Question about Whirlpool MH1140XM Microwave Oven
I have a Whirlpool MH1140XMB-2, the low voltage side works fine, clock, button, etc. When I start the microwave, smoke will bellow out of the top after it has ran for one minute and it smells like a burnt component. I placed butter in the microwave to see if it would heat up, it did not, what do you think could be the problem? As I don't want to replace the microwave over a ten to thirty dollar part?
MicrowaveSvc
  • 9098 Answers
SOURCE: After changing a blown oven light, the clock works but nothing else turns on, including the fan, light, microwave
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
Posted on Nov 28, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave external underside light no longer works
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The lights fan can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 22, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Whirlpool MH1140XMB-2 mic won't start
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
Or you can view and download it here.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you've recently had trouble with your cooktop lights, one may have shorted, causing a problem on your control circuit board, which we regularly repair for $39.95 in about a week or so with a one-year guarantee.
William E. Miller
prototech@usa.net
Posted on Oct 10, 2009
Testimonial: "I lifted the door a couple of times and the microwave started working, so we know it is the door switch mounts. Thank You!!!!! "
SOURCE: i have 2yearold whirlpool
NOyou with need help on fixing this problem
Posted on Aug 27, 2011
  • 1833 Answers
SOURCE: Microwave had burnt electrical smell a few minutes
The electrical burning smell will be the Hi-Voltagetransformer inside the microwave. Along with the transformer you will also needto replace the capacitor. It couldbe a leaking high voltage cable (electric arching) bad insulator, if it's moreof an electronic component burning smell, it could be an overheating component,in both cases you should have it checked by a professional technician.Hope this will help you. Good Luck.
Posted on Sep 06, 2011
Why Kenmore microwave oven (model 80089700) start/enter button not working while all other buttons works fine?
Safety system locking out the start switch. Door not closed, mode and timer not set etc.
Apr 10, 2017 | Kenmore Microwave Ovens
My Whirlpool microwave model MH6130XEB-1 made a pop noise and now will no longer heat food. Everything else works fine, clock, timer, fan, turn table, etc. Is this a fuse problem?
It can be the fuse supplying the magnetron, or the magnetron itself which has failed. Another suspect is the high voltage capacitor in this circuit.
Don't try to fix this yourself as the internals of a microwave are dangerous, with high voltages even when unplugged.
Aug 27, 2013 | Microwave Ovens
Whirlpool microwave
    • 1 Press the "Clock Set/Start" or "Clock" button on the control panel.
    • 2 Enter the time of day using the number pad, or use the "+" and "-" buttons to scroll to the correct time.
    • 3 Press the "Clock Set/Start" or "Clock" button once again to save the time.
Apr 11, 2012 | Microwave Ovens
My microwave oven stopped working. No lights, clocks etc. I have checked the outlet and it is fine, power available. Is there a fuse somewhere inside the microwave?
There is a main fuse in the microwave oven, "white body with silver ends" located near the high voltage capacitor. Unplug unit take top off and allow 30 seconds to dis-charge. Keep in mind the door switch becomes defective and often blows the fuse.
Mar 15, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
At
William E. Miller
prototech@usa.net
Oct 09, 2009 | Whirlpool MH1140XM Microwave Oven
Our MH7130eq microwave will not start after pushing the start button on The clock, timer, hood fan works, however the micro will not start
Check the door safety switches . remove the cover ... look on the right side near the top. Just because they sound like they are working doesnt mean they are working. Sheck them with an ohm meter or other contunity tester.
Door switches are the most common reason for microwave failure.
Sep 07, 2009 | Whirlpool Microwave Ovens
Smoke bellowing out the top of microwave
hi my name is mark, sounds like you burned up the high voltage transformer or the fan motor. or the transformer for the control board. if oven cycles but does not heat its the HV transformer. hope this helped. thanks for your question.
Mar 18, 2009 | Jenn-Air JMC8130DD Microwave Oven
Power went off for about 2 seconds. when power came on, the clock was still running but touching each and every other button brought no result. cannot change the clock, or use the microwave at all.
the next day, i tried the microwave again and it worked fine. don't know what caused the problem other than the power outage - we have quite a few of them.
Jul 21, 2008 | Whirlpool Microwave Ovens
Complete functioning control panel but nothing works.
This is a problem with the control panel assembly, which we repair nationwide for $32.50 postpaid. Sometimes the bulbs short when they fail, and that damages the control board. This also can happen when bulbs are removed or installed without first unlugging the oven or turning off the breaker. For critical safety & disassembly info and other details of our service, see http://tinyurl.com/yzjozk
Jan 16, 2007 | Whirlpool MH1140XM Microwave Oven
Whirlpool MH1140XM Microwave Oven Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
