Will fill with water but doesn't start cycle
  • Washing Mach... Master
  • 2,475 Answers
One possibility is that the timer motor has failed.
That would mean the timer should not be sounding like there is a clock (ticking) inside, and the knob should not advance as it ticks.
You can listen for the ticking by putting your ear to the control panel on top.
The reason it fills is that that is the first step, and it would do that, even if the times doesn't work sometimes.
Be blessed.
Posted on Apr 21, 2013
5 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: spin/drain cycle won't start
If the timer gets to the rinse cycle and stops,
Check the lid switch for continuity. If no continuity replace the lid switch.
If the timer continues through rinse and spin without doing either, replace the timer.
Posted on May 21, 2009
marka19
  • 1430 Answers
SOURCE: Washing machine won't stop filling the tub when I
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Posted on May 20, 2011
  • 5 Answers
SOURCE: I have a Maytag Model
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Posted on Jun 09, 2011
  • 207 Answers
SOURCE: My washer fills and doesn't
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Posted on Sep 13, 2011
Testimonial: "Thanks for the quick response. I will replace it tomorrow and let you know if it works."
My lg intellowasher wf t8501tp won't go into a
Check the pressure switch and hose. Pressure switch is what turns the pump on and off. Trouble is usually in the hose so check it first. Look for the hose to be unattached or clogged.
Jan 13, 2013 | Washing Machines
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
Sears washer dryer commbo model 417.94712400 didn't stop filling with water and water went everywhere
Generally you could have two problems. Number one may be a sticking water solonoid that doesn't want to close after the fill cycle has stopped. Number two, if the machine has not started to agitate the clothes that means the timer has not reached that part of the cycle and is stuck in the fill mode. My guess is number two would be more likley, the timers **** out nowand then. Hope that helps
Sep 06, 2012 | Washing Machines
Doesn't fill
Possible that the water level sensor is faulty as it tends to indicate before the level has reached thereby starting the rinse cycle.
Usually this can be due to faulty level settings or fault in the pressure switch as it can be acting too fast. It will be best to clean the inlet valve and check the flow , test the water level sensor and see if this works by blowing into the diaphragm.
Sep 04, 2012 | Kenmore 2942 400 3.2 cu. ft. Top Load...
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
Aug 01, 2012 | Washing Machines
My washer fills and doesn't stop. I try to advance it to the spin cycle but none of the cycles work. I changed the lid switch because it wouldn't fill at all. Now it fills and nothing else. Tested...
Sep 13, 2011 | Washing Machines
As soon as it gets to the rinse cycle it doesn't fill up water, what can i do?
If the only time that it won't fill with water is the rinse cycle is is probably either in the timer or control board.
Have you tested it on all the the setting to determine what works and what doesn't? Will it work on permanent press but not delicate; that type of troubleshooting.
Jul 16, 2011 | Washing Machines
I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the...
Jun 08, 2011 | Washing Machines
Will not fill with water but works on spin cycle
If your washer won't fill with water, but works in the spin cycle then the washer is sensing that water is in the tub. If there isn't water in the tub, then it is probably a sensor. If there is water but the spin cycle doesn't get it out, then look at the pump or control board.
Jun 08, 2011 | Maytag Washing Machines
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
