Question about Sony CDX-L480X CD Player
Power ON Sony CDX-L480X CD Player doesn't turn on the radio but the cd will work, if a CD will be insert it works, but neither CD play music.
  • 3 Answers
SOURCE: sony cdx r3300 Won't play...simply scrolls a message
_half fixed, use the remote -@least can get more life outa the unit!
Posted on Mar 13, 2009
  • 13 Answers
SOURCE: sony cdx-m610 BIG PROBLEM
yal ever fix them? its the ribbon cable between the face and the circuit board inside the unit the ribbbon cable is very cheap on ebay just google for example cdx-m610 ribbon cable now for the repair close ur face before u take out ur radio assuming u guys still have ur remote to do so theres 3 screws on the bottom of the face when u go to carefully pop the front panel off after pullin them hold ur deck facing down (this will keep ur reset and open buttons from fallin out then theres 4 screws holding in the face's circuit board roll the board out of the face very very carefully pry open the little black lock holding the cable in the connector then open ur radio up pull out the cd player assy same thing with that connector then ull notice the cable goes thru a tension roller pull each end of the cable to unroll it hold it there while removing the cable and sliding in the new one then slowly let go of the roller reattach the cable ends and put everything back together with the face remember its easiest to hold the deck face down those 2 buttons will stay in place hook the top of the face's cover first then put the deck back in ur ride and enjoy these ol sonys r worth a $20 fix specially if they still work good hope this helps yal
Posted on May 06, 2009
SOURCE: CD RESET
to fix this problem you have to take the face plate off. There should be a small button on the middle-left side that sais "reset" on it. Get a ballpoint pen and press this button. Pop the face plate back on and play your CD and it should work no problem.
Posted on Jul 11, 2009
SOURCE: Sony CDX-S2210 buttons are jammed
Hi Sameersach,
Have you found a solution for your problem? I have the same player and I got the same problem...please, let me know if you found a solution. Thanks!
Posted on May 10, 2010
SOURCE: sony CDX-L480X
I had the same problem, CD not accepted by unit and pressing source button to select CD player causes unit to display reset.
Using reset button just causes unit to 'whir' for a while, problem is not solved. Firstly with unit switched off, and the ignition off I inserted a CD using some gentle force, I then inserted a second CD, forcing it in over the top of the first. Next I pressed and held the reset button for a short time before releasing it. Both CDs were ejected, when the unit had stopped I took the CDs out, replaced the front panel and turned on the ignition, The unit will now accept CDs and eject them O.K.
(This did take two attempts to get right). Seems to reset the eject status of the CD player.
Avulon
Posted on Aug 08, 2010
I have a Sony CDX L480x fitted in my car, this radio has worked fine since i got the car, unfortunatly when i put the face back on it the other day, none of the buttons will work, volume, source...etc. All...
It sounds like the volume button may be jammed or the volume up switch may be bad. If the switch is open just enough to let some voltage through it locks up the microprocessor. Unless you have a multimeter and know how to check resistance on a switch you would be better having a professional repair person check it out.
Sep 29, 2011 | Sony CDX-L480X CD Player
When I put the CD in the player the CD comes up and the time playing but the volume doesn't play. Is there a trick to it?
Is the radio working fine? Are you using an amplifier? If so, you may be using the blue wire (power antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) to turn you amp on. The antenna remote turns off when leaving tuner mode, turning the amp off.
Jul 04, 2011 | Sony XPLOD CDX-GT200 CD Player
I would like to fit the cdx-L480X into my caravan
ok that will work fine please tell me what the problem is genrally if ir caravan had a tape player the plug should be the same as this unit uses a uni plug if not there will be a converter for under 5 pounds
Jan 19, 2011 | Sony CDX-L480X CD Player
It wont turn on the radio but the cd will work but the buttons wont make the sound i know when its working
Try removing the face panel - behind it on the main unit you will see a indent (small hole) that says reset, insert a ball point and you will hear a bleep (sometimes). Replace the front panel and everything should work, though you will need to reset stations and clock.
Nov 19, 2009 | Sony CDX-L480X CD Player
No instructions on tuning radio
The Manual is downloadable from Sony at
http://pdf.crse.com/manuals/3247340121.pdf
Avulon
May 19, 2009 | Sony CDX-L480X CD Player
Sony CDX-L480X
Avulon
Feb 17, 2008 | Sony CDX-L480X CD Player
Sony CDX-L480X CD Player Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
