Question about Cub Cadet Riding Lawn Garden Zero Turn Tractor
Wheels won't turn, runs and blades work
Runs fine and blades turn but the wheels will not turn.
    Master:
  • 483 Answers
If by turn you mean they wont rotate, then check if parking break is on, if you mean you cant turn the steering wheel, or cant make make it go around corners, then check the linkage
Posted on Apr 20, 2013
Minka aire f608 top won't screw on
Check to make sure your blades screws are tight. They could be rubbing against the glass.
Jul 01, 2013 | Minka Aire Ceiling Fan
Spice grinder blades won't turn
You just need to turn blade with some tool which has a good grip ..I just did it with "Pincers"and now its working..Hope this help.
May 05, 2013 | Krups 203-42 Electric Blades Grinder
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Powerhead runs but tools (blower, trimmer. edger) won't work.
Hi Jim Kamph...
You have a broken drive cable inside of the trimmer.You will need to replace the drive cable
Please rate me
Bud
Sep 26, 2012 | Ryobi Garden
Bandsaw blades keep popping off,could it be heat related?
Blades slip off the wheels on these saws is because one or both wheels are not turning true to the blade. This can be caused by:
- Missing or worn tires on the wheels. The rubber tires have to be on the wheels and they have to be in good condition.
- Occasionally the screws holding the sprocket on the driven wheel come loose and the wheel will wobble causing the blade to come off.
- Both wheels ride on bearings and shafts that, if seized, worn or broken, will let the wheel wobble enough that the blade won't stay on.
- If the blade is stretched or twisted from use it won't stay on very well.
Aug 06, 2012 | Dewalt DWM120 Heavy Duty Variable Speed...
Blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
My micro twister pro helicopter won,t lift off. all seems to be working fine
If it was the motor gear, the blades wouldnt be turning at all...some ppl are clueless :-/
Jan 03, 2012 | Toys
Why won't the blade stay on the wheels of my
You need to adjust the tracking, at the very least. Get a user's manual and it will describe the procedure to adjust the wheels to keep the blade tracking properly. If it's a used saw, it's possible the previous owner didn't maintain it properly and you'll have to replace the rubber, or even a wheel (possible but very unlikely).
Jul 13, 2011 | Saws
The fan wouldn't start for the condenser unless I turned the blades with a stick so I replaced the start capacitor and it still won't start without turning the blades with a stick. It runs fine but...
This problem could be caused by a bad motor run capacitor. Please see our If your motor capacitor is not the problem, then more than likely you need a new motor.
Jun 13, 2011 | Ruud UBHC Air Conditioner
Cub Cadet Riding Lawn Garden Zero Turn Tractor Logo
123 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
