Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
I want to delete protected pictures
A picture in projected status needs to be deletred
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Unprotect the picture first. In playback mode, scroll to the protected picture, then press the AE-L/AF-L button on the back of the camera.
Posted on Apr 20, 2013
5 Suggested Answers
  • 272 Answers
SOURCE: how to protect pictures so they do not get deleted
Best way is to only delete them 1 by one. Another is to transfer files (pictures) to your computer delete the ones you don't want, format your card and then put the ones you want to keep on your camera back. You can't delete just a few pictures. I carry 3 memory cards. one just has the pictures I want to show people. I load that card from my computer. The other 2 are like great big rolls of film that let me take lots and lots of pictures without the worry of running out of film. I transfer the pictures I want to show people on my camera to the third one and keep the other 2 erased. Most of my pictures are only on my computer and backed up on DVD's.
Posted on May 11, 2009
  • 102366 Answers
SOURCE: When I try to delete
What camera? What kind of card? SD cards have a sliding switch along one edge. Slide it away from the contacts.
Posted on Dec 30, 2009
  • 240 Answers
SOURCE: my memory card is write protected. when i turn on
Hi. Thanks for your question.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
NOTE: If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
Please don't hesitate to ask more questions if this is needed. Thank You for using FixYa.
Posted on Jan 10, 2011
ed_romero1
  • 36 Answers
SOURCE: i need to delete some pictures from my nikon
Take out the memory chip and push the little tab down...or up. The opposite direction its in. If you look on the side edge of the chip you'll see a little **** next to a small tab (usually light blue, maibe red, might even be black). Once you moved it (up or down) you'll notice the little **** is now covered by the tab and there is a new **** where the tab was (basically the **** is now on the opposite side of the tab).
If there is no **** don't worry, some are designed different. If the **** is visible you can delete pics, if it's covered by the tab then it is protected so you can't delete any (or vise versa).
Posted on Oct 04, 2011
My camera says internal memory full.How can I delete it?I have tried for a hour and I cannot delete it.The pictures that is.
Go to Menu.
Select a picture or multiple pictures you want to delete.
delete the pictures.
*make sure the file is not "protected" in which case you "un-protected the file and follow through the steps.
Note also that once you delete the pictures, they are un recoverable......you may consider backing up on the laptop or HDD before following through
Mar 21, 2015 | Cameras
If the picture on the camera is protected, unprotect the picture first. In playback mode, scroll to the protected picture, then press the AE-L/AF-L button on the back of the camera.
If the memory card is protected, take the card out of the camera. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 20, 2013 | Nikon D40 Digital Camera with G-II 18-55mm...
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
I dont know how to delete a protected picture off my canon power shot a470 camera. Can you help?
You have to unprotect it first. It's a bit confusing because the menu item probably only says "Protect..." but it also takes care of unprotecting too. Go into the menu for "Protect..." and navigate to the protected one. Whatever button you press to switch the protected status (it's the SET button on my Canon) you can use it to turn the protection off as well. When you exit the protection mode, you can delete it.
Jan 20, 2011 | Canon PowerShot A470 Digital Camera
Deleting protected pictures
"Protecting Photographs from Deletion
In full-frame, zoom, and thumbnail playback, the button can be used to protect photographs
from accidental deletion. Protected files can not be deleted using the button or
the Delete option in the playback menu, and have DOS "read-only" status when viewed on
a Windows computer. Note that protected files will be deleted when the memory card is
formatted"
This is from the nikon website. You can down load the entire users manual here:
http://www.nikonusa.com/pdf/manuals/dslr/D40X_en.pdf
Dec 24, 2010 | Nikon D40x Digital Camera
Pictures were protected for a temporary photo shoot now I would like to have them unprotected to delete. How does one go about deleting pictures from a Nikon D60?
To unprotect a picture, while viewing the picture press the protect button (marked with a key) to the right of the viewfinder. To delete the picture, press the delete button (marked with a trashcan) below the multiselector.
Jul 07, 2010 | Nikon D60 Digital Camera
Need to delete protected pictures
Try to remove first the memory card of your camera. After you remove the card you can see a small button at the side of the memory card. Just slide the small button to unprotected. Insert your memory card back to your camera and try to delete pictures.
Apr 25, 2010 | Kodak Easyshare M753 Slim Digital Camera
I can't find the manual for my didital ixus 700 and need to delete some photo's but they have been proteced, i don't know how to remove the protected status?
Here's the manual (free to download):
http://safemanuals.com/user-guide-instructions-owner-manual/CANON/IXUS%20700-_E
Protection / unprotection of pictures is dealt with on page 130.
Note that FORMATTING a card will delete ALL pictures (irrespective of protection).
Hope this helps
Mar 09, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Can't delete a photo off my memory card.
you should have turned on the protection status on while taking pictures by default. to switch of this status all you have to do is in the preview mode of the camera select that particular picture. now press the menu button. you can see a variety of options there. in those there is an option protection status of "protect this photo". you can turn it off there.
May 26, 2009 | Canon PowerShot A95 Digital Camera
No power
if the lamp is bad. it will blink.dont worry make sure you put screws back and cover on there are protection switches.If still blinks after bulb replaced and cover on. it is the thermo fuse on or near bulb, Then after that it get complicated
thanks DOCTOR VIDEO
Apr 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
51 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
