Phase linear uv8=jensen brake bypass code
My player will not play any cd i put in the player. it always say bad disc.
  • 523 Answers
Buy dvd cleaner disk , load it so it clean the lens of your DvD and you will be fine.
Best Regards
Posted on Mar 11, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
Please use a lense cleaning disk to clean the lens of your Player.
How do i override the emergency brake with remote to uv8
Look for dvd hack for that model. I see some on ebay
Jan 05, 2010 | Jensen VM9510 Car DVD Player
Jensen uv8 bypass code didn't work
no the code should work . unless jensen put a stop to the code in the newer modles.
Jan 19, 2009 | Jensen VM9510 Car DVD Player
The UV8 needs to use The Pink wiere to play an CD audio?
I got through to tech support. For problem of no audio from DVD or CD (can only hear radio), reverse the Blue wire (power antenna) and the Blue/White wire (external power amplifier). This should solve the problem.
Nov 26, 2008 | Jensen VM9510 Car DVD Player
My phase linear uv8
Hi
The Laser Diode inside the UV8 that reads the DVD media is most likely set too weak for the amount of dust built up in over time. This dust block the laser optics and causes the player to not read DVD's. You will want to go get a bottle of air from Radio shack and blow the DVD player out. The reason it is reading CD's is that its laser diode may be set stronger and is able to break through the dust. There are two Laser Diodes, one for CD, and one for DVD. Good luck. www.PlaystationClinic.com
Sep 04, 2008 | Jensen VM9510 Car DVD Player
Phase linear uv8 parking brake problem
for the uv8 to bypass the parking brake to watch dvds you have to take the pink wire and put one end to one of the screws on a two screw toggle switch connect the other end of the pink wire to the other screw and connect that to the black ground wire
Mar 12, 2008 | Phase Linear UDV9010 Car DVD Player
Phase Linear UV8
I have same problem with same uv8 but i use remote to activate am/fm then hit setup on rem.enter 543210 and a new menu came up. ( listening for the beep after each 3 is pressed ) select the hammer in upper left hand corner of screen, select brake bypass to on, then hot the X near bottom os screen. this works for me it should work for you.
Jan 11, 2008 | Jensen VM9510 Car DVD Player
Jensen in dash dvd monitors
jensen double din dvd monitor it a uv8020 model to bypass the e brake or parking brake
Dec 19, 2007 | Jensen VM9510 Car DVD Player
Pixelated picture
jensen is not such a great brand for indash. if you have the receipt or warranty you might want to return it and get yourself a new one. I know this because when i bought my phase linear i didnt want to eject the cd and the guy told me that they come very defective sometimes
Dec 07, 2007 | Car Audio & Video
from remote setup, 5 4 3 2 1 0(hold "0" for 4 seconds) let go. look for the brake override option and turn it on.
Nov 16, 2007 | Televison & Video
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
