Question about LG Z42PJ240 42 in. Zenith Plasma TV
LG 42" Zenith Plasma TV Z42PJ240 failed capacitor help
I have an LG made Zentih Z42PJ240 plasma set that I purchased used as having no picture. I opened the set expecting to find bulging caps on the PS or Y sustain board - but there were none. Brought up the set, and it worked, excellent video, for a little over 30 minutes - then protection shut it down. Noted some warm caps on the PS board, but not hot like there was a major current draw issue. Used component cooler on heat sinks and caps.. eventually the set came on and has run for hours without a shutdown. I suspect a cap is beginning to fail - but I hate "hanging parts" outside of preventative work, yet I also can't see pulling caps and testing them one by one. Yet at the same time, I see LG used very low-grade caps throughout. I am keeping this set, so I have the time to flush out the problem. What would you do? Replace, or at least pull/test caps that were warm - or just replace questionable junk with good grade parts?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 36 Answers
You maybe have problem with smd resistors on PSU around 380v capacitor they are ned to re- solder it is on the circiut where is made this voltage -380v in primary
Posted on Mar 09, 2017
  • 13 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
This is almost certainly the device that sends electricity to the the plasma in the panel after failing. Bring to your local repair shop and expect to pay 300-400 parts and 100-200 labour.
Cheers,
Stephen
Posted on Apr 28, 2009
maatmartin7
  • 1213 Answers
SOURCE: I have a 42 LG Plasma TV with a broken screen
NO....You must pay attention to all numbers on the back of the TV. Verify these with your tech or contact your LG customer support for the correct board numbers. If the screen was broken I doubt if you can repair this for less than it cost to replace. The screen for this one runs at about $650.00. Good Luck and good advice!
Posted on Oct 01, 2009
  • 380 Answers
SOURCE: LG 42 Plasma try's to turn on but just goes back into "stanby" ?
Check to see if you get Va and Vs voltages from the power supply. There should be some wires running to the y-sus. A couple of those wires will be labeled va and vs. Are they present? There will be a sticker stuck to the panel somewhere telling you what they should be.
Posted on Mar 26, 2010
SOURCE: TV has no display -- Need advice on Z Sustain Assembly Board
Send your board for repair / exchange - we service those by truckload :-)
http://www.coppelltvrepair.com .
Posted on Apr 05, 2010
  • 8457 Answers
SOURCE: hello....I have a LG 42" plasma tv model #
Replaced the X sus board too.That the other board,that also have a problems.
Posted on Nov 26, 2010
What might the problem be on a zenith tv
video control board remove back panel and look for bad capacitors
Mar 25, 2015 | LG Z42PJ240 42 in. Zenith Plasma TV
I have a Z42PJ240 42 in. Zenith Plasma television I canno.v.t find anywhere to manually power on the t
hi the power button might be underneath the tv or a touch screen panel
regards
shaun
Apr 21, 2014 | LG Z42PJ240 42 in. Zenith Plasma TV
Just install a new 42"
Can you please describe the problem with a little bit more detail? Are you saying that the pictures are coming up with a ghost effect? When the pictures are freezing what exactly do you mean, as in when changing inputs you can still see the picture there but gradually goes away?
Jan 10, 2011 | Zenith Televison & Video
My LG Plasma 42PC3D turns on and off repeatedly. I turn on my FIOS set top box first and than the TV and it turns on and off repeatedly (front bottom display goes red and green, red and green repeatedly)....
Your plasma TV has a power supply 6709900019A. These power supplies failed due to defective capacitors. See the picture below and check the capacitors mark with the red lines. There are 10 capacitors that should be replaced even if they do not show signs of bulging/swelling on top.
The value of the capacitors is 3300uF/10V but you can use 25 volts as long as they fit in the space provided by design.
Sep 24, 2010 | LG 42PC3D 42 in. Plasma Television
Dark and snowy Screen on my Zenith Plasma
Https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Oct 16, 2017 | Zenith P42W46X 42 in. Plasma EDTV
If you paid by cheque or credit card, that is your proof of purchase.
Mar 09, 2017 | LG 50PG6000 50 in. HD-Ready Plasma TV
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Feb 24, 2009 | LG 42LC3R 42 in. LCD TV
Zenith zsus pop
Hello to all! Some of the time with LG type Y & Z sustain boards you must replace both the boards in order to completely the repair or but not always. Please feel free to message or call me if you need more help with your Zenith plasma TV. 1-503-432-9904 / pleasefixitdave@yahoo.com Ask for Dave! If you are reading this post and you need help with a plasma or LCD type TV give me a call!
Dec 20, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
LG Z42PJ240 42 in. Zenith Plasma TV Logo
101 people viewed this question
Computer Repairing
Computer Repairing
