lawn mower surging
Dirty air cleaner.
Clogged fuel filter.
Replace or clean both...
Posted on May 29, 2009
  • 396 Answers
SOURCE: engine speed surges
Surging engines in lawn mowers are usually related to a lean fuel/air mixture. With today's environmental concerns, the carburetors on these engines are set with a very lean mixture (to reduce air pollution). Furthermore, they usually put limiter caps on the carburetors where you cannot easily adjust the mix to get the engine to run better.
If there are adjustment screws on the carburetor, try turning the high speed adjustment screw a bit counter-clockwise (if the limiter cap will allow it). This will enrich the fuel/air mix a bit and might help the engine run a bit better.
Posted on Oct 11, 2009
Testimonial: "Thanks, I think I can figure out which is the High speed jet, it's the other one besides the one that restricts the throttle from going below a level."
mickey813
  • 472 Answers
SOURCE: kawasaki 21 hp motor periodically misfires
SOUNDS LIKE THE COIL IS BFAKING DOWN
Posted on Oct 30, 2009
SOURCE: 09 JD X 340 27hp Kawasaki eng\ surges
Hi
That is a fuel problem caused by stale gas you will need to remove and clean the carb with carb cleaner.
Sam
Posted on Jan 08, 2010
Testimonial: "thanks"
  • 697 Answers
SOURCE: 44" Exmark lazer z pto/blade problem
My problem is that I don't know what your problem is exactly.
Posted on May 06, 2012
Removal of hydraulic axle exmark lazer z zero turn
I can help you, but I don't know what you're asking. I have an extensive knowledge of Exmark mowers.
May 28, 2016 | Garden
Exmark lazer HP 19 Kawasaki 50" deck new PTO and new relays blades engage for 30 minutes then shut off engine on. After cooling will engage for 10 minutes then shut off
Engine valves need adjusting.
symptoms: starts ok, runs until engine reaches max temp loses power then stops. can't restart when hot. once restarted runs for a while stops again.
There is very little clerance in these valves and temperature alters the lenth by a few thou and the valve don't close fully losing compression, once cold the valves shrink back enough to create enough compression to start again.
Aug 13, 2015 | kawasaki Garden
Why does 23 hp. Kawasaki exmark mower fuel foul 1 spark plug after you mow a hour
have you tried a different spark plug? if not that then check the ignition coil supplying spark to the plug thats fouling
Jun 25, 2014 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
Can't get exmark mower with Kawasaki motor to start
Have had this problem with the Kawasaki engines and found the starter to be bad. The old starter was turning it over but was not fast enough to start. Have also found weak battery that did the same. The first one I ran into was a FH680 Kawasaki and spent about 2 hours trying to figure it out and it came down to the starter not turning it fast enough. Put a new starter on and started at just the bump of the switch. Let me know if this helps you out
Apr 26, 2014 | Garden
Exmark 44
When you say 'going forwaed', is that while mowing or does it do it without the blades engaged or 'not mowing'?
Jun 13, 2013 | Kohler Engines NEW 25HP KOHLER ENGINE...
Exmark mower Z HP 523 PTO quit
hi
it sounds ignition failure
check for broken or cracked ht lead to spark plug ensure the spark plug is good / failure of coil /stop switch cable broken or cracked /fuel line blocked / insure fuel cap filler hole is clear
Jan 06, 2018 | Garden
May 06, 2012 | Oregon Scientific Electric PTO Clutch for...
Garden Logo
94 people viewed this question
Top kawasaki Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
