Question about WELLY 2006 Ford Explorer Eddie Bauer White Diecast Model 118 Die Cast Car
2006 Ford explorer shut down while driving - WELLY 2006 Ford Explorer Eddie Bauer White Diecast Model 118 Die Cast Car
  • 5,784 Answers
Could be crankshaft sensor.
Posted on May 09, 2013
What causes engine to ABRUPTLY shut off while driving ?
2004 Ford Explorer Engine Stalls/Cuts Out While Driving: 31 ...
www.carcomplaints.com/Ford/Explorer/.../engine/engine_stalls_cuts_out...
... 2013 · 2012 · 2011 · 2010 · 2009 · 2008 · 2007 · 2006 · 2005 · 2003 · 2002 · 2001 · 2000 ... 2004 Ford Explorer engine problems: engine stalls/cuts out while driving ...to overheat and slide out of its socket, causing the engine to shut off. ..... Suddenlyat 30-35mph, my engine just died and i cannot control the steering wheel.
2005 Ford Escape Engine Shutdown While Driving: 24 ...
www.carcomplaints.com/Ford/.../engine/engine_shutdown_while_drivin...
The 2005 Ford Escape has 24 complaints for engine shutdown while driving. ...January 22: Ford Ranger Driver Killed by Takata Airbag in South Carolina news ' 2 days ago; Ford Focus Door Latch ..... I was 80 miles from home when the engine shut off. .... No one could seem to determine the true cause of the problems.
Ford Ranger Stalling/Dying Problems - Edmunds.com
forums.edmunds.com > Ford > Ford Ranger
Nov 2, 2007 - 31 posts - ‎21 authors
Learn more about Ford Ranger at the Edmunds.com Car Forums! ... cut off a couple of times then it started happening more frequent while driving. ..... the other day I was driving down the highway and it just shut off, no warning .... 2000. when it gets overheated the circuit shorts and causes the engine to die. Ford Expedition engine cutting off while driving
Oct 24, 2009
Mercury Mountaineer Start Stall Idle Problems
Oct 1, 2007
More results from forums.edmunds.com
Jan 27, 2016 | 2003 Ford Ranger Regular Cab
What is the meaning of abs light and the traccontrol light on at the same time on a 2006 ford explorer
Go to the following web page down load the drivers handbook and see if that helps. There are also driving tips.
owner.ford.com see owners handbooks etc
Jul 09, 2014 | 2006 Ford Explorer
Shutting Down
Could be a relay, fuel pump, ignition coil, or several other things.
The charging system would only affect the condition of the battery.
Jan 20, 2014 | 2003 Ford Explorer
2006 ford explorer door hinge
I'd imagine that is common, there is usually a catch, that helps hold the door open so it won't swing shut on you. I don't know if catch is replaceable or you can try lubrication on it, see if it helps?
Mar 28, 2012 | 2006 Ford Explorer
Why does my ford shut off while running, turns back on immediately when cranked and now Check engine light is on?
Drive to Autozone or Oreillys and ask them for a free scan of your vehicle. They will tell you what part you need when they scan the car.
Oct 22, 2009 | 2006 Ford Explorer
I have a 94 ford explorer. While driving down the
Probably a loose wire. Make sure batter cables are tight and check for lose ground wires.
Aug 13, 2009 | 1994 Ford Explorer Limited
1993 Ford Explorer bogging down
This is not a bogging down problem if the engine is reving up it sounds like you have a very badley slipping tourk converter or you have a band in your tranny slipping and that is why you can go for a little while longer if you shut it off
Nov 13, 2008 | 1992 Ford Explorer
Ford explorer 2006
check thermostat or fan clutch is going back
Aug 22, 2008 | 2006 Ford Explorer
WELLY 2006 Ford Explorer Eddie Bauer White Diecast Model 118 Die Cast Car Logo
Top WELLY Toys Experts
xkikbxr
RSole
Bogdan Odwazny
Bogdan Odwazny
Are you a WELLY Toy Expert? Answer questions, earn points and help others
