Question about ASUS Eee PC 900 Notebook
Lcd compress mode greyed out
Unable to select that mode
    Problem Solver:
  • 20 Answers
Press Fn+F5 and select the "lcd only" option. Now the menu choice is available again.
Posted on Jun 29, 2009
The display on av2 is just a grey screen and i am unable to access tivo. I reset my tivo and the set up screen displayedvthen went back to grey screen
Corrupted firmware. A firmware update is necessary. If you get access to its control menu, do a factory reset, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 04, 2016 | Televison & Video
How to reset unable to clean 50 on dcp-j125
Try to reset Purge, it just might help.
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Clean unable 46 error on dcp 135c brother printer
Jun 03, 2014 | Brother DCP 165C Compact Color Inkjet...
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
May 19, 2010 | Brother DCP-350C InkJet Printer
When the camera is turned on view window is not lit up viewing is dark and grey hard to focus but still takes a good picture?
Do you mean the viewfinder or the lcd-screen?
The Nikon D80 does not have a 'live-view' mode to watch the picture you're about to take on the LCD-screen. It's a semi-professional camera not to be used like a standard 'point-and-shoot' digital camera.
If it is the viewfinder that's out of focus, try adjusting the dial to the right of the viewfinder. It might also be that your internal mirror doesn't get powered (in this case you're unable to see the focus areas). In the last case you will have to get the camera serviced by Nikon.
Dec 13, 2009 | Nikon D80 Digital Camera with 18-135mm...
Can i access panoramic feature, it is always
make sure you are using an Olympus XD memory card, most others do not support the panoramic photo setting :)
Jul 20, 2009 | Olympus Stylus / mju 1050 SW Digital...
Color page in Batch to file
If you select color mode and scan grey and color pages, the output will be Grey for Grey abd color for color. If you had chosen to scan in grey mode, color will appear in Grey only.
There is an option to scan in both color and B&W simultaneously under multistream option.
S. Mohan, India
Jan 27, 2009 | Canon DR-9080C Path-Through Scanner
HP deskjet printer D2460
Welcome to Fixya !
I assume that the printer is set to print in grey scale as below. follow the same procedure to change it to colour mode. If its still priniting in the Grey scale mode, Then please check the ink level in the printer.
Print in grayscale
To print in grayscale
1. Open the Printer Properties dialog box.
2. Click the Color tab.
3. Click Print In Grayscale.
4. In the Print In Grayscale drop-down list, select an option.
5. Select any other print settings that you want, and then click OK.
Apr 03, 2008 | HP Deskjet 2460 InkJet Printer
Toshiba Satellite A105 grey screen
just replace screen pop top off unscrew it out and unplug it put new one in and do u have latest video card drivers installed make sure u do that also
Jan 05, 2008 | Toshiba Satellite A105 Notebook
Documents scanned as 256 grey scale/TIFF show up as black pages.
Grey as you know is different shades of black. Uncompressed TIF can store this information. Compressed TIFF is not designed for this. Compressed TIFF is for blck & white only. Try JPG option. JPG can compress Color & Grey. For pure black & white chose TIFF compression.
S. Mohan, Chennai , India
Jan 05, 2007 | Canon DR-9080C Path-Through Scanner
LCD screen goes plain grey
i think it's the case of damaged flexible cable to the lcd screen from the camera. a replacement will do the job
Jun 27, 2006 | JVC GR-DVM5 Mini DV Digital Camcorder
ASUS Eee PC 900 Notebook Logo
304 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
