Question about Husky 30780 5000 Lbs A-frame Top Wind Trailer Jack
How do I drain the fuel tank on my husky portable generator?
Drain gas tank
3 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: Husky 5000 generator will not start
Hi
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and cranking the engine or by pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
Take a picture for later reassembly.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Then follow the procedure below:
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Oct 29, 2012
It shut off at 50 PSI
Did you try draining the excess water from the tank? Mine does this if there's water in the tank. You'll find a 'petcock' valve at the bottom of the tank. With partial pressure in tank, on screw the vavle slowly until it starts to drain. Let it drain all the water out then reclose the valve and try again.
Jun 18, 2014 | Husky Electric Portable Air Compressor:...
Generator does not start it has fuel in the tank with new battery ,check every thing is ok
how OLD is the gas? if it is older than 3 months with NO stab condishner get rid of it try new gas
Dec 12, 2013 | Dewalt Generator. 6000 Watt Portable...
Husky generator won't start
did you try cleaning the conductor that goes to the spark plug if not try to clean it with a real fine sand paper it should do the job.
Oct 27, 2012 | Husky Portable generator
Left some gas in tank last year,will turn over but will not start.it does not seem to be getting gas into the carb,will cleaning the carb fix it?
More then likely, needle could be stuck closed. Fuel bowl should be easy to remove, make sure needle moves when float droppes, and fuel should flow. Remove fuel line from carb and make sure fuel is running out of tank, when fuel valve is runed on.
Add fuel preservitive, and heat to fuel every year, Use minimal amount of fuel, drain and recharge every year with fresh fuel with preservitive. Run Monthly, turn off fuel and let most of fuel to be used before turning off ignition.
Sep 01, 2011 | Winco Dyna 8kW Portable DL9000E
Need new gas tank
A couple things you can do here...
1) Drain the tank, blow it dry using compressed air, and get all the rust out that you can. Use an acid wash / rinse to help remove the rest of the rust. Coat the tank inside with a tank sealer like that from kbs-coatings or caswell.
2) Have a metal shop make you a new tank that will approximate the old one.
3) Install a fuel filter that will catch the rust particles (left over after blowing it out) and be done with it
4) Use an external fuel tank (marine comes to mind) instead of onboard fuel tank.
May 11, 2010 | Coleman Powermate Premium Plus 6250W...
Makita G11oo portable generator. starts on choke. cuts off run
Just noticed your question... If you still need a little help:
1. If the gas is from last year, drain the tank and the carb bowl and replace gas with new. Visually inspect the inside of the tank ..be sure there's no sediment that needs to be cleaned out.
2. remove air cleaner and make sure it's not plugged or dirty
3. plug the spark plug and clean with spray carb cleaner.
4. At end of season, mix some gas stablizer in with the fuel to keep it from going bad while in storage.
Let me know how it goes..
k
May 21, 2009 | Makita 1,100 Watt 2.5 Hp Portable Power...
Honda 5.5 generator gas is filling oil compartment when not in us
turn the fuel off when not in use,it is going through the carb.to the oil.
Mar 17, 2009 | Honda 3000 Watt Portable Generator
Husky 30780 5000 Lbs A-frame Top Wind Trailer Jack Logo
174 people viewed this question
Top Husky Hoisting Experts
gbob59
Andrew Taylor
Andrew Taylor
JAIJITH
Are you a Husky Hoisting Expert? Answer questions, earn points and help others
