Question about E-Machines eMachines Desktop PC
Power button on e machine light turns yellowish orange
    Brigadier General:
  • E-Machines Master
  • 3,400 Answers
It's of the PCs powersettings and energysavings profile.
Posted on Apr 25, 2013
My photocopier machine Konica Minolta, when I power it on, the lights turn on, but the display screen does not, on the start button, the yellow light appears.
Sounds like the LCD or main board has blown a fuse. Look for a small fuse. This may require the machine to be opened up. Contact Konica customer services as this is a common fault with the c250 range
kindregards
Mar 07, 2015 | Konica Minolta Bizhub C253 Copier
Orange light trying charge
I would try this:
take the battery out
unplug the charger
turn upside down
hold power button down for 1 min
keep holding power button down as you turn over the laptop
while still holding power button down plug in charger and try to power on
Jan 26, 2014 | HP Computers & Internet
I just changed the ink in my canon iP90 printer and there is a light that flashes from green to a yellowish orange color and still wont print.. Can you please help me??
thake the power out.
hold your power and cancel button in
put power back
reless the cancel button but still hold the power in.
press cancel 2x
reless the power button
press cancel 4x
power unit off and on
Oct 18, 2011 | Canon PIXMA iP90 InkJet Printer
Hi i see you have some knowledge with tvs, and have read your responds to a vizio in a similar condition to mine.. here is the problem, out of the blue one day it does not turn on. However the...
Measure all the voltages present on the power supply board first. If they are all present and within 10% of the normal value, then the main board is suspect. The main board controls the power supply, but if a voltage is missing or out of specs it cannot function correctly.
Apr 15, 2017 | Televison & Video
How do i reset my pixma 1990 printer the ink receptacle is full message keeps on appearing?
To reset the printer follow these steps : 1. Turn off the printer and hold the "RESUME" button located on top of the MP220. While holding the "RESUME" button, press the "POWER" button and wait for the machine's green LED to illuminate.
2. Release the "RESUME" button while holding the "POWER" button. Press the "RESUME" button twice and release the "POWER" button.
3. Press the "RESUME" button four times followed by the "POWER" button. Turn the printer off and then on to complete the reset process.
As per your error follow the below mentioned steps :
1. Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2. While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3. While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4. When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5. Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6. Power off then check it.
In case if the problem persists please revert back.
May 22, 2011 | Office Equipment & Supplies
Hellow. The lights indicate trouble with the ink. I have replaced the ink and want to do a cleaning, but it only shows E and 5. I can not get the leter H or F for maintenance, and the machine does not...
Let me give you instructions to get to service mode.
With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
* When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
* When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
* When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print (auto teste)
2 times Green EEPROM print (dados da EEPROM)
3 times Orange EEPROM reset (EEPROM reset)
4 times Green Waste ink counter reset (Absorvente reset)
* Turn off the printer.( it must be turn off) then turn it on again.
Nov 14, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Replaced lamp now yellowish orange status light is flashing
Hi,did you close everything up,make sure door cover is closed.Do you hear clicking noises? If you do it could be an issue with the the ballast that the board that powers the lamp.Make sure fans are running ok,dust them out if they are dirty.Also reset lamp timer by unplugging tv wait 5 min and plug it back again.Good luck and God bless you!
Oct 07, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Gateway MT6451 Does not turn on
leaving your unit in standby mode is not a problem as long as your ac adapter is plugged in to your ac outlet and to your pc. otherwise, you will have a drained battery. try removing your battery for a few minutes and then insert it back in then plug your ac adapter to your wall outlet and to your pc and leave it without starting your pc. notice the small pilot light at front edge of your laptop, it should be yellowish/orange. wait until this light turns green then you can try turning on your pc.
Oct 23, 2008 | Gateway MT6451 Notebook
In March 2008, I bought a CANON printer "PIXMA MP210" series. But, only last week I was abled to errected and connected the printer to my Fujitsu Life Book # A6110 (lap top). When switching on the...
is there any error message appear at your laptop..? have you check the ink cartridge inside, and also the mechanical parts inside if there was a paper jam..
Jun 27, 2008 | Office Equipment & Supplies
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
