Question about Electrolux EW26SS65G Side by Side Refrigerator
Removing freezer side drawers
Can't get the freezer-side drawers out for cleaning.
  • Official Brand Answer
  • 4,342 Answers
Hello mvaillanc608 - I am happy to assist you. Do you have the model number of your refrigerator? You can typically locate your model and serial number on the inner wall of your refrigerator on the left or right side. With this inforamtion I can better assist you. Thank you!
Posted on Apr 25, 2013
Water collecting inside fridge, under meat drawer
Yes most responses are the freezer drain even if it is in the bottom freezer. If the drain is blocked water will build up anywhere inside your refrigerator only because it has no place to go during the defrost. Defective door seals can also can make the problem much worse. See Leaking Refrigerators I am here should you need me, Thanks John Tripp Appliance 911
Apr 21, 2014 | GE Profile 22.2 Cu. Ft. Side-by-Side...
I cant get the cool select pantry drawer back in
I just had the same problem. The drawer was removed for cleaning and we could not get it back in; it would slide in with about 3 inches not able to go in. Took everything out that we could and still could not get it to go back in all the way. Finally started looking closer at the metal rails and the sides of the drawer and realized there is a tab on each side that needs to be inserted in the the corresponding hole on the metal rail. With the drawer out, pull the rails all the way out; place the side rails of the drawer on the metal side rails and line up the tabs with the holes and insert. Your drawer should now slide in correctly.
Dec 18, 2012 | Samsung RF265AA Bottom Freezer French Door...
Top drawer on F&P dish drawer stuck on cycle & continuously beeping
You could isolate the top drawer by taking the controller power cable out. DIsconnect mains power to dishwasher, open top drawer and remove front cover carefull after removing 2 plastic pins on each side with plier. Controller box is on left top side, remove bottom connector and cover with insulation tape. Put things back and turn power back on.
But if you want to find the fault with top drawer then that is very trick if there is no fault code on panel except beeping First clean the top panel inside door with a clean damp cloth. If this does not change the situation, then it is very likely the controller is detecting some faulty sensor - and will need to find one by one. Are you ready for it?
Dec 17, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
I can't remove the freezer drawers from my Whirlpool Gold Model # GI5FVAXVB02. Called the company and they couldn't help me.
you have a blocked drain,try this,pull out the machine,unplug it,remove the bottom panel,lie on the floor and with a light look up or feel around,there's a nipple that's there that the water drains out of or drips through,i've been removing the nipple,running it under water to clean it,but it has to go back,if you don't put it back you'll have problems,this keeps the warm air from getting into the freezer,before you put it back on get a hair dryer and melt out the ice,just heat up the back freezer wall and then pour hot water down through the back wall,if the water drains out you don't have to take the freezer draws and racks out,they changed them all around and i can't explain how to do it and if you pull it out and don't line the two wheels up correctly the door won't close right,i mark them with a marker before i pull them out,it sucks to do and is very ridiculous,you need a manual just to remove these parts,if this doesn't have a nipple on it and has a drain hose there you can try to clean it out from that end,you can get a piece of 1/4 in water line like they use for the water lines on the fridge,buy a piece and snake it up through the drain hose and then blow through it then flush water through the back inside freezer wall,slime builds up in the drain hose on all machines so once it's freed up it will drain,you might think that if you go from the back you'll push it up into the freezer and it will happen again it won't,once you hit it and free it up it will break apart and every time the machine defrosts the water will wash any parts that is still in there out.i'll try to see if i can find any videos on line for you to show how to remove the shelves and racks and then to line them up again but try going from the back first.good luck.
Aug 10, 2012 | Refrigerators
Samsung bottom drawer freezer is leaking and ice is forming along both sides of the drawer?
See previous answer re drain blockages. Also check condenser clean and all fans working ok.
May 20, 2012 | Samsung Refrigerators
I just bought a house with a Kenmore stainless steel bottom drawer freezer. The freezer drawer does not close completely and large amounts of snow and ice accumulate inside. I have taken the drawer out,...
Check top see if the arms of the drawer are fully seated into the rails which support it and extend from inside the freezer when the drawer is opened. On most french door refrig's, there are hooks on the back side and tabs on the front side which are sometimes hard to get back in. Then the door is locked into the rail with a screw at the point where the rail meets the freezer door.
Aug 21, 2010 | Kenmore 73503 Stainless Steel Bottom...
Im thinking of buying the MFF225VE bottom freezer but am wondering can you remove the freezer baskets to clean the bottom floor of freezer?
The baskets do come out, there are some tabs that can be depressed on each side and the bins come up. If you want to take the entire drawer out you would need to remove a couple of screws from each side to accomplish this.
Let me know if this was helpful or if you have questions.
Thanks
Jun 14, 2010 | Maytag MFF2258VE Top Freezer Side by Side...
Bottom freezer door/drawer won't close all the way on one side.
Remove all the food from the freezer and then the drawer from the cabinet. Now using a silicone based lubricant, lube the tracks up real well. Be sure to clean the tracks first if gunked up. Make sure nothing small fell out of the basket over time and is laying on the floor in the rear of the freezer section. Once done, you should be fine.
Eric Campion
Feb 21, 2009 | LG LRFD25850 French Door Refrigerator
Electrolux EW26SS65G Side by Side Refrigerator Logo
113 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
