Question about Craftsman Convertible 32cc Gas Line Trimmer - POULAN/WEED EATER
Too Much fuel? Wet under tank, Spark arrestor wet, spark plug wet.
My trimmer start fine when i replaced the spark plug. The old one looked black. I was trying to adjust idle and the trimmer died and would not start again. Under the fuel tank, outside of carb, spark arrestor plate are all wet. Unit will briefly start after the spark plug is taken out and cleaned, but it will not run continually. Is only solution to replace carb? could this be the only problem? Carbs are $75, if any more i will just buy a new one.
5 Suggested Answers
  • 20 Answers
SOURCE: Craftsman Wee trimmer will only run when tilted on its side.
its your flaot in your little carb
Posted on Mar 24, 2009
  • 85 Answers
SOURCE: Sears weedwacker won't start 358.797150
Plug could be fouled. Make sure you have fresh fuel mix.
Posted on Aug 19, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Mini-tiller stopped running, cleaned the
Sounds like you will need to replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to seat the jet screws.
But before you seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
vincob
  • 718 Answers
SOURCE: I have a craftsman 32cc weedwacker gas trimmer,
No more Mr. nice guy. But it sounds like your just out of adjustment, try readjusting your high idle screw. Good Luck..
Posted on Apr 03, 2011
Won't start, gas out of exhaust
Sounds like its flooded : excess fuel / wet spark plug.
Empty tank / Clean and dry spark plug. test plug for spark before refitting. If strong spark refit plug / and see if fires when turn engine over.
If it does then refill tank with new clean fuel and attempt to start without choke to avoid flooding.
May 25, 2016 | Toro Garden
I have a hasqvarna 125 b I have put new starting coil on it,new fuel lines, rebuilt carb, new primer pump, new plug. It is getting spark, the plug is wet, but it still won't start.
Check your muffler's spark arrestor screen for clogging. Also test your compression. It needs to be be at least 100 psi for the engine to start.
Apr 24, 2015 | Garden
My still fs 160 not sarting but sparg plug wet
Check spark arrestor and check compression If spark arrestor clean and compression low check for struck ring(s) or cylinder damage. This can done by removing muffler and looking through the exhaust port.
Dec 20, 2014 | Garden
Troy built weedwacker wont start
Try draining the fuel and re filling with fresh, if no better, does it have a spark at the plug? does the plug get wet with fuel? if not try replacing the fuel filter in the fuel tank.
Feb 16, 2012 | Garden
Won't run but it starts. Replaced the spark plug, new fuel. cleaned out the lines. tokk the carb apart blew it out it looked fine.
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 26, 2010 | Troy Bilt Tb70ss Gas Trimmer
32cc crafstman weedwhacker (2 yrs old)flooding wont start
Nope, it's not the carb. The plug is wet and probably black as well. Wet plug and lots of smoke means too much oil in the mix which is where the problem lies. Get a compression tester and look at the pressure reading; anything less than 90psi means the piston ring is stuck and needs to be replaced/cleaned.
Oct 07, 2009 | Garden
I am able to crank the trimmer but it does not stay on. in the past it worked just fine but sat unused for roughly 4 months and now this. we own a TB425cs string trimmer. how do i fix this issue?
1) Change out the old fuel (not just adding fresh but pouring out the old and replacing it entirely) and check the engine oil.
2) Check muffler and/or spark arrestor screen for restrictions.
3) Clean and reinstall spark plug (check gap).
4) Replace inlet screen INSIDE the carb. (It is located directly under the inlet needle.)
Try each of these as needed.
Hope this helps!
Oct 01, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Won't start
If the plug is wet, have you checked to see if you are getting spark? I will assume (something I hate to do) for the sake of argument, that you do have spark. If you have gas and spark then the next place I would check would be the spark arrestor/exhaust port. Make sure it is clear of carbon build-up. It has to be some sort of compression problem, I would think, and that would be a place to start. Hope this helped and let me know how it goes! Best wishes.
Sep 10, 2009 | Garden
2 Cycle Gas Trimmer will not start
it is normal to see air bubbles in line when pumping the bulb. to make sure what the problem is, try starting several times, remove spark plug. if dry, yes no fuel, remove the carb. if wet, place plug on engine block and look for blue spark. no spark means you need new plug, plug cord or ignition module
Jul 24, 2009 | Ryobi Factory Reconditioned 18" 40cc...
My Echo GT-200R will not start. The plug is clean and wet. The switch is "On". Fuel (50:1) is new. It was working 2 weeks ago. Thanks, Chuck My echo gt-200r will start and idle but any time you push...
Try cleaning the screen that is located behind the spark arrestor screen cover. This is located on the muffler. Soak it with gasoline and clean it with a wire brush.
May 29, 2009 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
Craftsman Convertible 32cc Gas Line Trimmer - POULAN/WEED EATER Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
