Question about Orbit Sprinkler System Power Source Transformer #57040
One of my zones keeps sprinkling after I shut the timer off
  • Orbit Master
  • 5,245 Answers
Which timer do you have?
Copy following link for sprinkler timer manuals
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Add comment and describe timer in detail
Posted on Apr 21, 2013
Why isn't the timer going off/changong zones?
Go to the Intermatic website and download the instructions. There may have been a design change. If possible, compare old and new instructions.
Jun 19, 2015 | Intermatic T8845PV - Sprinkler-Irrigation...
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
Sprinkler will not change zones
You mean timer will not change zones? Is it from zone 1 to zone 2? Does the timer say it is watering zone 2 and no water, does it default and shut down on zone 2? Does zone 2 have run time? Can you be a little more specific?
Feb 19, 2014 | Fimco 1-1/2 in. 10 psi 6 Outlet Indexing...
Orbit sprinkle model 57894
Copy following link for sprinkler and irrigation timer manuals from all companies:
Add a comment and describe problem in detail
Jun 29, 2013 | Hardware & Accessories
My Nelson SmartZone Ez operates 4 zones. Zone no. 1, 3 and 4 operate normally but zone no. 2 doesn't. I can hear a click when the program tries to run the pump for this zone zone but after a second it...
Let me answer your second question first. The rain sensor should take a day or two to dry out, it is supposed to duplicate drying of the earth. It is, however, adjustable so it requires more rain to shut off and comes back on quicker.
Your timer may be operating properly but you may have a faulty control valve for Zone 2. In many systems, there are control valves for each zone.
Gary
Aug 10, 2011 | Hardware & Accessories
I have 4 zones can run them manually; but they will not come on the automatic setting. Springs are strong; timer itself keeps accurate time. I did read inside the box about a "Silver Pin"...
If zones are not advancing, then 1) Clock motor is not rotating dial > replace clock motor, 2) on-off trippers are worn down > replace trippers, 3) or the day skipper is set to skip all days and all skipper pins are pushed down, 4) or sprinkler valve is bad.
The sprinkler timer dial rotates each 24 hours. The trippers cause sprinkler head to turn on zone 1 for example. Zone 1 waters until the dial rotates to part of dial with no tripper. Without a tripper on the dial, the timer turns off circuit to sprinkler. At this point, the sprinkler valve mechanically advances to zone 2 and waits for timer to turn off again. The timer does not advance sprinkler to next zone > the sprinkler valve is designed to advance each time circuit turns off. The timer just turns on and off. When next tripper rotates around, the timer turn on the circuit and zone 2 begins to water.
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
The silver pin inserted at 12midnight position is for advancing the day skipper wheel.
Open following link for parts and resources:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Jul 27, 2011 | Intermatic R8806P101C -...
Orbit Sprinkler System Power Source Transformer #57040 Logo
167 people viewed this question
Top Orbit Hardware & Accessories Experts
Craig Butler
Craig Butler
Hippy_dd
Are you an Orbit Hardware and Accessory Expert? Answer questions, earn points and help others
