Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
LDF6810ST/01 no water
Hello, i have ldf6810st/01LG dishwasher and i started to have really weird issue with it. I turn it on, motor that pumps out excessive water from the machine starts, then it will not turn off and keeps on going and going for about 10 min, then machine turns off. Water never starts to go to machine. No error code on display.
  • 192 Answers
The pump out motor starts because it detects some water leak and is a safety switch on a polystyrene float. Find the cause of the water leak (hose or hose clamp) dry the water and this should solve your problem
Posted on Jul 07, 2013
  • 489 Answers
SOURCE: Door leak in LG LDF6810ST Built-in Dishwasher
Your drying vent tube is probably leaking inside the door panel.  Remove the outer front panel and on the top left side, there is long white plastic tube connected to the dryer fan assembly.  In that connection is where the problem is.  You will need to disassemble the fan from the door, disconnect the tube from the fan, clean out the water and debris and use silicone when reassembling the tube to the fan.
Posted on Jun 08, 2008
SOURCE: LG Dishwasher Model LDF6810ST Dishwasher won't turn on
your model probably has a coating of a black tar-like substance on the inside of the inner door, which, by design, reduces noise. However, LG failed to notice the corrosive properties of the black tar-like layer. Your wiring harness is probably corroded by the soundproofing, and you will need a new inner door, wiring harness, and circuit board. LG extended my parts warranty because they know it's their fault, Call them at 1-800-243-0000. They will recommend an LG warranty repair certified technician in your area to come out and confirm this. They probably won't extend the warranty until after the tech checks out ur unit. However, labor will be your responsibility.
Posted on Dec 27, 2008
  • 423 Answers
SOURCE: LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Posted on Mar 30, 2009
  • 423 Answers
SOURCE: lg LDF6810ST dishwasher not cleaning top rack
Almost all of the problems mentioned above will be solved by having the owner buy a name brand detergent powder (like Electrosol or Cascade) and using a little less than you think you should.
For those who continue to have problems with poor cleaning, you need to remove the lower spray arm (pull straight up firmly, then out) and then remove the 9 screws that hold the filter in. Using a flashlight, inspect everywhere in the sump area (be careful of broken glass!) Remove all debris and especially look for something blocking the white check valve that is driven by the Vario motor to control the alternation between the upper sprayer arms and the lower arm. Reasemble and test.
If inside dishwasher is a mess with white mineral deposits, recommend you place a bowl filled with white vinegar on the rack of your empty DW. Start a quick cycle with no detergent added.
Check out how clean it is when you are done!
If you have problems after this, please post back what you are seeing.
Good Luck!
Posted on Apr 08, 2009
  • 3230 Answers
SOURCE: Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Posted on May 06, 2009
Error meaasage 0E Drain Error what to do?
This OE error or fault code indicates that the machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Finally, if the drain line is clear and the pump seems to be clear, you may need to replace the drain pump assembly.
Mar 01, 2016 | LG 4681EA2001D Original Water Pump Drain...
Lg tromm washer
The DE or DOE (Door open error) error or fault code indicates that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
Aug 22, 2014 | LG 4681EA2001D Original Water Pump Drain...
LDF6810ST/01 no power.
see this causes:
Power from the house
reset the c.breaker or blown fuse replace
Door switch
test for open or defective, since this is not o.k will not close the relais for start the m.motor see the diagram
Wiring
test for open, loose, broken, or burn wires
Timer or selector switch
test for open, defective, or dirty contact, clean, and tight
Jun 18, 2012 | LG LDF6810ST Stainless Steel Built-in...
What is the Thermistor on my LG Dishwasher LDF6810ST?
It is the Sensor attached to the Water heating compartment (Element) on the Dishwasher.
It is attached to the Circulation pump.
See below image (It is the part in BLUE)
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively. A 4 four thumbs up will do nicely too :-)
Apr 08, 2011 | LG LDF6810ST Stainless Steel Built-in...
Dishwasher arms do not spin
It sounds like your wash motor has failed to run at full speed to pump the water through the spray arms. The computer board will eventually report an "LE" error code for the motor's issue.
Jul 25, 2010 | LG LDF6810ST Stainless Steel Built-in...
No water coming in
check inlet water free flow. Check strainer at the inlet. check whether motor is running.
Apr 30, 2010 | LG LDF6810ST Stainless Steel Built-in...
LG LDF6810ST Dishwasher - LE Error
If this LG LFD6810 dishwasher is less than 24 months old, the parts are still covered, just not the labor.
Recommend you contact LG service and discuss your failed wash motor.
And yes, because the impeller (and the motor it is connected to) does not spin freely, it is the culprit.
Good Luck!
Apr 10, 2009 | LG LDF6810ST Stainless Steel Built-in...
2H accures in digital read out. NO Cycles start, just a humming
Do you own an LG LDF6810ST dishwasher? If not, please reply with the manufacturer name, model and serial number.
Are you saying that the display that normally shows the time is displaying an code of 2H? On an LG, that means 2 Hours, (120 minutes) and is not an error code.
On an LG with a symptom like this, I would arrage to replace the main processor card (PCB). You would be getting an error message if the motor (wash or drain) had failed.
Mar 30, 2009 | LG LDF6810ST Stainless Steel Built-in...
Steps to fix OE are as follows:
-Check the Drain Hose is not kinked or blocked.
-Are all wiring connections OK?
-The drain outlet of sump is blocked.
-The Drain Pump/Motor or circuit has failed.
To check the pump motor: -Measure the electric resistance of Drain Motor. (best between 20-40 ohms) If out of range, replace the Drain Motor or repair the Circuit.
Good Luck! Please report back your findings.
Feb 14, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG dishwasher model #LDF6810ST doesn't DRY DISHES.
ok ...first the average dishwasher will only heat the water 1 degree per mintue,,,now if your starting out with very cold water the dishes will never get clean check your water temp,,at start up..if you have 90 to a 100 degrees thats ok..that means we have problem in heater circuit...also turn up your jet dry level...keep me posted onthejob,,incase we have to look at heater circuit
Dec 31, 2008 | LG LDF6810ST Stainless Steel Built-in...
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
155 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
