Question about Lanier 7335 7328 7320 Upper Fuser Roller
Lanier 7328 prints black streaks - Lanier 7335 7328 7320 Upper Fuser Roller
4 Suggested Answers
SOURCE: Lanier 7328
hi im jules_09,have you tried cleaning all the ruber roller?try cleaning all ruber roller then lubricate al bushing and gears.if there is still a problem check all paper sensor it can be cleaned with alcohol.just soak the paper sensor with alcohol then let dry after a few minute then install it back again in the copier.dont soak the paper sensor in alcohol while it is in the machine.turn of the copier first
Posted on Nov 03, 2007
SOURCE: I have a lanier 7328 Copier and need a manual for
I have it. Let me know if you still need the manual.
Posted on Mar 12, 2010
  • 257 Answers
SOURCE: I have a lanier 7328/7320.
How are you? This is a problem with front door switch.
Remedy
  • Place the machine on a level table and make sure all the four stands are landing freely on this table.
  • Check that the front door notch that closes the door switch is not broken and if it is replace that particular door or modify the notch.
  • Make sure the upper half of copier is well locked with the lower bottom part.
If all the above is correct, and still reads open, replace the door switch.
Good luck.
Posted on Nov 15, 2010
Xerox 7328 not printing in color
Ensure that you are intalling the correct print driver, www.xerox.com, support section.
Also check to make sure that the colour option in the printing preference is not set to Black and white or grayscale.
Also ensure that you dont have any accounting option set to black and white only.
Dec 28, 2012 | Xerox WorkCentre 7328 Multifunction laser...
In Lanier GX3000 I would like to print with black ink only. The printer displays to replace the three color ink cartridges.
The printer requires that all of its ink cartridges have ink before printing, the color ink cartridges will have to be replaced.
May 12, 2011 | Lanier Office Equipment & Supplies
XEROX WORKCENTRE 7328 IS RUNNING SLOW WHILE PRINTING PDFs
Are you printing to the printer using the Xerox Global Print Driver PCL6? If so, this will be the cause of your problem. Earlier versions of the driver werent as bad when processing PDF documents. I would suggest that you download the Workcentre 7328 PCL6 driver and try that - the problem should clear.
Cheers
Jon.
Dec 17, 2010 | Xerox WorkCentre 7328 Multifunction laser...
I have a lanier 7328/7320. It reads side door open on screen. Only the door is closed. Any suggestions
Remedy
Good luck.
Nov 15, 2010 | Lanier Office Equipment & Supplies
Black streak at center of page; LP238C is model of the lanier copy machine
Problem could be on the Glass or Mirrors.
Also could be the blk drum unit
Print out a counter page.
If the line is present clean the charge roller in the drum unit
If it is not present clean the glass and mirrors
Good Luck
Mar 03, 2010 | Lanier UNKNOWN
HP L7700 officejet printer leaves streaks on black ink lines only. Have cleaned heads repeatedly, changed black and color cartridges - nothing works.
Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE: This step does not apply to color printouts.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Nov 28, 2009 | HP Office Equipment & Supplies
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Lanier 6720
If when you open the rt. door are the streaks on the drum unit? If not remove the 1 screw and slide the fuser out and check there
-Carl
Sep 03, 2008 | Lanier 5235 Printer
Lanier 7328
Nov 03, 2007 | Lanier 1205 Copier
Lanier 7335 7328 7320 Upper Fuser Roller Logo
26 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
