Question about Motorola Mobility RAZR V3
Dead phone but keypad flashes
Hi, I had the exact thing happen to my phone as reported by Heliolis below. It had been acting strange for a while where my screen would not illuminate after I opened the cover, but it would generally work if I plugged it back into the charger. It's on a relatively new battery, as well. Any other suggestions than a new battery? Posting by heliolis on Jul 29, 2007Report abuse Hi, Went to charge my V3. Plugged the adaptor into the phone. The screen indicated that it was charging for about 3 seconds and then the phone went dead. Now, phone is completely dead and the keypad is flashing. Unable to turn on the phone, unable to charge it. No water damage and was not dropped. Tried removing the battery and the SIM card...nothing :( Any suggestions?! THANKS!
    Brigadier General:
  • 7,752 Answers
Replace the LCD + flexcable on the phone.
Posted on Apr 15, 2008
2002 F-150 regular cab. Idling seems like it wanted to die. While driving would rev up and down wanting to die. Finally died at a red light and had to be towed home. In the driveway it acts like a dead...
From what you describe, it sounds like your alternator died. The battery's main function is to provide power to start the vehicle. Once started, the alternator takes over and provides the main source of power to the truck, and also recharges the battery.
When the alternator stops working, the car starts to run solely off the battery. It will work for a little while, but as the battery starts to lose power, strange things will happen with the electronics. The computers and other electronics that control the vehicle are very dependent on a constant, steady flow of voltage. When that voltage dips below 11 or 10 volts, the car may start to run badly or strange things may happen with electrical system.
When there was finally not enough power to keep the car running, it shut off. Of course, once this happens, there will not be enough power left to start the truck back up.
Feb 24, 2010 | 2002 Ford F150 Regular Cab
Nokia E71 keypad is acting strangly when u hit s it types ad5#, when trying to navigate u push down and it enters when u hit l it opens the calender.
hey im facing the exact same problem with my nokia e71. how did u fix yours please let me knoww :)))<!-- from fixya rte -->
Jan 23, 2010 | Nokia E71 Smartphone
My W980i Cannot be turned on, but the key pad is lit up. This happens after I try to connect my phone's mass storage to my computer.(It never manage to connect my phone's mass storage to my computer)
ahcuhan_92, this exact same thing happened to me
the solution is to open up sony ericsson pc suite
then under tools click "phone repair" and follow the prompts
if this fails it means your battery is dead, try charging it and try again
this worked for me
Jan 04, 2010 | Sony Ericsson Walkman W980i Cellular Phone
Flashing red light
I had the same problem, blinking for no apparent reason. I shut off phone, removed battery, put battery back in, turned on. No more red light. Not sure if the charging routine gets stuck in some loop or what, where it doesn't realize it isn't charging anymore? I think it's supposed to blink while charging isn't it? Sure would be helpful if the manual said SOMETHING about it.
Aug 06, 2009 | Sony Ericsson Cyber-shot C905 Cell Phone
Exact problem!
First of all do not put your phone in the freezer anymore because you might have water damage in your keypad and freezing it could make it worse overall. Now you should leave your keypad out to dry for a day or two then check if it works or not if it doesnt dont worry you can order a replacement keypad at http://cnn.cn this is where I get all my replacement parts at and they are really good quality and price best of luck to you.
Kyle
Jun 18, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
DEAD AFTER FLASHING
sounds like it got wet... go to the service veriz or tmob whatever it is they can retreeve your memory onto another phone
Jun 06, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Motorola v635 dead
you have a software problem. take your phone for flashing. but if there was water damage, then the phone might be dead.
flashing the phone replaces the phone's firmware with new firmware, making the phone brand new
Jun 13, 2008 | Motorola Mobility V635 Cellular Phone
Water Damaged Razr V3
what occurs with liquid damage is a cemical reaction. the fluid and the electicity create an alckaline which looks a lot like mould but acts like acid. when this happens it eats away at the components in the phone and eventually the phone dies or the prob persist until you just can't stand it anymore.
Nov 06, 2007 | Motorola Mobility RAZR V3
Mobile Acting Strange
Have you tried downloading the Nokia software updater from the nokia website? After you download this, backup your phone. Then plug it in and it will update the firmware. This might help.
Aug 23, 2007 | Nokia N95 Cellular Phone
V3 dead but keypad flashing
I had exactly the same problem. After unsucessfully looking for a solution on the net I removed the simm chip and set it aside. The next day, I put it on PC usb charge and left it overnight. The next day, I powered it up and it worked. I turned it off and replaced the simm and it is now working fine. Go figure...
Jul 29, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
238 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
