Question about Weller WH 40 SOLDERING IRON, FOR WHS 40/WHS 40D
Replacing Weller tip
Screw for removing tip is stuck. Where te have new tip replaced in South Africait re
I used the Iron for the first time fil him with wather, but te empty reservoir stay on flassing
if instructions are followed and the light stays on
if new return to place of purchase for refund on faulty iron
Mar 06, 2017 | Irons
Power steam elite boiler screw is stuck
Morphy Richards Power Steam Elite boiler screw
Mar 16, 2013 | Morphy Richards Irons
Power cord on rowenta dm991 is split- needs a new one- can I do this myself?
On the end of the iron there are 2 screws - remove them; on the bottom of the end there is a small slot - put a small screw driver in the slot and pull on the end; you will find the wire that goes into the iron - get a replacement from an iron shop and you are good to go!
Dec 14, 2010 | Rowenta Ultra Professional DM991 Iron
No power from cord. I want to replace the cord.
In replacing the cord, you have to remove the screw that holds the back cover and unscrew the damaged cord from the heater terminal. Insert the new cord on the rubber insulator and screw it to the heater terminal.
Nov 04, 2010 | Euro-Pro Shark GI490 Iron
How to open the back of iron. Has an irregular screw
these screws take a star tip screw driver to remove. My 6 month old Rowenta's switch quit. You can buy the star screw driver at any good hardware store or auto place.
Oct 13, 2010 | Rowenta DZ1700 Iron
Wont turn on
I agree.
It is probably a loose screw (if you shake the iron, you may hear it rattle).. The iron is most likely good, just needs a 5 minute repair.
If you want to do it, or find someone to do it:
1. UNPLUG the iron.
2. remove the 4 screws from the back end of the iron.
3. Open the back plastic plate.
4. There will be a wire with a loose screw; tighten it.
5. There may be a broken wire near the screw; if so, remove the eyelet that is on the screw. put the screw back on and wrap the broken wire end onto the screw and tighten.
6. Replace the back plate.
7. Plug back in and use for a few more years.
Hope this helps!
Sep 04, 2009 | Rowenta Power Duo Iron
Sewing machine keeps skipping stitches
Generally, it means that the bobbin is too tight in the cavity.
1. Remove the bobbin
2. Try a drop of oil in the bobbin cavity in the machine, using a Q-TIP
3. After applying the oil, use a clean Q-TIP to remove excess oil in the cavity (may need more than one clean Q-TIP).
4. Replace bobbin.
(I'm sure you already tried differenty thread)
Hope this helps!
Sep 01, 2009 | Kenmore Irons
Morphy richards comfigrip 40715 how to disassemble?
Phil - I have the same problem. Can't see how to dismantle it at all. Did you ever get a solution?
Thanks
Chris
Aug 08, 2009 | Black & Decker AS975 Iron
Rowenta Iron
Special screw called "Torx tamper proof" call 925 8271011 and order "Rowenta tool" $10.00 plus shipping-this place also sells Rowenta parts
Apr 09, 2007 | Rowenta Professional DX8800 Iron
Weller WH 40 SOLDERING IRON, FOR WHS 40/WHS 40D Logo
66 people viewed this question
Top Weller Irons Experts
Are you a Weller Iron Expert? Answer questions, earn points and help others
