Question about Garden
Oil comes out of the bell housing when the tractor is shut off
    Problem Solver:
  • 9 Answers
Its most likely the rear seal is out [bad] on the engine causing leakage.
Posted on Apr 20, 2013
Smoke coming from bell housing
Clutch or automatic? The rear engine crank seal is most likely leaking. Oil on the clutch will ruin it completely, even the metal parts, so replace the whole thing. If it's an automatic, the oil is dripping on the flywheel which gets hot normally. No damage . Use a solvent to clean the oil from inside the bell housing after you replace the seal.
Sep 24, 2014 | Cars & Trucks
I have a 1993 polaris 350l. I found oil in my starter when cleaning it because the bench test failed. Why and where is the oil coming from?
the starter is open at the pinion end inside the bell housing so the oil can come from a leaking rear main seal on the crankshaft or from the transmission front seal. Because fluids are thrown out from a spinning surface then any oil in the bell housing will be flung out and if the starter pinion opening is facing upwards or slightly upwards then the oil will eventually find it's way into the starter
Apr 29, 2014 | Cars & Trucks
I have a 2003 Dodge Neon se there's a major oil leak between the engine and transmission how do I fix this
Check that the oil leak is not engine oil coming out before the bell housing ( sump gasket) If the oil is coming out of the bell housing inspection cover then it means box put and either flywheel off for a rear main seal or torque converter out for a seal in the box or converter.. If it is a sump or rear main seal check the engine oil level first and the PCV valve operation as excessive oil level and sump pressure will cause the engine side problems that you can fix without removing the box.
Mar 02, 2014 | Cars & Trucks
How do i remove the starter on my allison chalmers wd tractor
Isn't there just a tapered bolt that tightens into the bell housing & down into the starter housing, if I recall correctly.
Dec 04, 2010 | RTO Allis Chalmers W,wc,wd,wf,wd45 Tractor...
When the unit shuts down it blows about a quart of compressor oil out the bell housing. The shut down blead off sysrem doesn't appear to be working.
See if you can bleed the compressed air from the tank.Don,t forget to put oil to the motor.Start the machine for a few minutes.If still bleeding oil you need to overhaul the bell housing with new gaskets.I recommend to do the overhaul first but the test will troubleshoot both bleeders.
Dec 04, 2010 | Ingersoll Rand Compressors 5-HP,...
Won't pull itself up hill
You didn't indicate what model of tractor you have but most likely it is a hydrostatic drive problem . The power is transfered from the engine to the wheels by hydraulic pressure. If the fluid level (hydraulic oil) is low then it won't drive correctly. Follow the owners manual to check the fluid level. The other possibility is if this is an older unit it could actually have water in the oil.The water will not operate correctly. Where did the water come from? The transmission housing, is vented to atmosphere. On a hot humid day, while you're driving, the fluid and housing is heated. When the tractor cools, the ambient humid air enters the housing. When night rolls aroound the water condensing inside the housing. If you're lucky this transaxle may have a drain plug in the bottom. You can remove this and see if the oil looks milky. If it does, I'd drain it all and refill with fresh oil.
Jul 18, 2010 | Husqvarna 24HP 54" Yard Tractor ()
JD 2030 power steering failure
either the steering arm in the bell housing on the right side of the tractor is striped or the colume is broken internaly. the is asuming that all tie rod ends and the bell crank are still atatched.
Jun 16, 2009 | John Deere Tractor Side Screen...
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
