Question about Panasonic PV-GS31 Mini DV Digital Camcorder
Thick Blue Lines
I just came into a problem that when I playback a tape I get thick blue lines. I just bought the camcorder two years ago and it should not be broken. I took back to the store where I purchased it and they told me it was shot. Please someone help. I don't want to accept that it is broken. I have tried two of three of the previous solutions, but what is a dirty head and how do I fix it? Restarting the camera didn't work. Thanks!
  • 169 Answers
Just forward a blank new tape...5 times if needeed i suggest not to use a video head cleaner..just imagine using a sand paper to the head what will happen..:-)
Posted on Aug 09, 2007
Had similair problem with other brand of DV camera, Thanks to x-tian for his suggestion. Wasn't sure if he meant to Fast-foward in playback mode or just Fast- forward in rapid search(No picture) I tried both..... After a couple of passes - the playback was normal!!!! matt
Posted on Sep 17, 2007
This was the fix for my problem,,,thx! I thought I had lost a whole tapes worth of video of my son.
You were a life saver.
Colin.
Posted on Dec 27, 2007
Thanks it helped
Posted on Dec 16, 2007
Hi I went with x-tian idea. Thanks you saved my life,worked a charm
Posted on Sep 06, 2007
The solution I found, in some tapes I have, is to move the "save protection" tap to the "allow recording" position, this solves the blues lines in my Panasonic PV-GS12 Hope it helps Oliver
Posted on Sep 03, 2007
SOURCE:
Grey lines during playback.
Camcorder video head required cleaning because gray lines come in playback when video head got clogged/ dirty.
Put video head cleaning tape and playback it as per instructions.
hope this will help you.
Thanks.
Apr 03, 2010 | Sony DCR-HC38 Mini DV Digital Camcorder
Gray horizontal lines in video playback
dear ,
i Jasdeep working in superb broadcast as an lengineer .and for this problem i can suggest u the following things :
1. Play back the cleaning tape for 10 sec. only then use it.
actually this problem occurs when the head get clogged (i.e, dirty ) it REC. only single band and shows the same in play back too.
Jun 27, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Blue lines in play back and no sound
Please use good quality video head cleaning tape and clean video head for normal playback.
Video head cleaning tapes are available in many electronic stuff stores.
Mar 03, 2009 | Sony Handycam DCR-TRV250E Digital...
Blue lines appear across screen during video playback.
thank you for choosing Fixya.com.
it seems that some parts in your Cam are Dirty.
please try to use the head cleaner disk first.
let me know if any changes happen.
goodluck
please don't forget to rate our answers properly.
Mar 03, 2009 | Panasonic Palmcorder PV-GS12 Mini DV...
Panasonic NV-GS60 with horizontal lines appear on screen
Clean the heads(use the specified cleaning tape sparingly).
Change tape. Using Panasonic video tape? It sounds like no. You might get by with Sony... Try Panasonic.
The tapes are different thickness, durability and therefore suitability for cameras. Try to get ME -type tape( metal evaporated) instead of MP( metal particle) as the particles tend to flake off more readily. The blue often means no signal(video) was recorded in that space(on the tape). Let me know it it helps.
vac8
Dec 26, 2008 | Panasonic PV-GS39 Mini DV Digital...
Panasonic HVX200 will not play back tape
Your playback heads might be clogged. I am not sure if this camera with give you a RF warning if your record heads get clogged. Also most professional machines drums are rated at 1000 - 1500 hours before they need to be replaced. If you are at 500 and never cleaned the heads it is time to. Run a cleaning tape a few times.
Dec 16, 2008 | Panasonic AG-HVX200A Mini DV Camcorder
Lines across screen on playback.
A Q-tip should never be used to clean a video head.  Unfortunately they can pull the tiny head out of alignment.  I believe this is your problem and the repaid may be more costly than a new purchase.
Nov 25, 2008 | Panasonic Palmcorder PV-DV351 Mini DV...
Panasonic PV-GS500
I had the same problem but without the needing cleaning message on my Pana PvGs12, weird as it sounded, I stopped it but left it on and gave it a whack on my palm and then tired playing it again and it fixed it. But I have heard it may also need professional head repair and that it may be out of alignment too? Try switching from doing it in the camera mode and or in the playback mode. I'd also try the reset button.
Dec 16, 2007 | Panasonic PV-GS500 Camcorder
Blue Lines
I have the same problem with my Panasonic and have not taken it in yet; however, understand that its a simple fix of running a cleaning tape through it.... Ill try this...
Nov 06, 2006 | Panasonic PV-GS150 Mini DV Digital...
Panasonic PV-GS31 Mini DV Digital Camcorder Logo
349 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
