Question about Dell OptiPlex GX270 PC Desktop
Guide for setting bios options ? - Dell OptiPlex GX270 PC Desktop
  • DEAN ASHER
    DEAN ASHER Apr 22, 2013
    There isn't an option for that that I can see ??
  • Dell Master
  • 27,725 Answers
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow keys navigate through options.
Posted on Apr 20, 2013
  • 2 more comments
  • DEAN ASHER
    DEAN ASHER Apr 21, 2013
    Getting to the Bios is no problem . The bios on my computer has so many options I was hoping maybe there was a glossery or such that would help with the settings . This being an old computer and has seen many changes it gets a little confusing . Thanks for the input though , everything helps .
  • Brian Sullivan
    Brian Sullivan Apr 21, 2013
    you can set failsafe or optimised defaults
  • Brian Sullivan
    http://www.maximumpc.com/article/feature...
  • DEAN ASHER
    Not seeing that option on my computer . Am I missing something ? Ended up finding most of the info by simply googling each option and picking the best fit . Thanks for all the help though .
Setting of USB boot
http://support.fujitsupc.com/CS/Portal/supportsearch.do
A6110/A6120 BIOS Guide
Boot Menu
Nope. No option for booting from USB
1. Floppy Disk Drive
2. Drive0: (Harddrive)
3) CD/DVD Drive
4) NETWORK
5.
6.
7.
Excluded from Boot Order:
USB MEMORY
USB Harddrive
Back before USB thumbdrives (Flash Drive, whatever), came on the scene; the Floppy Drive was used. Then the Optical Drive came out.
(CD/DVD drive)
Transfer the boot data to floppy disks, or a CD/DVD disk.
Make sure they are bootable..........
Regards,
joecoolvette
May 06, 2013 | Computers & Internet
There is missing system configuration option in acer AOD257 bios
Search for a recent update for your bios. You can also try a different bios all together. Google "Acer AOD257 BIOS Upgrade" and "Acer AOD257 compatible BIOS". I remember my old BIOS having very limited options available. The BIOS I use now has two pages of options. Hope I was able to help!
Jan 30, 2013 | Acer Aspire One D255-2670
How to enter bios setup to toshiba dynabook satellite 1850
1. Enter BIOS Setup
1. Press the Esc key while powering on the computer.
2. Press the F1 key, when prompted.
2. Change the Virtualization Technology option
The Virtualization Technology option is in the OTHERS configuration pane on the right-hand side of page 1 of the BIOS system setup.
1. Press the O key to select the OTHERS pane, and use the down arrow key to move down and select the Virtualization Technology setting.
2. Set it to Disabled.
3. Change the Configuration option
The CONFIGURATION option is on the upper left-hand corner of page 2 of the BIOS system setup.
1. Press the PgDn key to go to the second system setup page.
2. Press the O key to select the Device Config setting and change it to All Devices.
4. Change the Display option
The DISPLAY configuration option is on the bottom left-hand side of page 2 of the BIOS system setup.
1. Press the D key to select the Power On Display setting and change it to LCD+Analog RGB.
5. Save the changes by pressing the End key and then the Y key to. Be sure not to press the Home key -- which restores the default BIOS settings.
Aug 14, 2011 | Computers & Internet
Cant open computer bios has password its a toshiba a10 system unit i turn it on and it only wants a bios password
hi,
you can remove the bios backup battery inside.
open your laptop and locate it on the motherboard, remove it for about a minute and replace it back.
your bois settings will all be reset including your password.
but before doing that you must be familiar on the bois settings of your unit prior removing the battery.
You can also doing it in the cmd. to this just follow the links below to guide you.
Hope that answers your problem.
Don't forget to rate me ok. Thanks.
Best regards,
john
resseting at the cmd.
disassembly of your laptop:
utube.png You-Tube video "ilyVTnHImzY" placeholder
removing bios battery:
utube.png You-Tube video "hyuFOvkMeCw&feature=player_detailpage" placeholder
Jan 08, 2011 | Toshiba Satellite A105 Notebook
Want to re-format MSI Notebook S420. Screen continuously shows windows 'loading' but never boots. I have the recovery CD but because the computer never actually starts, I'm not sure what to do with it!MSI
Hello megan_van
While your laptop is on, eject the optical drive and insert the recovery CD. Turn off your laptop via the power button, and turn it back on. The recovery CD should boot. Follow the on-screen instructions to do a clean install.
If the recovery CD doesn't boot, try holding down the C key after turning on your laptop. If it still doesn't boot, you will have to change the boot order in BIOS. Don't worry, this is easier than it sounds! Follow these instructions:
1. Turn on your laptop, and look for a message that says something like PRESS (USUALLY F2, F8, DEL, ETC.) TO ENTER SETUP / BIOS. Hit that key before the Windows logo appears.
2. After hitting the relevant key, you'll be taken to the BIOS setup utility. All BIOS utilities have different appearances, but it is basically a set of menus containing different settings for your laptops hardware. Somewhere on the screen (usually the bottom), is a set of instructions for navigation your way around the BIOS. Follow these instructions to navigate your way to the option for changing the boot order.
N.B. Since every BIOS setup utility is different, the specifics on where the boot order options are located varies from computer to computer. The menu option or configuration item might be called boot options, boot, boot order, etc. The boot order option may even be located in a general menu like advanced options, advanced BIOS features, other options, etc.
3. Once you've located it, use the navigational controls to place the optical drive above the hard drive (usually the +/- keys). To be certain that the recovery CD boots, it's probably best to move the optical drive to the top of this list.
4. Within the navigational controls, there is usually an option to SAVE & EXIT. Press this key. If there isn't, look for a menu option with the heading EXIT. A SETUP CONFIRMATION box will now usually appear asking you to confrm the changes you've made to the BIOS before exiting.
N.B. The SETUP CONFIRMATION box can sometimes be worded cryptically. Read the message carefully to be sure that you're saving your changes instead of exiting WITHOUT saving your changes!
Your computer should now restart automatically, and the recovery CD should now boot.
Hope this helps. If you require further assistance, please don't hesitate to ask.
ajblaj
Apr 28, 2010 | MSI MEGABOOK M510C Notebook
PCV-RX580
ok, you press F2 or F3 to enter into the bios setup.
Thanks
Oct 27, 2009 | Sony VAIO Digital Studio PCV-RX580 PC...
Trouble Updating BIOS: Medion M3 Director 5100
plz check the fsb of ur new memory.plz conform it the memory is supporting ur motherboard.
Jan 15, 2009 | Medion M3 Director 5100 PC Desktop
Tower change
1. Restart your machine
2. Enter BIOS by pressing F2
3. Scroll down to 'System Security'
4. Press Enter
5. Scroll down to Chassis Detection
6. Arrow over to 'Disabled'
7. Press Escape
8. Save changes and exit.
In some bios is in bios in the section BOOT and BOOT SETTING CONFIGURATION and disable CASE CHASSIS WARNING.
Your bios may be slightly different from the above. check inside the settings and find the case chassis warning option.
Regards
Mar 29, 2008 | ASUS NVIDIA nForce Chipset A7N266-VM...
BIOS PROBLEM
Actully you are not selecting the reall speed of CPU thats why it asks. Its better to use the default setting of your BIOS as it was provided by company as per your specification.
Thanks
Iqbal
Mar 09, 2008 | Computers & Internet
Dell OptiPlex GX270 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
