Question about Garden
6 hp motor starts runs fine couple min then dies wait min same thing over apears to be get gas
  • 7,482 Answers
Hi gary
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Apr 21, 2013
I have a B&S 22hp Intek v-twin on a craftsman mower. It starts fine, runs great, but after about 10-15 min it starts skipping and will finaly die after another coupl min. As if it was running out of...
Mine did exactly the same thing until I figured out the replacement fuel cap I bought wasn't vented.I put a vented one on and away I went.Also check for a collaping fuel line,and check the screen inside the gas tank,those corrode sometimes.Hope that helps !
May 11, 2014 | Briggs & Stratton Briggs Stratton Intek V...
2000 blazer runs rough and dies when gas pedal pushed to floor.
sounds like you need to change your fuel filter or you may need a new fuel pump relay
Jan 23, 2013 | 2000 Chevrolet Blazer
85 vette starts runs a few seconds dies. could it be a crank shaft sencer
if you need to keep your foot on the gas to keep it running clean the throttle body and idle speed motor
Aug 20, 2012 | 1984 Chevrolet Corvette
I have an audi a6 4.2 v8. it ran out of gas before i could get to the gas station and i tried to buy some gas and put in there. so i did and it still wouldnt turn on. so i got more i checked the oil and...
Check and replace if necessary the fuel pump. When the car ran out of gas the fuel pump was not cooled enough and worked with air inside, then fails more and more often.
Apr 30, 2011 | Audi A6 Cars & Trucks
13 hp honda pressure washer 3000 psi 4gal/min Hard to start and dies out after 20 seconds after the engine gets hot and running after multiple starts the engine will stay running but then dies every 30...
There are a couple of things that can cause this problem. The first thing to check is if you are loosing spark. Dying after it gets hot sounds like to stater is failing in the engine. If you loose spark this is more than likely the issue. If you are not loosing spark you need to check the fuel system. Dying after 20 seconds it could also be a plugged main jet in the carb. Another common issue on Honda engines is a faulty vent on the gas caps for engines sold from around 2008 - late 2010. If your gas cap is only about 3/8" thick this is very likely to be your issue. Try running the engine without the gas cap on to see if it still dies. If not that is your problem.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Nov 03, 2010 | Honda Landa PG 3500 PSI Pressure Washer
Stops running AFTER A COUPLE MINS
If it starts OK and runs fine for a few minutes you may have debris (dirt) in your gas tank. The dirt settles on the bottom, you start the motor and through vibration and shaking the dirt gets mixed up in the gas and sucked onto the fuel filter until the motor starves and dies. When the motor dies the dirt settles back on the bottom and you start all over. With the motor off, shake the gas up well and drain the tank into a bucket so you can check for debris. If there is a lot, half fill the tank, shake it up and drain again. Also, you may want to check your gas can to make sure the debirs isn't coming from there.
Sep 23, 2010 | Husqvarna Chain Saw 18" 450 Model...
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
