By Pass Tray
The By Pass tray is closed but the photocopier still wants to take paper from it instead of from the other trays. We get a mishandled paper message.
  • 145 Answers
Sound like you have it set as a defauld.you should be able to change its in your user setting...
Posted on Mar 18, 2009
I have WC 7535 when I give print or copy from tray 2,3 & 4 printer showing paper jam in tray module
Look carefully on the left hand side. All the paper from those trays pass up the left. ( you probably know that) The last time I worked on one of those machines paper feeding up from those trays can get stuck you've got to investigate where the paper is stuck coming up from the trays. Open the left door and very carefully see how far the media has traveled, does the lead edge get damaged, dented or spoiled in any way. ( look closely there) don't just rip out the paper, investigate why. Just how far has the media moved from the tray selected. I suspect a torn bit of paper stuck inside. If your machine is difficult to get to you must make room to look properly with a torch if necessary. Pull out trays 1 & 2 fully so you can look without being hindered. Good look!
Jan 12, 2015 | Xerox Office Equipment & Supplies
Paper jam in tray one after receiving every photocopy in kyocera fs6525 wht's a problem ???
First make sure that tray is set up for correct paper size. That would be first thing. Check for paper dust in paper path blow it out. Really sounds like paper tray not set correctly.
Feb 23, 2014 | Kyocera Fs-6525mfp Copier, Printer,...
How to reset paper tray in Richo Aficio 2045e photocopier
Verify the paper blocated under tray or the paper tray actuators.
Jan 04, 2012 | Office Equipment & Supplies
I have a Panasonic Workio 1820 photocopier and I can't get it to copy A3 size documents. I have set the copy size to A3 but it will only copy and print an A4 portion of the document.
from where are u using the A3 paper . if ur using the drawer then simply select the original size and copy size as per ur requirement and first change the tray paper size to A3 in operator settings. if ur using by pass tray then be sure to pull the entire tray out as there is a sensor in the last end of the tray that senses A3 and legal paper
Aug 23, 2011 | Panasonic Office Equipment & Supplies
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
My photocopier sharp z810 is not accepting paper.how do i rectify the fault or problem.i need a solution please.
if there is paper in the paper tray but the machine still says no paper, then the paper end sensor is broken in the tray. take the paper tray out and you will be able to see a sensor on top. when the tray is fitted the sensor is on top of the paper. the paper lifts the sensor to activate. i am a photocopier technician.
Oct 01, 2010 | Sharp Office Equipment & Supplies
I have a brother MFC-9440cn printer. The printer is telling me to load paper in the MP load. I need to use the tray instead of the MP load. How do I go about doing this?
When you ready to print your computer.please go to print properties setting paper source default or tray 1 or MP.MP mean multi pass tray.I mean front paper loading tray.
Jan 14, 2010 | Brother MFC-9440CN Laser Printer
Can this printer automatically choose the paper tray i.e. if the MP tray is open will it choose that instead of the cassette?
MP tray needs to be set on FIRST*
When paper is in MP tray, thats where the printer will automatically take it from. When there is no paper in the MP tray, or it is closed, the printer will take from the cassette.
Apr 09, 2009 | HP LaserJet 4 plus Printer
Hi i have problems with my 7502 gestetner nrg photocopier
This sounds like a paper size issue. Check your papersize and oriontation in the tray(green selector font right or back left of tray) and check paper settings under the user tools menu for tray 1. let me know if that works, so we can trouble shoot.
Feb 23, 2009 | Gestetner DSm618 All-In-One Printer
37 people viewed this question
jasbo
jasbo
