Question about Brother Multi-Function Center MFC-665CW All-In-One InkJet Printer
Brother mfc will not print
Brother mfc 665CW will not print or feed paper
Unable to print 50& 30
Posted on Apr 16, 2009
MFC-665CW won't turn off?
Brother MFC-665CW Quick Start Manual - ManualsLib
www.manualslib.com > ... > All in One Printer > MFC-665CW
View and Download Brother MFC-665CW quick start manual online. Brother MFC-665CW: Quick Start. MFC-665CW All in One Printer pdf manual download
Aug 30, 2015 | Brother MFC-665CW All-In-One InkJet...
I haved an error message on my Brother MFC-665CW--unable to print 51
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
Apr 07, 2013 | Brother Multi-Function Center MFC-665CW...
Im getting unable to print 50 error on my brother mfc 665cw
The paper jam you had probably lifted the long, thin, plastic encoder strip out of its slot. It is making the printer think paper is still jammed. Try gently pushing the strip back into the slot. You might have to use a screwdriver or other thin instrument to get to the strip.
Be sure printer is off when you do this.
Sep 18, 2011 | Brother MFC-665CW All-In-One InkJet...
Will not print or shut off comes up unable to print 50
I had this same problem and it is an easy fix. It is similar on all brother printers but mine was a 5860CN.
Lift the lid on your printer and at the back you can see the opening where the print head is.
With the power off, use your finger to move the print head into the middle.
Now feel under the lip of the cover at the front of the gap and you will find a plastic strip that runs from one side to the other. This is the encoding strip and it what the print head uses to read where it is. This encoding strip is easily pushed out of position when a paper jam occurs and all you need to do is to get it back into position. Using both hands use a finger on either side of the print head and lift the encoding strip upwards slightly and move slightly towards the back of the printer. This will locate it back into the correct position in the print head when you release. You can feel this with your fingers. Power back on and the problems will be gone!
Remember and be gentle so as not to damage the encoder strip!
Nov 27, 2010 | Brother Multi-Function Center MFC-665CW...
I'm getting an error saying Unable to print 30
  1. Clean all feed wheels and guides with methylated spirits.
  2. Look for any switch or guide that may be bent or out of place. This could have been damaged when a jam was removed.
  3. Look for any small piece of paper or staple that may have lodged in the paper path somewhere.
  4. Ensure the paper is dry. Not stored in a cupboard in the kitchen or the printer is not setup infront of an air vent.
Nov 17, 2009 | Brother MFC-665CW All-In-One InkJet...
Want to set brother 665CW to print black and white
It can be done, but all ink cartridge need to be in printer.The printer need all cartridges to initialized.When you start printing something click on Properties then find Advanced.There is a option Colour/Greyscale.Check on greyscale and it's done.
Oct 28, 2009 | Brother MFC-665CW All-In-One InkJet...
MFC-665CW "unable to print" 50 error
Did you have a paper jam before this happened? If yes then the paper must have pushed the encoder strip out of alignment. You will need to turn off the printer and then push it back into slot to fix it. Let me know if you need more help. Sai.
Jun 11, 2009 | Brother MultiFunction Center MFC-440CN...
I have a brother mfc 665cw printer, had a printer jam, cleared the jam and now recieve unable to print 50 error, unable to copy or print. Have found some information about the encoder strip but I have no...
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 05, 2009 | Brother Multi-Function Center MFC-665CW...
Printing problem with MFC-665CW
1. Take paper tray completely out of the machine.
2. Remove the rear cover, clean the paper pick-up roller.
3. Put rear cover back, put paper tray into machine.
4. Copy a blank page for paper feeding test.
Jan 23, 2008 | Brother Multi-Function Center MFC-665CW...
Brother MFC-665CW
I need a manuel, I'm trying to print a 4 x 6 picture and when I take out the regular 8 x 10 copy paper and want to put in the 4 x 6 picture paper I don't know where to put it. I can print a 4 x 6 on regular copy paper but thats not what I want.
Dec 20, 2007 | Brother Multi-Function Center MFC-665CW...
Brother Multi-Function Center  MFC-665CW All-In-One InkJet Printer Logo
421 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
