Question about Toshiba Satellite A205-S5879 Laptop
I have a toshiba satellite lap top with vista. With XP, I could go to 'preferences' a was given an option to print in black ink only. With vista, I go to 'preferences' and there is no option to print in black ink only. How do I print in black ink only?
    Problem Solver:
  • 19 Answers
What kind of pritner?
Posted on Mar 11, 2009
Can you solve the problem for my lap top Toshiba satellite E105-S1402, I am not able to register my finger print on TrueSuite Access Manager Finger Print. The error message come "failed to open the sensor"
You can try to download and install the Fingerprint Utility here and check if you will receive the same error message.
Refine Search by: Your Operating System (Vista by Default)
All Categories: Security
Title: Toshiba Fingerprint Utility for Windows Vista / XP
Download and Install
If the reinstallation of this software does not help then the issue must be related to a corrupt Windows Vista files and in my opinion the usage of the Toshiba recovery CD should helps.
Thanks for using Fixya
Jul 29, 2010 | Toshiba Computers & Internet
Displays no hard drive found wen installing win xp
You have to go to BIOS setup, find HDD setup, and change the value to the other one (there are only two possibilities). That will fix your problem. The problem is caused by the fact that the lap top was designed for vista, not XP. and the lap top contains SATA HDD. when installing XP pre-installation doesn't have SATA drivers, so your OS can not see the HDD. Change it in BIOS, and you trouble is gone
Nov 14, 2009 | Toshiba Satellite A200-19501F Notebook
Dell AIO 924 - Can't get the Print In Black Only option to work
hello! Ttry this option. At start menu select control panel, then select printer, then right at your printer model, then select properties, and select maintenance. At maintenance menu, select ink settings. if you want to use black ink only then click the menu button. or at Printing Preferences select main, then just check the box with grayscale printing.  if the problem still the same Try upgrading your system to XP Pack2 Professional or Vista Premium/Ultimate, then install your printer driver. These two system has a built in upgraded plug and play drivers, so it best suit to your need. thats it... Have nice day!
Dec 23, 2008 | Dell 924 All-in-One InkJet Printer
Black ink only
Print using pigment black ink only (Windows) Instructionsto print using only the pigment black ink tank only. Occasionally youmay need to print using black ink only. Using grayscale alone does notprovide this option and the color inks will still be used. By followingthis procedure you may print using only the pigment black ink tank. Note: Image quality may be sacrificed when printing photographs.
  1. Open the Properties / Preferences window for the printer.
    For Windows Vista
    • Click/ Select 'Start' from the bottom left of the Windows screen, 'ControlPanel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    • Clickyour right mouse button on the listing for your printer, and thenselect 'Printing Preferences...' from the menu that appears.
    For Windows XP Home Edition
    • Click/ Select 'Start' from the bottom left of the Windows screen, 'ControlPanel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
  2. Click on the Main tab.
  3. Select 'Plain Paper' as the Media Type. If any other paper type is selected, color ink will be used to create black.
    Note: The pigment black ink will only be used when printing on plain paper.
  4. Select the box for 'Grayscale Printing'. If the document to be printed is in black only, then this step may be skipped.
    Note: If either 'Borderless Printing' or 'Duplex Printing' are enabled from the Page Setup tab, grayscale will be created using a combination of the color (dye) inks to prevent smearing.
  5. Click 'OK' to save the changes.
The printer will now only use the pigment black ink tank.
Oct 15, 2008 | Canon Pixma MP500 All-In-One InkJet...
Support
hi, for the driver of ur sound card click here
Jun 22, 2008 | Toshiba Satellite P105S9337 Notebook
A135-S7406 Instruction for replacing Vista with XP
insert the windows xp cd on the system before booting ,in the bios setup choose BOOT from CD option and u can install xp onto it..
no additional drivers are required
note: try xp with service pack 3 to have vista themes..
please do vote
regards
pradhan
Mar 21, 2008 | Toshiba Satellite A135 Notebook
I had this problem. It's actually very easy to fix:
- Print -> Properties
- Go to "Advanced" tab
- "More options"
- Deselect "Use color cartridge for all black printing"
- Select "Use black cartridge to print black and white"
- Click "Ok"
You should be able to select the "Print in black and white" option now and stop all the frustration!
Anthony
Dec 05, 2007 | Dell 924 All-in-One InkJet Printer
Instaqlling a game by iwin on my lap top
right click on the game go to properties , try changing the compatibility settings, to windows xp
Nov 20, 2007 | Toshiba Satellite P105-S6207 Laptop
Toshiba Satellite A205-S5879 Laptop Logo
71 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
