Car Audio & Video Logo
Anonymous Posted on Apr 20, 2013
Nissan primera 2.2 diesel version the radio is not working properly as some times it catches the signal and some times it's not,if I think a reception problem but its the company fitted one Iam not su
Nissan primera 2.2 diesel version the radio is not working properly as some times it catches the signal and some times it's not,if I think a reception problem but its the company fitted one Iam not sure do I need to on AF and RF on in the audio controls please suggest a solution
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 23, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
253
Points
Go to the store you byed the car and they will fix it
  • Anonymous Apr 23, 2013
    Thanks for the advice
1 Related Answer
xxxxxx xxx
  • 5117 Answers
  • Posted on Jun 19, 2010
SOURCE: hi there i wonder if us can help ...i got a nissan
It is showing SECURE because wrong codes have been entered previously
To restore leave SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself.
Make sure you have the correct code.
Nissan primera key
The key you are using may not be for that car. Visit a Nissan factory service dealership and provide your vehicles' VIN number to obtain the proper key, there is likely a radio transmitter built within the thumb handle of the key which communicates with the ignition cylinder. The guys at the parts counter should be able to provide further detailed assistance.
How to reset service light on nissian primera 54 plate diesel
try turning ignition to accesories and hold down trip meter reset button for ten seconds this works on some makes of cars.
I have a 1970's Sony AM Receiver ICR-9. Reception is poor and sounds almost like it is receiving on another band. It has been a great radio and would like to retain. Bill
Do you use an indoor antenna ? Nowadays, with all gear around, like micro-waves receptors, strong motors, satellites, etc., reception becomes quite poor, unless you use an external antenna, properly set to catch broadcast stations. FM reception particularly has its signal much improved in that way. Correct demodulation requires a good an somewhat large outdoor antenna. Hope I could help. Good Luck.
Flavio/Brazil
1helpful
I got the clock from my daughter and have no manual. I keep setting the time, and it keeps changing to 2 hours earlier. I think I've pretty much figured out everything else, though this is NOT intuitive.
Hi, your clock radio is an atomic clock radio... no wait you don't need your lead underwear! it receives a signal from the atomic clock and sets the time to match it, after you set the time zone and put it on auto dst you will never have to set the time again!
ENVIRONMENTAL RECEPTION EFFECTS:
The Atomic Clock obtains the accurate time with wireless technology. Same as all wireless devices, the receiving ability may be affected by, but not limited to, the following circumstances:
  • Long transmitting distance.
  • Nearby mountains and valleys.
  • Among tall buildings.
  • Near railway, high voltage cable, etc.
  • Near freeway, airport, etc.
  • Near construction site.
  • Inside concrete buildings.
  • Near electrical appliances.
  • Near computers and televisions.
  • Bad weather locally or electrical storms between you and Colorado.
  • Inside moving vehicles.
  • Nearby metallic structures.
LOCATION PRECAUTIONS:
This clock receives a radio wave much like a TV or radio. Be sure to locate it near a window or some other location where reception is good. Avoid the following locations, which can interfere with proper reception.
Synchronization signal reception can be received in Continental USA only. In other areas, you can still use this clock by making time settings manually.
QUICKSTART
  1. Place your clock in a location with optimal signal marks on the LCD.
  2. It is recommended to put the clock near a window. Please move the clock to another location if difficulty in signal reception or unstable signal marks is encountered.
Installation
Simply plug the SkyScan clock radio into any household outlet.
Battery Back-up Operation
This clock radio is equipped with alarm time memory that can be powered with a 9-volt battery (not included).When normal household power is interrupted, or the AC cord is unplugged, the battery will power the clock to keep track of the time and set alarm. When the backup battery activates, the LCD backlight is off, however, the functions of alarm and radio still operate.
To Install the Battery
  1. Remove the battery cover at the bottom of the case.
  2. Connect a 9-volt battery to the connector plug.
  3. Insert the battery in the compartment and replace the cover.
Note: An Alkaline battery is recommended. Carbon Zinc and rechargeable (nickel cadmium) batteries not recommended.
Set the Time Zone Press the SET button in sequence until you see PST(Pacific Standard Time)blinking below the time digits on the LCD. Press UP or DOWN button to select your time zone.
Daylight Savings Time
Always slide the DST switch to ON position unless the clock is used in an area without Daylight Savings Time.
**Special attention to usage in Arizona and Indiana. **Arizona and parts of Indiana do not recognize Daylight Savings Time (DST). Turn the DST off if the clock is used in these areas.
Cheers!
3answers
I lost my nissan primera 1996 radio code
just take it in to your local nissan dealer - they will look it up for you
1helpful
2answers
Poor radio reception with Jensen VM9512 in 2001 Nissan Altima
If you used the 2 plug nissan radio harness, there should be a blue wire on there which is the (power antenna) even if your car doesn't have a power antenna, this wire needs to be connect to power on the am/fm amplified ant which is used in many nissan cars.
if the jensen has a blue or a blue/white wire, connect it to one of those. if not, you can always connect it to the red ACC wire. that should solve your reception problem..
hope this helps
13helpful
How do i reset service light on my 55 reg nissan primera
turn ignition to position 2 turn off radio push and hold info button whilst turning volume button on radio a new menu will appear on screen go into confirmation adjustments then go into service and reset
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
