Question about Toshiba Office Equipment & Supplies
Not able to print from computer
Copier is installed on computer and set as default printer, still unable to print from computer.
  • abby_burroug Mar 11, 2009
    it's connected by a usb cable. also, it's not showing up that it's even connected in the little list of things connected via usb.
  • 523 Answers
If its hooked by usb cable to copier you have to check the cable if its good and the most important if ur loading the right driver for the real windows. But if your connecting through network cable, you have to check the ip address if its the same in machine and in the driver, also you have to install the right driver, and check ur connecting devices such as switch, hub, router. let me know the type of connection and will help you solve it.
Best Regards
Posted on Mar 11, 2009
  • Kyocera HP Expert Mar 11, 2009
    Best Regards
Unable to print files from windows 7
have you checked the setting if the machine is the default printer
Nov 11, 2015 | Sharp Mx-2310u Color Copy/print/scan
My printer scans, copy but won't print from computer?
Did you set this printer as the default printer? To do this go to Start - Printer and Faxes, right click on HP printer, select Set As Default Printer. If you are not see your HP Deskject F340 there, that mean your printer driver is not installed. Please install your printer driver.
If you already set it as the default and it is still not printing. Restart your computer to try solve problem.
You said that printer scans so the connection between your computer and printer is fine. Problem is your computer doesn't take the printer as it's printer device yet.
Hope this will help. Thanks for reading
Jul 19, 2011 | HP Deskjet F340 All-In-One Printer
I have problem in my printer when i print a self page the print is ok when i print through a computer there is no print on page except a single line plz help me
Hi
reinstall your printer driver
check you'r computer about viruses
check in 1- start menu 2 - printer and faxes
if you installed diffrent printers set your main printer as default printer by right click on printer name icon and chose (set as default printer)
good luck
May 23, 2010 | HP LaserJet 6p Printer
Print one side only
Plz Check Duplexer Is Disable either thru Hardware or Software
Sep 14, 2009 | Office Equipment & Supplies
I HAVE INSTALLED THE LEXMARK 4200 SERIES PROGRAM ON MY COMPUTER THE LEXMARK IS A X4270 MODEL. BUT I AM UNABLE TO PRINT MATERIAL FROM THE COMPUTER TO THE ALL IN ONE LEXMARK OFFLINE OR ONLINE. IS THERE...
START- CONTROL PANEL-PRINTER AND FAXS.
Is it listed there? If not click on ADD A PRINTER, follow the prompts. if that doesn't work , let me know, and we'll try other things. .
Dec 31, 2008 | Lexmark X4270 All-In-One InkJet Printer
Printer instalation
Good day.
Usually that happened once the printer was not set to default setting after it was installed.
To set to default, click start, choose printers and faxes, select the lexmak pinter, click file select default printer.
To test your printer if it print.
1. right click the printer icon
2. select properties
3. click print test page
Thanks.
Nov 01, 2008 | Lexmark X6570 InkJet Printer
Command print, set up like it will print, but immediately brings up fax form to be completed for faxing...............unable to get print. Suggestions? Thanks, Dave
Make sure your printer is set as the default printer in the control panel of your printer. You fax mode could be setup for default causing the problem.
Jul 13, 2008 | HP Officejet 5510xi Printer
LEXMARK P6350 All-In-One
Did you ensure you connected the usb cable and printer in order of the disc requesting you to do so.
Have you been to Lexmark site?
Have you enabled the printer in Printer settings as a default printer? It should normally do so when installed, but worth checking if you have other printing software on your comp
Regards Faggly
Mar 25, 2008 | Lexmark P6350 All-In-One InkJet Printer
Unable to print
Just a thought has the re installation put the printer to lpt1 instead of the enhanced USB for printer? Another way to try to get over this is to go to Faxes and Printers Click on install new printer When the window comes up asking for the CD or select from list- take 'select from list' Select the Printer Maker - HP Select the model. Follow through and make it Default printer See what Happens. Also take a look in www.fixyourownprinter.com
Jun 28, 2007 | HP PhotoSmart 7260 InkJet Printer
Installed drivers and set up new unit per instructions,unit will not scan or print from any user
open the nprinter folder and confirm that your preinter is set as the default printer,try and print a test page,then send your printing jobs,good luck. eyo7 eyoifiok2005@yahoo.com
Mar 30, 2007 | Lexmark X7350 All-In-One InkJet Printer
63 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
