Question about Estate Washing Machines
Can not find the lid switch
Where is the lid switch located on my wash
  • Estate Master
  • 2,344 Answers
Your lid switch should be visible, around one of the 4 sides of the lid. It will not be on the lid itself, it will be on the "top" of the machine.
You must open the top to get to the switch.
One kind of machine has a tiny white button at the back of the machine, right near the control panel.
To be sure, although I don't remember seeing one, it is even possible your switch is hooked to the hinge of the lid inside the top so you can not see it without raising the top.
Be blessed.
Posted on Apr 21, 2013
How do I find the lid sensor switch on a Kenmore 500 washing machine
If the washing machine stops in the middle of the cycle then it is very unlikely the lid switch is involved. It could be a number of reasons.
Best to drain the washing machine and repeat the cycle a few times to check if it happens at the same point. Could be a problem with the timer or pressure switch.
You can locate all the parts and their location in this site. I hope I have the correct model for your washing machine.
KENMORE Residential Washer Parts Model 11029522800
Aug 05, 2014 | Kenmore 500 3.5 cu. ft. Top-Load Washing...
I have Whirlpool washer from about 1994, model LLR8233BWO, serial CD4350912. ALl of a sudden it would stop in the middle od a cycle, full of water, loandry. What can I do about it?
Check your lid switch. The most common cause of the symptoms you describe is a lid switch malfunction. Symptoms include, filling and stopping on the intial fill, stopping right after the wash cycle, failing to advance to the rinse cycle and no draining.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30. Prices differ between sites so shop and compare.
If you have questions, need additional assistance, please post back with your complete model number (located on a nameplate along the wash tub rim under the lid) and let me know. I hope this helps you.
Feb 26, 2010 | Washing Machines
My kenmore series 90 washing machne will not engauge the spin cycle..any ideas??
The most common cause of the symptoms you describe is a lid switch malfunction. Symptoms include, filling and stopping on the intial fill cycle, wash tub will not drain and/or the washer will still agitate in some cases, but will stop right after the wash cycle and fail to advance to rinse or spin cycles.
repairclinic.com
Feb 24, 2010 | Kenmore Washing Machines
Have series 80 washing machine. It filled with water but will not turn on
The most common cause of the symptoms you describe is a lid switch malfunction. Symptoms include, filling and stopping on the intial fill cycle, stopping after the wash cycle, failing to advance to the rinse cycle and no draining.
repairclinic.com
Kenmore 80 series washing machine toploader - washes but does not spin or drain - water stays in it
repairclinic.com
If you have questions, need additional assistance, please post back with your model number (located on a nameplate along the wash tub opening under the washer lid), so I can provide you with better assistance. I hope this helps you.
Jan 30, 2010 | Washing Machines
My whirlpool washing machine is getting stuck in the wash cylcle right before it is to drain
Check your lid switch. If the washer fills and agitates, but stops at the rinse cycle, or, if the washer fills, then stops and will NOT drain, this is a common symptom of a lid switch malfunction. The following link explains how to access and/or replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and there will be no small hole on the right hand side of the wash tub. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
repairclinic.com
The average price is about $20 - $30. Prices differ between these sites, so shop around for the best deal.
This is a very simple repair, but if you have questions, please post back with a complete model number (usually located around the wash tub rim under the lid) so that I may be able to provide you with better assistance. I hope this helps you.
NOTE: You do not need to drain the washer to replace the switch.
Nov 17, 2009 | Washing Machines
Washer stopped middle of cycle, have tested power into motor still supplied
Check your lid switch. The most common cause of the symptoms you describe is a lid switch malfunction. Symptoms include, filling and stopping on the intial fill cycle, stopping after the wash cycle, failing to advance to the rinse cycle and no draining.
repairclinic.com
Mar 16, 2009 | Whirlpool LSQ8000 Top Load Washer
Washing Machines Logo
27 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
