Question about Hitachi 43UWX10B 43" Rear Projection Television
Projection TV is out of focus
Had no problems with this TV, always had a great picture! One evening we turned it on and it was out of focus. We hadn't made any changes to the TV. It hasn't been moved, no changes. We tried the MAGIC FOCUS button, didn't help. We would like to fix this ourselves. I have the same problem. I had the amplifiers and resistors replaced. Worked ok for about 2 days and went bad again. Repairman said I needed that whole assembly replaced. He tried to find one and couldn't. Any ideas to try
Thanks
Jake
  • 4 more comments
  • j222996 Mar 12, 2009
    Do you know the part number for the whole assembly?
    Jake
    Had no problems with this TV, always had a great picture! One evening we turned it on and it was out of focus. We hadn't made any changes to the TV. It hasn't been moved, no changes. We tried the MAGIC FOCUS button, didn't help. We would like to fix this ourselves. I have the same problem. I had the amplifiers and resistors replaced. Worked ok for about 2 days and went bad again. Repairman said I needed that whole assembly replaced. He tried to find one and couldn't. What is the part number for that whole assembly?
  • j222996 Mar 13, 2009
    There is no button labeled Input on my remote. Any ideas
    Jake
    The remote I have is a Hitachi Part Number: HL01643
  • j222996 Mar 14, 2009
    RyleeGave a solution using the remote, however here is no button labeled Input on my remote. Any ideas? The remote I have is a Hitachi Part Number: HL01643
    Thanks
    Jake
  • j222996 Mar 15, 2009
    Very useful. Will look in
    Sergeant:
    Champion:
  • 435 Answers
What you can do it get a broken TV (screen broken??) of same model from ebay and salvage the parts.
That might work out cheaper.
Posted on Mar 14, 2009
  • Hitachi Master
  • 19,396 Answers
Hi there.
Your TV has lost convergence, and as the convergence setting and autofocus do not help in fixing the problem, that means that one of the convergence ICs had blown.
You need to have the convergence ICs replaced, the job can cost $200/$300 at a local repair shop.
Below is explained how to do this kind of repair:
Fixing Convergence problems in RPTV's
Posted on Mar 12, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
Try adjusting the picture yourself by entering the service mode, you can do that by---
1. TV turned off 2. Press 'Power' and 'Input' buttons on the TV for more than 3 seconds.. You are now in the Adjustment mode
The letter P indicates picture and A indicates audio.
4. Use the 'Menu up or down' on the remote to select the item. 5. Write down the old value of the item before changing. 6. Use the 'Menu left or right' to change the data.
Please ask for any clarifications.
Please accept the solution if it helps.
Thanks Rylee
Posted on Mar 11, 2009
    Sergeant:
  • 320 Answers
Yes you can try to get the required parts at
www.partstores.com
as per the repair menn its right that the assembly has the problem.
Flash focus can no longer line up all colors,and gren is the one always sticking out;do I need to replace all my "color lamps"?
No,this tv have no projection lamp,tv only have 3 CRTS tubes guns R,G,B.Ur tv have a problems known convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike.The tv convergence board is dead.Tv convergence board,must be replace 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 17, 2011 | Sony KP-48S75 48" Rear Projection...
Sony kp-57hw40 double picture. regular and the other right next to it is red. tried auto focus and nothing happens. while holding auto focus btton down get red cross and white next to it. tv is 9 years...
Auto Focus button no longer work.Tv have a problems known as a convergence problems,it dead.Tv have colors lnes R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replaced on the tv convergnce board to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 13, 2010 | Sony KP-57HW40 57" Rear Projection...
I have a Hitachi Projection TV 51G500A 2004 ,
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Hitachi 51G500 51" Rear Projection...
I purchased a tv repair kit and replaced the convergence ic chips to fix my convergence problem. put everything back together and now, no picture. I tried magic focus and it works great, the colors are...
As per statement, "the magic focus works great, the colors are bright and aligned" it means the tubes are working ..you need feed a signal to see the picture...the tv video goes muted without signal
Dec 29, 2009 | Hitachi 60SDX88B 60" Rear Projection...
Sony rear projection tv model KP-53V15 turns on, have sound but no picture, after a while, picture comes on, but later goes out again, picture keeps coming and going. Where do I start looking?
Adjust Screen Volts (G2) of all 3 picture tubes and screen volt control knobs are on focus block located under speaker grills at front of TV.
Remove speaker front grille of TV, look for focus block that has 6 control knobs, 3 knobs are for focus and 3 for screen volts, increase volts by turning little bit control knobs of screen volts and this will solve your problem.
Nov 02, 2009 | Sony Televison & Video
Rca mm52110 rear projection tv with issues
Will power up, but won't have a picture. What could cause this?
Sep 16, 2008 | RCA MM52110 52" Rear Projection HDTV-Ready...
1986 tv won't turn on
Great TV you bought.
At this point I would say it might not even be worthy to get the TV fix due to the age unless you can do it yourself.
In my opinion you can save the money from the repair to buy a new TV.
Hope you do not upset with the messenger LOL.
Jul 16, 2008 | Samsung HCM4215W 42" Rear Projection...
3-D picture
Good Day, ladyluck5509;
It sounds like the TV is experiencing an auto focus problem. That in other words is a convergence problem, needing to replace the convergence IC's, chips. There is no known focus knob. If you are concern of shocking oneself, I would recommend that you seek a factory authorized service center for repair. Always, always get an estimate first.The normal/average cost for this repair should run between $350.00-450.00.
Good Luck, Big Irish.
Jul 09, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Picture goes black
With a shop doing the repair they will almost always say the deflection PCB will need to be replaced which would be about 350.00 plus labor. I would suggest trying to solder the vertical output IC first as that is usually the cause on the mitsubishi rear projection or solder around the flyback one of the two.
Jun 29, 2008 | Televison & Video
P56930BL focus problem
Sounds like you need a new focus block, they are actually cheap. If you need a link on where to get one let me know.
Jun 20, 2008 | RCA P56930BL 56" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
66 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
