Question about Irons
Looking for assenbly diagram for MODEL IB 4201 BY ROWENTA ironing board
Assenbly diagram for MODEL IB 4201 BY ROWENTA ironing board
satscoop
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
SOURCE: Rowenta Steam Iron Leak
I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
Posted on Sep 03, 2008
SOURCE: Rowenta iron manual needed
does not heat but indicator light is on.
Rowenta steam Iron Model DE-871
Posted on Dec 26, 2008
  • 2976 Answers
SOURCE: Iron spits out rusty water. The iron is a Rowenta
Fill it with a mix of 50% white vinegar and 50% water. Let it set for 30 minutes and steam it out for about 2 minutes. Unplug it and dump it. After it cools colpletely, fill it with water and steam it out. The rust is coming from your water supply, not the iron.
Posted on Oct 06, 2009
SOURCE: wiring diagram for Rowenta DE-05
I took the iron apart for cleaning and installing a new cord and neglected to note which wire goes where. Does anyone have a wiring diagram for this iron?
Posted on Sep 26, 2010
I need a schematic for a Rowenta DW-8080 steam iron
They do not publish such diagrams for this type of product.
Oct 03, 2016 | Rowenta DW8080 Pro Master 1700W Steam Iron...
Rowenta steam iron fell down and top part is broken can it be replaced
Rowenta Iron Parts - eReplacementParts.com
www.ereplacementparts.com/rowenta-iron-parts-c-180639_180647.html Fix your Rowenta Iron today with parts, diagrams, accessories and repair advice from eReplacement Parts! Worldwide ... DE0554 Rowenta Steam Iron Parts.
Aug 08, 2015 | Rowenta Irons
My rowenta steam iron fell down and top part has broken any chance it can be replaced
I need the circuit board for a Rowenta steam iron Model DW2070
I tried to take apart a rowenta for my neighbor-Basically it is GLUED TOGETHER and is basically non repairable unless returned to vendor who repairs tge ho get them reglued! Weird!!!!!
May 23, 2014 | Rowenta DZ9080 Iron with Auto Shut-off
Rowenta pressure iron and steamer model DG5030? We have purchased the iron and cord, now we need to assemble the part.
Google Rowenta and go to their website, they will have parts diagrams and wiring diagrams. Hope this helps, please post solved on fixya.com. So I get credit for a solved problem if it does.
Apr 30, 2014 | Irons
It is sticky and looks like glue.It looks gooey
Hello :
Here I'm going to tell you the basics of cleaning your Rowenta iron :
Things You'll Need:1:Rowenta Soleplate Cleaning Kit
2: Ironing board
3:Clean, dry cloth
4:Two cotton terry cloths, such as washcloths
Now to the cleaning :
1:Pour out any water from the iron. Turn the steam iron on to the "Cotton" setting, which is the one with three dots on the settings dial.
2:Cover an area of the ironing board with a clean, dry cloth. Fold one washcloth or other piece of cotton terry cloth in half and place it onto the cloth on the ironing board.
3:Dispense a 2-inch long daub of cleaning solution onto the terry cloth. Run the heated iron over the cloth directly on the cleaning solution. Move the steam iron in a circular motion over the cleaner on the cloth for a minute or two.
4:Remove the steam iron from the cloth. Carefully wipe any remaining cleaning solution from the soleplate using the second terry cloth.
5:Add water to the steam iron. Turn on the "Steam" or "Burst of Steam" feature. Run the iron over the clean, dry cloth on the ironing board to ensure the cleaning product is entirely gone from the soleplate.
PLEASE RATE !
Apr 20, 2010 | Rowenta DX6700 Iron
My grandson knocked my Rowena Iron model DE-87.1b
go to the store get a 2 part epoxy glue follow the directions and mix the glue put it on both the knob and the part the knob goes on wait untill the glue gets tacky then put the knob back on wait 24 hrs. before you use the iron so that the glue can set
Apr 24, 2009 | Rowenta Irons
Rowenta problem
mY de 87.1C WAS WORKING AN ABOUT TWENTY MINUTES OF IRONING, THE CORD & PLUG IN BLEW & IT QUIT.
Dec 26, 2008 | Rowenta Professional DE871 Iron
If you dropped it it will probably be an easy fix. Just openup the unit and look for a crack in the cicuit board. This is the case 99 percent of the time in apliance drops. If you find a crack in a board simply epoxy it and on the cicuit side of the board solder jumper wires from point a to point b when you follow the boken trace(s). If more than one trace is broken repeat the process until all the circuits can be repaired. Make sure you use wire of a high enough rating to handle the current the trace handles, and also use wire with heat resistant insulation in this application.
First things first though. Just open it up and have a look. The plug to the heating element may have just been knocked off. With a little trouble shooting skills and a good look you should be able to see your problem. If you get it open and see something I did not tell you how to fix just post any question you have and I will answer them for you.
George
Jul 24, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
Irons Logo
128 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
