Question about Hoover UH70120 WindTunnel TSeries Rewind Bagless Upright Vacuum Cleaner
Vacuum wont turn on
Its plugged in and i press the power button and it doesnt turn on
  • 57 Answers
Power cable damaged, get new
Posted on Apr 20, 2013
Why wont the reset button depress on riccar 8955 or turn on after trying
The reset button does not have a significant amount of movement in response to pressing to with a paper clip or ball point pen. If the vacuum does not start upon pressing the button, then either the thermal protection circuit is not why the vacuum stopped in the first place or the reason the thermal protection circuit tripped has not been cleared. Quoting from the manual
"Your Riccar vacuum cleaner comes equipped with a Manual Reset Thermal Fuse Protector. This thermal protector is designed to protect your vacuum cleaner from overheating due to a restriction in airflow (i.e. clogged hose, operating the vacuum without a bag). Should this situation occur, the thermal fuse protector will safely shut off the vacuum cleaner to avoid any potential damage. NOTE: To determine it was the thermal fuse protector that turned off your vacuum
cleaner, please refer to the vacuum cleaner's headlight. If the headlight is on while the motor is off, then the thermal fuse protector did safely shut down the motor. If both the headlight and motor are off, then there is some reason other than the thermal protector (i.e. pulled plug) your vacuum is off.
To reset the thermal fuse:
. Unplug the vacuum cleaner
  1. Check for problem - over-filled bag, clog in hose, clogged filters, etc.
  2. Correct problem
  3. Locate "tripped" fuse - the small white button located on the bottom of the back side of the main body (roughly one inch to the right of the left wheel)
  4. Using a pencil, paper clip or other pointed object, push the reset button in
  5. Plug vacuum cleaner in and resume use"
Mar 08, 2015 | Riccar 8955 Upright Vacuum
Spark caused vaccum to turn off
Some vacuums have a reset button you can push. Some have a fuse in the power line that may have blown. You will have to follow the power all the way through the vacuum checking the voltage at each switch, connection, etc. I often unhook the power & neutral wires from the motor and hook up a power cord with connectors on the end directly to the motor to make sure the motor is good. You must be very knowledgable with motors, switches, electrical testing, etc. If not this repair is best left to a professional.
Mar 03, 2014 | Dirt Devil Vacuums
My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
Apr 04, 2013 | Electrolux Zb4106wd Rapido Wet And Dry...
Power wont come on
Look for a reset button, inspect the cord and if it failed while on make sure whatever it uses for a filter is not blocked with dirt.
Dec 23, 2012 | Shark Euro-Pro Ultra Steam Blaster...
Brush doesnt turn
Look for the reset button on the side of the brushbar housing - there should be a red sticker and a red button. Push it once. It's
not gonna stay depressed, it's gonna pop right out - that's normal.
- Step on the red pedal on the back
- Turn the machine on with the red power button
- Press the gray button next to the red power button - this is the ON/OFF switch for the brushbar - if it doesn't spin, press and hold the gray button down for 10 seconds
- If it still isn't spinning, remove the brushbar and make sure nothing is blocking it and withholding it from spinning
this link is for the manual..
http://media.dyson.com/downloads/UK/floorcare/Manuals/DC24_allfloors_uk.pdf
Sep 23, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
My apple ipod touch wont turn on
I've seen this before. You need to reset it.
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
I hope this works!
May 10, 2011 | Vacuums
The Dyson roller ball vacuum I have is making me crazy because the roller bar wont turn. What gives?
Check that you dont have anything blocked in the roller, if all is clear there is a little red button on the side off the roller. Push this in and this will reset the roller... If that doesnt work, check that it is switched on with the switch next to the power button.. That should solve your problems
Oct 04, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Where is the reset button on shark navigator. vacuumed throw rug, and bar wont move
I'm not sure it has one. Check the owner's manual though.
Try this. Turn off vacuum. Unplug it. Make sure there are no clogs in main hose, power head intake tube, or intake inside tank. Plug it in, turn it on, and let us know what happens.
Aug 23, 2010 | Euro-Pro EuroPro Shark Navigator Vacuum
Wont turn on when pluged in and the plugs that
tighten the center screw in the back that holds the top handle assy on. this always comes loose and causes the vacuum to not recieve power. let me know if this doesnt fix the problem
Jan 08, 2010 | Bissell 5770 Healthy Home Bagless Upright...
Hoover UH70120 WindTunnel TSeries Rewind Bagless Upright Vacuum Cleaner Logo
214 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
