Question about HP Photosmart C5180 All-In-One InkJet Printer
I NEED TO KNOW HOW TO ACCESS MY USB PORT CONNECTED TO MY PRIN
I HAVE A HP PHOTOSMART C5500 ALL-ONE-PRINTER WITH A USB PORT ON THE FRONT. I DON'T KNOW HOW TO FORCE MY COMPUTER TO SAVE MY DATA TO THIS USB STICK AS POSED TO PRINTING A HARD COPY.
You save your data to to the USB 'stick' via your PC's USB port, not the port on the printer. This port is simply for printing information already contained on the stick.
Posted on Mar 12, 2009
I have a HP Photosmart 3310. I see a place for USB key in front. I need to print document from it. It says no information found on the usb key. Can you print from USB key? Thanks
The Port on the PS 3310 is called PictBridge. it is mostly used to connect Camera devices thru USB. It will not Read documents, you will have to try using an USB Adapter ( but not sure if that will work )
Jun 23, 2010 | HP Photosmart 3310 All-In-One InkJet...
When I insert my SD memory card into my photosmart 420 it says card access error
Hi there
I dont think your printrt is made to read SD cards the only way it see the SD cards if they are in the camera and the camera lead into the USB inlet on the printer.
Printer Specifications
Category Specifications
Connectivity USB 2.0 full-speed
PictBridge
: Using the front camera port
Bluetooth: Microsoft Windows XP Home and
XP Professional
Image File Formats JPEG Baseline
Margins Top 0.0 mm (0.0 inch) ; Bottom 0.0 mm (0.0 inch);
Left/right 0.0 mm (0.0 inch)
Media Sizes Photo paper 10 x 15 cm (4 x 6 inch)
HP
Feb 28, 2010 | HP PhotoSmart 420 InkJet Printer
I have an HP photosmart 8200 series printer. It
Try installing the printer as a LPT Port or USB Port connection. Do not allow it search for any printers.
You can change port access later.
This is how I install my HP4050N Network printer.
ALSO, Is your network connection working properly?
Tihs
Jan 15, 2010 | Dell Inspiron E1705 Notebook
What kind of printe cable do i need to connect my photosmart c7280 to my computer usb port
Hello, Joe.
You need to get a USB printer cable ...
Here's a photo of the connectors:
Hope this helps.
Dec 07, 2009 | HP Photosmart C7280 Laser Printer
I need to scan a paper
Do you have the usb connected tot he front of the computer or the back?Switching to a different usb port sometimes fixes the issue.
Sep 06, 2009 | HP Photosmart C4280 Aio Printer
HP Photosmart C5500 series CD will not install completely
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | HP Photosmart C5580 All-In-One InkJet...
I have just installed my C5580 printer and every step was perfect. I printed a picture from my library- no problem. I inserted my camera memory card and printed a picture - no problem. Then I went back to...
what PC, HP, then what HP model
what OS< what operating system. on that PC.
did install the C5580 software, packing from HP.com
matching your OS?,
how is the 5580 connected to that PC.
USB connected?
Or blu-tooth connected.\
the manual.
http://h10032.www1.hp.com/ctg/Manual/c01507549
the software is here.
XP throught a w10 software is here, match what you have.
https://support.hp.com/us-en/drivers/selfservice/hp-photosmart-c5500-all-in-one-printer-series/3575176/model/3575255
if running XP, make sure SP3 is installed, service pack3
if USB fails try different USB port on that PC.
Apr 26, 2017 | HP Computers & Internet
My HP Photosmart 8450 no longer prints lines, boxes, etc., since I upgraded to VISTA and MS Office/Word 2008. HP says to buy a VISTA-compatible printer...they do not have an updated driver. Any solutions?
You can use the drivers supplied by Windows Vista
Verify that the printer is turned on.
Connect the Universal Serial Bus (USB) cable to the printer and to the computer.
After plugging in the device, select Don’t show this message again for this device.
Click Continue on User Access Control (UAC) Window.
Go to the Start ( ) icon, click Control Panel , click Hardware and Sounds , and then click Printers .
Click Add a printer .
Click Add a local printer .
Select the Use an existing port check box.
In the Use an existing port drop-down list, select USB001 and then click Next .
Under Manufacturer on the Install the printer driver dialog box, select HP .
Under Printers , select HP Photosmart 8400 series and then click Next .
In the Printer name text box, type the printer name and then click Next . The printer driver starts to install.
When the message You're successful and HP Photosmart 8400 series appears, you can print a test page to ensure that the printer is working correctly and then click Finish .
Apr 03, 2008 | Office Equipment & Supplies
HP Photosmart C5180 All-In-One InkJet Printer Logo
85 people viewed this question
Seeker5211
Seeker5211
