Question about Pool & Spa
How do we get a stuck pisto out so we can replace o rings?
  • Pool & Spa Master
  • 1,384 Answers
Rinse the valve out well with fresh water and try using the pump to pop out the valve.
Posted on Apr 24, 2013
How do you remove a stuck cv from inside at trans axle
Every one I've replaced was stuck. You need to jerk it out. I've pried carefully with a flat blade screwdriver and I've ised a small pry bar as well. Some have a ring on the end that keeps it from pulling out. You need to keep jerking at it and once the ring lines up it will just about fall out. Check and see if the new axle has a ring on it as well. Sometimes you need to move it from the old one onto the new one.
Apr 03, 2015 | 2004 Dodge Dakota
What foods come from spain
Some of the foods you may be familiar with are: Paella, Gazpacho, Tapas, Salmorejo, Pisto, and Turron. All of which I think you will love. Try them and see.
Jun 18, 2014 | Cooking
I cant get the oil pressure relief valve out the cap and spring are out but the piston is jammed in the bore
try tapping the pisto with a punch to realign it then use a small magnet to remove it
Mar 02, 2014 | 1989 Toyota Land Cruiser
Do you hawe parts for a husqvarna 254 piston end rings my mob number is 00353 85 730 98 28
The pisto is readily available from any Husqvarna dealer, the part no. is 503503701, there are also plenty of pirate parts available on the web
Apr 04, 2011 | Husqvarna Chainsaw Piston Kit for 61...
I replaced my GE profile MWF water filter (identical GE part) and now I dont have water dispensing and don't have a working ice maker
Quite frequently carbon fines can be flushed from filter and plug the filter. If you have the bypass plug to replace the filter. Put that in and flush system completely. Take the filter and flush it at the kitchen sink. It is best to fill these with water before installing and flush the carbon fines before installing in fridge.
RJ
Mar 09, 2011 | GE Mwf Ge Refrigerator Smart Water Filter...
How much for a pisto and a rings
There are many different prices depending on if you want original parts or after market. Original pistons and rings are $20-$40.
Here is a link to the pistons and rings. Look at number 14 and 15 in the list. http://www.bikebandit.com/2005-suzuki-motorcycle-dr-z125/o/m5889#sch505648
If you found this answer helpful please leave a good rating for me. Thanks hope this helps.
Nov 22, 2010 | 2005 Suzuki DR-Z 125
When trying to pull start my Mcculloch chainsaw 338, its all jerky. ok last season. Help please.
Take the spark plug out and pull the cord to see if it stuck.
Drain all gas and get a new mix.Put back the sp and start.
If thr cord was unable to pull,thr pisto and crankshaft must be service.
Oct 26, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Kenmore electric dryer series 70, on the inside of my dryer there is a plastic white ring that is cracked and brittle, clothes get stuck on this ring and tear, can I replace this white ring?
Yes, you can replace that ring.
I believe you have a front loading machine, if so then you will need to remove the front of the machine to expose the ring, drum and belt.
Try this website and see if they can supply the part you need.
Good luck, I hope this helped
http://www.partsselect.com/
Oct 03, 2009 | Kenmore 73952 Gas Dryer
Will not go up past 20 psi i put another pump on for now however would like to fix my old pump any thoughts
hi you don't say what pump it is ,or how many cyl but whatever it is take head/s off clean up or replace valves remove cylinder/s check pisto/s /rings and bores replace /rebore as nessasary check big ends /main bearings replace as nessasary small pumps and 80%of the chinese ones are totaly uneconomical to repair in fact some of the chinese stuff ,and not just comps are only fit for scrap as soon as they leave china !! hope this helps merlin v12
Aug 20, 2009 | Plumbing
Zoom ring on 18-55 mm lens is locked/stuck
Are you sure it's the zoom ring that's stuck, and not the focus ring? The focus ring doesn't move when the camera is in autofocus.
If it's indeed the zoom ring that's stuck, you can spend more money than the lens is worth in repairs, or buy a replacement (circa 35 dollars on ebay) for dreadfully cheap. Good luck.
Apr 06, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
