Check engine light on ? How does it idle ? Have exhaust check for back pressure . Possible catalytic converter plugged . Also check fuel pressure with fuel pressure gauge . Iron computer ? PCM/ECM engine computer . Testing for plugged clogged restricted exhaust converter
FROM this LINK:
www.oilchangerinc.com/automotive/detail.cfm?Make=Oldsmobile
1999 Oldsmobile Aurora ... 1999, 1998, 1996-1997.
To reset the "CHANGE OIL" light, turn the ignition switch to the "RUN" position with the engine off.
The cars engine is most likey doing this...yes, not to worry....The engine is shut down by the ignition coil, it is either faulty and may need replacement, also, for better results, try to tune up the spark plugs, and make sure battery is fully charged... This should get Aurora back on his wheels...:)
