Question about Mitsubishi WD-65638 65-Inch 3D-Ready DLP HDTV
DLP screen is pulsing. Shouldn't be a lamp issue.
My issue started out as an occasional green tint that would flicker across the screen. I assumed it was the color wheel, so I replaced it. No change. I put the old color wheel back in, and replaced the DMD board (not the DLP chip). Still no change, so I put the original board back in. The problem has now progressed to what seems to be a pulsing of the screen. The picture appears to change saturation in a constant flicker. I've tried replacing the lamp itself several times, with no change. The TV has never shut itself off or displayed any warning lights. I hate this TV...
techman
  • 3130 Answers
SOURCE: Lamp Light Red - No Screen Image
It could be the a problem with the lamp ballist circuit, or just a bad lamp socket, or simply a bad lamp. The only way to tell is to call out a servicer as that would be alot less expensive then to get a new lamp and then that not be the problem. These problems can be a little hair pulling at times, thats why i have no hair left!! LOL Good Luck
Posted on Mar 21, 2007
  • 1153 Answers
SOURCE: Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Posted on Sep 18, 2007
  • 395 Answers
SOURCE: DLP TV turning on and off automatically - Mitsubishi WD-52327
1. Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB part # 930B929001
Posted on Feb 21, 2008
  • 8457 Answers
SOURCE: tv tries to turn on but then turns off with a red
Lamp light on again?must replaced the lamp again,the lamp hours it up.
Posted on Mar 30, 2010
SOURCE: mitsubishi WD-65737 DLP TV. TV powers on, green
I had exactly the same thing happen..I contacted Mitsubishi and they said the software needs to be updated..they are going to send me the link to download the software.
Posted on Dec 29, 2010
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from www.cnet.com
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Jan 18, 2016 | LG Televison & Video
Samsung HLM507 FLICKERING PROBLEM
how extended is that warranty, and what does it cover? Sounds to me like a classic video controller board about to fail.
Mar 24, 2008 | Samsung DLP HL-P5663W 56" TV
57in Toshiba projection tv flicker all the time,what the problem?
Toshiba 56HM195 DLP Flickering Problem - YouTube
? 0:08
www.youtube.com/watch?v=SxnUYXkaLr4
Nov 21, 2009 - Uploaded by Brian Baute
Flickering & green boxes appearing all over my Toshiba56HM195 screen. This behavior is consistent all the time, with multiple lamps, and across multiple inp... ... Up next. Stay Away From Toshiba DLP Projection Television!
Oct 29, 2015 | Toshiba Televison & Video
67" Samsung DLP. Last night it started flicker to a green tint. Back to normal then green tint. Now it's completely a green tint. Still has picture and voice but green tint and not bright like before.
In those sets there is what they call color wheel and it could be on its way out it sounds like its stuck.or not working prop in any case you need to bring it in for service place
Mar 26, 2013 | Televison & Video
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
I have a hitachi 50vf820 with green tint to it
Its a DLP type set that uses a lamp for a light source.
With the color turned to zero stand back and examine the image.
If mostly all green or areas are green you may have a issue with the optical light engine--either damaged inside from the heat of the lamp or the portion that processes red, green, and blue information bad.
Jun 03, 2012 | Hitachi 50VF820 Projection TV
DLP RCA HDTV is displaying bars from top to bottom of screen, with green tint. Is this the light engine going bad?
Hi
Thanks for using FixYa. This issue can happen due to a faulty light engine or due to a a faulty DLP Lamp. However, it can be an issue with the video driver card of your Card. I'll suggest to use a DVD player and check if the tint is still there. If the tint disappears then its an issue with the video driver card.
However, if it doesn't correct the issue its either a DLP Lamp or a faulty light engine.
Note-- Please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in OFF condition.
Before performing any repairs i'll suggest you to try and reset the TV by unplugging it for 8-10 hours.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 15, 2009 | Televison & Video
Sony Wega 50" DLP bluish tint
the issue is the optical block. replace the optical block
Jan 07, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Blue Flickering Screen - Which Repair Kit?
yes they provide a free service manual with their kits. the symptom of the blue screen could either be the signal or the FMT as they can both cause those symptoms, My professional guess would be the signal board as the FMT will cause distortion lines across the screen with no picture.
Sep 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Screen's color in black and white
your color went out because the color wheelor generators not working. These are sofisticated sets and if I were you I would call a pro as you dont want a local guy who knows little about DLP sets to cause the problem to 10 fold. Contact 800-211-PANA see if they can help
Apr 18, 2006 | Panasonic PT-52DL10 52" Rear Projection...
Mitsubishi WD-65638 65-Inch 3D-Ready DLP HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
