Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Bissell proheat snags on carpet
Can not go forward, only backwards. carpet snags on window suction plastic forward of the brish
  • Official Brand Answer
  • 315 Answers
Hi Richardad229. The front clear window nozzle(s) may be off alignment and can be re-aligned quite easily.
Here's a link to the instructions: http://www.bissell.com/FAQDetail.aspx?id=1212&cid=ccsocial
Posted on Apr 25, 2013
SOURCE: schematic parts diagram for bissell proheat 9200 carpet cleaner
http://www.nelsonappliance.com/bissell+proheat2x+parts.asp
hopes this helps, they also have parts, but shop around.
Posted on Jan 08, 2009
SOURCE: loss of suction bissell vacume
Under the red flap in the water resevoir, there is a small screen. Pop that screen out and clean it. It is probably blocked with hair. I took my entire machine apart trying to fix this problem and I finally saw that screen. I cleaned it out and my machine works like new now.
Posted on Mar 10, 2009
SOURCE: bissel proheat 2x main suction problems
bissel pro heat x2 does not suction up the cleaning fluid
Posted on Sep 09, 2009
  • 10 Answers
SOURCE: bissell proheat 7 will not spray water or cleaner
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! g
Posted on Sep 26, 2009
SOURCE: Repair manual for Bissell 2X ProHeat 9200 Carpet cleaner
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000074560.pdf
Bissell Manual
Posted on Feb 24, 2010
When the shampooer is moved forward to initially to spray the shampoo the plastic guard on the front drags the floor and keeps it from moving forward and shampooing. .
The one's I've used the sprayer is on the back of the suction (suction hood which is kind of clear plastic), you watch that clear part to see if it is picking up dirty water. Recall it's easier to pull it and if caught just push down on handles and that raises front of machine to clear carpet snag. I would walk backward as it sprayed and then picked up the water with dirt. If different machine you could spray moving backward, go back to same starting point go again and don't spray but just hold it near carpet so it picks up the water.
Jun 03, 2016 | Bissell ProHeat Pet Upright Deep Cleaner,...
The suction on my dyson is too strong
i don*t know alot about dyson but if it has a thing to raise it up off the floor then that will work
Jan 26, 2013 | Dyson Vacuum Dc 14 Low Reach
Dyson DC08 turbo brush won't turn but have suction in tube
Hi Cathy,
I'm sorry to hear you're having difficulties with your DC08's turbo brush. As you've already checked the machine for blockages and washed the filter, I'd encourage you to get in touch with us directly so we can provide further assistance to help resolve this.
You can call us on 0800 298 0298 - our UK Helpline is available from 7am until 10pm, 7 days a week. It will help if you have the machine to hand when you call.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 26, 2012 | Dyson DC08 Hepa Allergy Bagless Canister...
We just installed new plush carpet and my Dyson Animal will not push forward in it. I can pull it backward but, no way can I push it. The front end seems to just dig in. It is terrible. It is a DC...
I'm sorry to hear you're having difficulties using your DC14 on this particular carpet. We'd strongly advise contacting your carpet manufacturer to check it's suitable for cleaning with a vacuum cleaner equipped with a revolving brush. Manufacturers sometimes recommend cleaning certain types of plush-pile carpeting using suction only.
If you have any further queries about using or maintaining your Dyson vacuum cleaner, please get in touch with us directly. One of our experts will be happy to provide the information and assistance you need. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Jun 09, 2011 | Dyson DC14 All floors Bagless Upright...
Bissell Power Steamer Pro Deluxe will not move forward
tip unit back to lift brushes off floor and roll forward until over carpet edge. tip back unit to sit flush on carpet and unlock handle so it swings freely. now pull backwards ith finger on spray trigger. that's how it works, not by pushing forwad.
May 16, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Shark navigator n22
What I tried and it worked for me is to losen the hose slightly from where it connects to the long plastic tube on the side to allow the little hole to show. What that does is to lessen the suction power a little since the problem is that the suction is too powerful on the carpet and the roller freezes.
Apr 24, 2010 | Euro-Pro NV22 Shark Navigator Bagless...
My Bissell Dirtlifter Powerbrush carpet cleaner will not roll. The back wheels roll fine, but when you put the machine down flat, the front part (where the roller is) sticks and will not roll.
I had the same problem. It would pull backwards but not go forward. A closer examination revealed the clear plastic part on the bottom in the very front of the machine had popped loose on one side.
If you look at the front of the machine, there is the clear plastic part on top where you see the dirty water being sucked up. The bottom half that creates the channel for the vacuum is where it came loose. It wouldn't create enough suction to draw the water up either. By taking out the two screws that hold the top part in place and removing it, I was able to snap the bottom back in. Works fine now. Hope this helps.
Apr 14, 2009 | Vacuums
Bissell carpet cleaner does not have suction like it should
Try checking the lint filter. It is located in the top clear plastic section (the one with the dial to switch from floor to tool use) and is on the underside. It is a small (1 inch square) red plastic filter with a door on it. Flip open the door and it is probably clogged with hair, carpet fibre, etc.. Clean it out and you should have full suction once again.
Mar 16, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Wheels won't engage
Sounds like the outer window noozle isn't seated with the inner window. Take out the two screws, one on each side, remove the window, inspect the other half moon window to make sure it is ok, then reinstall the outer window(don't forget the gasket that sits on top of this window)Try to see if you still have a problem.
Jan 10, 2008 | Bissell 1699 ProHeat Clear View Upright...
DC07 Very difficult to push forward.
on the front of the base there are 3 very small rollers made out of rubber, these are either just dry and won't turn or worn and or damaged,
that is your problem / honest its that simple
Oct 13, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
166 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
