Question about Canon Pixma Mx330 Inkjet All-In-One Printer
Canon mx330 won't scan windows 8
I just got a new computer, Windows 8 OS It prints fine. I downloaded everything from Canon site already.
SOURCE: Canoscan 4200f Problem with Vista 32 bit
I got mine working after experiencing the same problem.
I had mine hooked up to a USB hub, after I hooked it directly to the USB ports in the back of my computer, everything just worked fine.
Weird that it worked on the USB hub on XP and not vista though.
Posted on Jun 24, 2008
SOURCE: failed to open a driver
OK. Here is what you do. (I just did this on an Intel Mac running OX10.5.6)
First go to the cannon site and get the program (File name: deldrvosx1510en.dmg) to uninstall the drivers for your scanner. Also, delete copies of the scan toolbox that you may have installed in your application folder.
Then go back to the canon site for the LiDE 25 and install the drivers (file name: lide25osx11030en.dmg.) This part is very important, in the middle of the install a dialog will popup asking if it is OK to run something like deldvr, DO NOT ALLOW IT TO RUN, HIT CANCEL.
reboot.
Install the canon toolbox software (it should be version 4.9.x not 5.0). File name is : cstbosx4934ej4.dmg
You should now be good to go.
What a %^#%$#-up process on Canons part.
Posted on Mar 12, 2009
SOURCE: Canon ScanGear CS driver error Code: 2,252,0 - Can't preview
Canon ScanGear CS driver error Code: 2,252,0. Error when trying to Preview scan using ScanGear in your program, e.g. Word, PhotoShop...
I had the same problem, Canon Technical were clueless on this error code. Yes the problem occured when trying to preview first however I could scan but without any preview, pointless really.
I have fixed it for Windows Xp SP3, Canon Lide 80. To Fix:
You need to download the latest ScanGear driver and Deldrv.exe from the canon website. You don't need the Toolbox, http://software.canon-europe.com/
It would help if you have Tuneup 2009 (even Trail version) for the later parts of this fix: http://www.tune-up.com/download/ just click download, you don't need to give them your email address.
1. Save these on C:
2. Remove the USB cable from your scanner - make sure it is unplugged.
3. Run Deldrv.exe, select your scanner and uninstall.
4. Now you will need to go into 'C:/WINDOWS/TWAIN_32' folder; you must remove anything in this folder - safest thing to do is CUT any items and paste them on the C: or personal folder.
5. Now the register parts - you need to purge your registry of any left over values. I found out after several attempts that this final step fixed the problem for me.
Basically through Windows XP Regedit or TuneUp Reg Editor search the ENTIRE registry for first 'ScanGear', second, 'Canon' and third if you have installed previously, 'Canon Toolbox'. Find any entries relating to any Canon scanner software and delete them. I only found around 6 or 7 entries to remove.
6. If you have TuneUp run '1-Click maintence' (correct problems) and afterwards run the 'Register defragger'. Restart.
7. On the next bootup your register should be optimised. Ok, disable any Anti-virus software.
8. Run the scangear setup winzip file you saved on C:. * it will extract a folder to C:. If get an error with the extraction, try running it anywhere else except C drive. Alternatively if you have WinRar, right click and manual extract contents. The scangear setup winzip file/folder (called lide80vst7250a_xpen) only contained a readme and setupSG.exe.
9. You must run the setupSG inside this folder. And you're done. Enable your anti-virus.
9. Now connect USB to scanner, Windows should pick it up. Open Word or PhotoShop > run the scangear program to preview.
10. Done! It worked my end.
Please let me know if this helped you.
Posted on Apr 27, 2009
SOURCE: Canon 8400f suddenly will not allow neg scan option
just had the same problem, check the connection going into the top part of the scanner at the back and restart which ever program your using... got mine sorted
Posted on May 22, 2009
SOURCE: CanonScan Lide 30 flatbed
You need the software called "Canoscan toolbox"...click on the link below and then select your operating system...you can also get the driver for the LIDE 30 on this page:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6623
Posted on Jul 04, 2009
How do i get canon imageclass mf 6540 to scan
Such printers with scanners built into them are know as Multi Function Printers. It is possible you have downloaded a 'printer only' or generic printer driver software.
