Question about Husqvarna Garden
Carb setting Cannot keep it running. Need what setting to put the carburator on.
  • 181 Answers
All husquvarna products have the same settings 1 turn out high side and 1 turn out on low side to start. high side should never be set ant less then 7/8 of a turn,if it less then that it will burn the saw up from being to lean....
Posted on Mar 13, 2009
Craftsman Kohler 26 hp starts and runs for 10 seconds with starting fluid sprayed in the carbureator then stops. How do I keep it running
first you need to see if you have fuel going to the carb then you need to see if it is going threw the carb there is a solenoid on the bottom of the carb that shuts fuel off to the jet if you have no power to the solenoid that will keep it from running also dirty old fuel sitting in the carb will cause the carb rto stick closed so if you have power to it remove it and see if it is opening
Jun 14, 2012 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Honda Elite 80 1986 motorscooter - won't keep running
most probably a carb problem, either dried out or gummed, rebuild it
Jul 24, 2010 | 1986 Honda VF 400 F
Poulan 446 Pro engine won't run
its probably not getting any gas from the tank try putting your finger on the hole on the carberator and pull your finger should be wet if not take fuel line of the carburator and thenblow then take off the gas cap and blow through the hole on the gas tank it should flow freely throgh teh line to the carburator
Nov 06, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Weedeater carburator setting on bolens 31cc
initial setting is 1and1/4 turns out for walbro carb.
1 turn out zama carb.
May 26, 2009 | Garden
New carburator and it runs worse
Check your fuel pump,it sounds as if you have excessive fuel pressure.
May 05, 2009 | 1984 Ford F 250
Scag SMT61A Mower with Kawasaki 27KA engine. 200
try taking stater fluid to carb and try keeping it running,needle seat might have some dirt in it or the carb itself needs to be cleaned.
Apr 22, 2009 | kawasaki Full Suspension Mountain Bike Men
Craftsman lawn mower can not run without pumping the red button
The fact you need to keep pushing the RED or "Primer" button says that your engine is running too lean ie. not getting enough gas.
You probably have a carburator problem due to the old gas gumming up the inside of the carb. The gum and dirt is clogging some of the internal passages of the carburator. It will need to removed from the engine and cleaned. The carburator is held to the engine by 2 bolts and is simple inside. Carefully clean the carb. with either carb. cleaner or laquer thinner or similar good solvant. Reinstall and you should be fine.
Also be sure to check your air filter and replace if dirty.
The red button is a "primer" that pumps extra gas into the engine. It is normally used only only for statrup so if need to use it while the engine's running, you're running too lean.
Dr of Motors
Mar 21, 2009 | Garden
My p/u 1988 mitsubishi 2.6L runs rough after replacing carb with
Have a qualified mechanic rebuild your original carburator and reinstall it with all the original vaccum hoses and controls functioning properly.
Someone smarter than you and I, designed this engine to function properly with the feedback carburator. Installing an aftermarket carb negates the entire emision control system and will not allow the engine to "Breathe" properly.
"KISS" (Keep it simple, Stupid)
Mar 11, 2009 | 1988 Mitsubishi Mighty Max
Garden Logo
144 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
