Question about Mitsubishi LVP-X70U Multimedia Projector
Power on. When projectors main power switch is turned on, the power and lamp light stay on but no light out put. Dvd is connected to the projecter. How can you tell if lamp is out.
  • 682 Answers
Try to feed projector from video and from pc or laptop if you get the same result from all signal sources you have a problem in main board and it needs to fix in good service center.
Posted on Mar 18, 2008
SOURCE:
The projector turns on but won't project any light through the lens.
If this is a NEC VT series projector, Change the lamp. When if it continues to blink amber and not project and image after installing a new lamp check the lamp cover to see if the micro switch tab on the lamp cover broke off. Some models have a built in lens cover. If the cover is not slid over to open completely the light may not turn on.
May 19, 2014 | NEC VT800 LCD Projector
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
I have Sony VPL CS6 projector and the lens cover stays open and wont shut to cover the lens!! The Lens/Cover light on it flashes? It does project for about 15seconds or so but then goes off, this is when...
It is possible that there can be few reasons for the fault siad:
1.the lamp can be faulty
2. the filter can be clogged.
3. the lens cap trigger switch can be faulty and staying on
4.The power supply can be faulty, not delivering the power but shuts off.
5,the main processor board can be faulty witth errors.
It might need board swapping to confirm.
Sep 25, 2010 | Sony VPL CS6 Multimedia Projector
What is wrong with my Panasonic PT-L711XU projector?
try to clean the air filter of your projector... in case the problem occur check the lamp ballast board and replace it.
jahting
Oct 10, 2009 | Panasonic PT L711XU Multimedia Projector
InFocus Won't turn off, no powering down, and no projection
The 4805 does not have a power button it has a power switch next to the mains power connector but that switch has no lights near it.
If you meant the power light on the top of the projector right next to the menu button is yellow that is bad. it indicates that the main board is not working which would explain the projector always being on. also the led being orange means that both the green and red led's are on at the same time (this is BAD)
This is not a valid function for the led's. Another indicator that the main board is wacked. By the way if you received the projector less than 30 days ago you can file a claim with the eBay resolution center that the projector is not as advertised/Described in the listing. And you might be surprised when you get your money back! the "NO RETURNS"is null and void if there was any gross misrepresentation or deception in the listing!! i.e. Not as described...
Sep 19, 2009 | InFocus In Focus SP-LAMP-021 Replacement...
PROJECTOR PROBLEM Casio XJ 31
it wasn't able to go through cooldown mode. turn it on, power down and let it go through cooldown. does the light come on at all?
May 31, 2009 | Casio XJ-S31 Projector
Only power light will power on for few seconds then flashes.
Does the main lamp light at all? It sounds light a cooling fan failure. If the fan iis not working the the main lamp will not turn on and the power light will flash.
Jan 07, 2009 | Optoma EP755 Multimedia Projector
Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Oct 13, 2007 | Toshiba TLP S30 Multimedia Projector
Mitsubishi LVP-X70U Multimedia Projector Logo
141 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Marvin
Marvin
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