Here are the links to the 3 bits of software you require:
http://www.usa.canon.com/nw3s/CanonUSA/DownloadContents/English/0100242106EN.htm
http://www.usa.canon.com/nw3s/CanonUSA/DownloadContents/English/0200155901EN.htm
3 (only for 64 bit windows 8)
http://www.usa.canon.com/nw3s/CanonUSA/DownloadContents/English/0100114601EN.htm
3 (only 32 bit Windows 8)
http://www.usa.canon.com/nw3s/CanonUSA/DownloadContents/English/0100114501EN.htm
May 05, 2014 | Canon ImageClass MF6540 Copier
Tip
Drivers and Manuals for PIXMA MX330 Windows and MAC OS
Here I will show you where to find drivers and manuals for the CanonPixma MX330 OFFICE all in one printer.
Drivers for this printer are available for Windows98, windows ME, windows Xp, Windows Vista, windows vista 64bit editions,windows 7 and windows 7 64bit editions.
On the Mac side drivers are available for Mac OS X 10.3/10.4/10.5/10.6
A full on screen manual, quick start guide andother instructions are also available.
To download these drivers and or documentation foryour printer please visit
THISPAGECLICKHERE
Note that the picture belowreads mp730 but the actual page linked will be for MX330
1. Click on Drivers & downloads
2. Select your OS ( Operating system, windows, macetc )
3. All available drivers, documents etc will beavailable below.
For some of the documents a PDF reader may berequired to open and read / print them.
To obtain a PDF reader, read this page
PDFDocuments. Pdf reader(s)
Thank you for reading and I hope your printer isup and running again.
-Ekse
on Mar 11, 2010 | Canon PIXMA MX330 Multifunction InkJet...
PIXMA 990 won't scan on windows OS 8
Visit the Cannon website to see if there's an updated driver for the scanner software.
Sep 30, 2013 | Canon Pixma Mx330 Inkjet All-In-One...
Canon LBP printer driver won't work on my Dell Laptop
1) Make SURE the Canon printer is NOT attached to the Inspiron when installing the software!
Why?
When a device is installed (In this case the device is a printer), Windows 'breaks it's neck' to find suitable matching drivers.
If THE drivers are not already there, Windows will match up one of it's THOUSANDS of generic, one-size-fits-all, drivers.
This = NO
A driver conflict will result when THE drivers are installed afterwards;
Windows: "Which drivers do I use? These or THESE?"
Drivers and software is installed FIRST, then the printer is plugged into the computer, and turned on.
If you have just downloaded the drivers, I suggest you go back, and download the Software AND the drivers /package.
You need the software for the user interface.
When you see the file name DOUBLE-click on it.
Then follow the easy instructions of the Installation Wizard.
(Just click on Next, Next, and Finish, at the bottom of the three small windows)
For additional questions please post in a Comment.
Regards,
joecoolvette
(Don't forget to Restart the computer after the drivers and software is installed. Then when Windows has loaded again connect the printer to the computer with the USB cable, and turn the printer on.
After a couple of seconds you should see a message out of the system task bar, at the bottom of the monitor screen;
"Found new hardware", and then after perhaps another one;
"Found Canon LBP XXXX" )
Sep 25, 2012 | Dell Inspiron 15R Notebook
I lost my cd for my canon pixma mx330 printer wat do i do
You can download the software from manufacturer's support website by clicking this link
On the page which opens, select the operating system of your computer (Windows XP/ Vista..) from the drop-down menu (See attached image).
Then download and install the required drivers and software.
The list of available software and drivers will load only after selecting the operating system of the computer.
Hope this solves your problem. Thanks for using FixYa.
May 02, 2011 | Canon PIXMA MX330 Multifunction InkJet...
Need a driver for canon canoscan N 65OU
I got this link from Canon's site. Click here. Choose the Operating System of your computer. Then download the driver utility. I hope this will work for you.
Jun 07, 2010 | Canon CanoScan N650U Flatbed Scanner
My cannon pixma MP150 just won,t print or do anything, it is connected to the computer alright & the computer says that it is connected but it just won,t print or scan, can you please suggest anything...
probably you need to download the driver for windows 7 in the canon website.(www.canon.com.sg) if this doesnt solve your problem check the led and display of your printer. if the led blinks alternately in orange and green it means that your printer needs to be brought to an authorized service center for resetting and diagnostic.
Feb 13, 2010 | Canon Office Equipment & Supplies
Canon mp600 scan problem vista windows 7, does not scan print ok,
Do you have Windows Vista or Windows 7? They are two different OS. Drivers are available here. If you haven't downloaded and installed the latest drivers, uninstall all drivers on your computer before installing these. Be sure and download/install the MP Navigator also.
Nov 11, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon Pixma Mx330 Inkjet All-In-One Printer Logo
188 people viewed this question
old marine
old marine
