Question about Ragalta Thermo Electric Hot and Cold Water Cooler
Hot water faucet on water cooler not working - Ragalta Thermo Electric Hot and Cold Water Cooler
On demand hot water heater gets cold for a short while during showers.
Check for crossover.
Bad single-handle faucet cartridge causes cold water to enter hot pipe, so hot never arrives and tankless does not run consistAntly
http://waterheatertimer.org/Crossover.html
Apr 13, 2013 | Bosch AquaStar 2400ES-NG
Heater takes more than 1 minute to get water to kit faucet , then temp fluctuates
1) Guesses: Sounds like a bad single-handled faucet cartridge, or low water flow at faucet, or clogged water filter.
Replace faucet cartridge, clean the aerator, and/or clean sediment out of pipes below sink, and clean water filter at tankless unit each month.
2) For exact measure of problem:
Typical faucet can have 2 gallon per minute flow rate.
2 gpm flow rate means faucet fills 1 gallon container in 30 seconds. Test faucet using 1 gallon container and a cooking timer to get flow rate.
Clean aerator to improve flow rate. Compare kitchen flow rate with other faucets in home.
http://waterheatertimer.org/Low-hot-water-pressure.html
Most homes have 1/2" diameter pipe running to kitchen faucet.
100 feet of 1/2" diameter pipe holds 1.2 gallons of water. This assumes no sediment build-up inside pipes.
http://waterheatertimer.org/Water-heater-recirculation-system.html
Assuming only hot is turned on: If faucet is 100 feet away from water heater, and pipe diameter is unobstructed 1/2" diameter, and faucet has 2 gallon per minute water flow, then hot water should arrive in 36 seconds.
50 feet away, and hot water should arrive in 18 seconds.
If kitchen has single handled faucet, and the handle is raised in the middle, then equal amounts of hot and cold water are drawn at same time. This doubles amount of time for hot water to arrive.
If single handle faucet has a bad cartridge, then faucet can have crossover.
Crossover means that cold water can enter the faucet even if faucet is turned to hot.
Bad single-handled faucet cartridge can delay or stop the arrival of hot water.
Tankless require maintenance including cleaning combustion parts yearly, de-lime heat exchanger frequently, and clean water filter each month.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
http://waterheatertimer.org/pdf/Bosch_Overcoming_fluctuating_temps.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 15, 2011 | Rheem Direct Vent Natural Gas Tankless...
I own a watercooler 4 yrs old model # whkmd30The bottle water get extremely hot. There is good ventilation Any suggestions
Your water cooler has a Hot water section, also-- correct?-- You have 2 faucets, right?-- One COLD and ONE hot!
Is it possible that the section that does the HEATING, is stuck ON and is in some way heating the water back up thru the connection, into the big bottle?
Another possible thought: Is there a heater to prevent freezing of the bottle?-- Maybe it is stuck ON
Note: Your question ended up under Vacuums-- We are just trying to help-- Feel free to re-list your problem up there where water coolers are-- OK?
Sorry we couldn't be more helpful here in the Vacuum cleaner area-- :-)
Mack B
Jan 29, 2011 | Vacuums
Need new faucets for Sunbeam water cooler
hot and cold water have a smel, do I have to clean or replace sonthing?
Sep 12, 2010 | Avanti Hot and Cold Water Cooler
Only warm water from the tub/shower
You can cap the lines at the tub faucet to rule out tub faucet. It maybe mixing there.
Faucet may be bad also the safety stop will alow you to change water temp it can be tricky to adjust water temp.
May 02, 2010 | Moen 1 Handle Lever Shower Faucet With...
Sunbeam Drinking Water Cooler model YLR2-5-24H2
my hot water faucet is broken!!.. when can i get new?
Jan 21, 2010 | Whynter FX-6SB Free Standing Hot & Cold...
My delta 132900 gets too hot.
With these Faucets, you can remove the handle and make adjustments to the max Hot water setting (scald guard).
You may also have a faulty or lime-covered cartridge.
SEE THIS SITE for making adjustments/replacing the cartridge.
Thanks for using FixYa - a 4 THUMB rating is appreciated for answering your FREE question.
Aug 23, 2009 | Delta & Single Handle Shower Faucet
I purchased a whirlpool 40 gallon hot water heater model #BFG1J4040T3NOV in November of '08. since its been installed i been having a problem with the water staying hot for more than 1 shower. After about...
Will the water stay hot in the kitchen sink? Try to isolate the problem. If it is happening at all hot water locations, then it will be related to your water heater. If just in the shower then it is related to the mix of water ratio coming out of the shower hear. If its only the shower, then you are getting too much cold and not enough hot through the pipes. This can be very simple to fix by replacing the handle going to the shower. If this does not work then you may have a problem in the hot water pipes. After you isolate the problem, please post another question here.
Apr 16, 2009 | General Electric GE SmartWater Household...
Ragalta Thermo Electric Hot and Cold Water Cooler Logo
53 people viewed this question
Top Ragalta Water Filters & Coolers Experts
Tom Chichester
Are you a Ragalta Water Filter and Cooler Expert? Answer questions, earn points and help others
